  2. Announcements
  3. πŸ’¬ MYSController
πŸ’¬ MYSController
58 Posts 24 Posters 32.8k Views 23 Watching
  • J jimmy loyens
    @jimmy-loyens i use a mosquitto broker to get messages from my esp milight hub in openhab. Can i use this same broker with different topic? I beleive openhab uses mqtt binding for this. Sorry still got a lot to learn about mqttπŸ€”
    G
    G
    Guillermo Schimmel
    @jimmy-loyens Yes, use the same broker for everything.
    • J jimmy loyens
      @guillermo-schimmel thanks, seems i have an ethernet shiel + spare uno lying around. I will give it a go. Is the mysensors binding compattible with custom nodes i written my own code for? Wich metod is less work to reprogram my openhab? I'm asking because my openhab is quite elaborate. I have a few 100 items and about 80 mylight sensors plugged in to openhab 😁 right now (serial gateway) they all enter openhab via 1 rule with a large hashmap. If i understand correctly i have to create a thing for each sensor and link each item to the channel of this thing. Got a lot of work to doπŸ˜‰πŸ˜‹
      G
      G
      Guillermo Schimmel
      @jimmy-loyens said in πŸ’¬ MYSController:
      Same setup here.
      Yes, it supports custom nodes.
      Yes, but if you do it in text files it's not that bad.
      J 1 Reply Last reply
      • J
        J
        jimmy loyens
        Ok, thanks for all your help! I'll get started this weekend with the mysensors binding approach. 🀞
        • G Guillermo Schimmel
          Same setup here.
          J
          J
          jimmy loyens
          @guillermo-schimmel hi, when i look under mysensors binding in openhab paperui i only see things for serial gw & ethernet gw but not for mqtt gateway. Am i supposed to build a ethernet gw or is mqtt gw allso supported? Just asking to know wich firmware to flash since hw is the same. Thanks
          G 1 Reply Last reply
          • J jimmy loyens
            G
            G
            Guillermo Schimmel
            @jimmy-loyens You have to build an mqtt gateway. On the hardware side it is identical to the ethernet gateway.
            There is another sketch for it though:
            https://www.mysensors.org/build/mqtt_gateway
            It is very easy.
            Please let me know it if works. I really like the openhab+mqtt+mysensors combination, I think that eventually there will be a lot of us here.
              It is very easy.
              J
              J
              jimmy loyens
              @guillermo-schimmel I have been looking at the mysensors binding this evening (see my posts here: https://forum.mysensors.org/topic/7176/openhab-2-2-binding/118), but at first sight i cant get it working (i cant find a lot of clear documentation on the binding either) so i'm leaning more to the MQTT-binding approach right now. I will be exploring this route tomorrow. allready reflashed the gateway with MQTT-firmware
              • J jimmy loyens
                J
                J
                jimmy loyens
                @jimmy-loyens do you use the mysensors-binding in openhab or the mqtt-binding (or a combination of the two)
                • J jimmy loyens
                  G
                  G
                  Guillermo Schimmel
                  @jimmy-loyens I use the openHAB-mysensors 2.3 binding.
                  But if you are unsure your mysensors setup works, it’s reasonable to start with mqtt binding and then migrate. Lots of moving parts.
                  I have posted here my own files for your reference.
                    J
                    J
                    jimmy loyens
                    @guillermo-schimmel can you tell me where you downloaded the binding? I think im using the 2.2 binding. Is it possible you forgot the link to your setup files? Greets
                    • J jimmy loyens
                      G
                      G
                      Guillermo Schimmel
                      Please take a look here:
                      https://www.mysensors.org/controller/openhab
                      You will find my config and also a link to the 2.4 version of the binding.
                      J 2 Replies Last reply
                        J
                        J
                        jimmy loyens
                        @guillermo-schimmel ok thanks, the link was formilliar, i have come by this link at one time in the past but i couldnt find it anymoreπŸ™ƒ. I will give it another try tomorrow with the newer binding. The configuration examples will help alot. ThanksπŸ‘
                          J
                          J
                          jimmy loyens
                          wrote on last edited by jimmy loyens
                          #41
                          • A
                            andy5211d
                            Have Mysensors in use with Home Assistant for several years, no issues. Using a Sensebender Ethernet MQTT gateway to feed HA. Just found this software. Can only get this software to connect via serial connection, not IP, and only shows data in the MYSController Debug tab. No nodes are discovered just 0 and 255. Is there something I need to do with the Gateway to allow connection for this software? Example of debug tab messages:
                            22/04/2020 18:34:56 ERROR ErrorFlag=255, Msg=2433158 GWT:TPS:TOPIC=mygateway2-out/23/1/1/0/0,MSG SENT
                            22/04/2020 18:34:56 RX 2433224 TSF:MSG:READ,23-23-0,s=2,c=1,t=0,pt=7,l=5,sg=0:28.1
                            22/04/2020 18:34:56 ERROR ErrorFlag=255, Msg=2433224 TSF:MSG:READ,23-23-0,s=2,c=1,t=0,pt=7,l=5,sg=0:28.1
                            22/04/2020 18:34:56 RX 2433224 GWT:TPS:TOPIC=mygateway2-out/23/2/1/0/0,MSG SENT
                            22/04/2020 18:34:56 ERROR ErrorFlag=255, Msg=2433224 GWT:TPS:TOPIC=mygateway2-out/23/2/1/0/0,MSG SENT
                            22/04/2020 18:35:00 RX 2437119 TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:28.5
                            22/04/2020 18:35:00 ERROR ErrorFlag=255, Msg=2437119 TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:28.5
                            22/04/2020 18:35:00 RX 2437120 GWT:TPS:TOPIC=mygateway2-out/23/1/1/0/0,MSG SENT
                            22/04/2020 18:35:00 ERROR ErrorFlag=255, Msg=2437120 GWT:TPS:TOPIC=mygateway2-out/23/1/1/0/0,MSG SENT
                            22/04/2020 18:35:00 RX 2437186 TSF:MSG:READ,23-23-0,s=2,c=1,t=0,pt=7,l=5,sg=0:28.5
                            22/04/2020 18:35:00 ERROR ErrorFlag=255, Msg=2437186 TSF:MSG:READ,23-23-0,s=2,c=1,t=0,pt=7,l=5,sg=0:28.5
                            22/04/2020 18:35:00 RX 2437186 GWT:TPS:TOPIC=mygateway2-out/23/2/1/0/0,MSG SENT
                            22/04/2020 18:35:00 ERROR ErrorFlag=255, Msg=2437186 GWT:TPS:TOPIC=mygateway2-out/23/2/1/0/0,MSG SENT
                            22/04/2020 18:35:03 RX 2439780 GWT:TPC:IP=192.168.1.96
                            22/04/2020 18:35:03 ERROR ErrorFlag=255, Msg=2439780 GWT:TPC:IP=192.168.1.96
                            22/04/2020 18:35:04 RX 2440780 GWT:RMQ:CONNECTING...
                            22/04/2020 18:35:04 ERROR ErrorFlag=255, Msg=2440780 GWT:RMQ:CONNECTING...
                            22/04/2020 18:35:04 RX 2440783 GWT:RMQ:OK
                            22/04/2020 18:35:04 ERROR ErrorFlag=255, Msg=2440783 GWT:RMQ:OK
                            22/04/2020 18:35:04 RX 2440784 GWT:TPS:TOPIC=mygateway2-out/0/255/0/0/18,MSG SENT
                            22/04/2020 18:35:04 ERROR ErrorFlag=255, Msg=2440784 GWT:TPS:TOPIC=mygateway2-out/0/255/0/0/18,MSG SENT
                            22/04/2020 18:35:04 RX 2441081 TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:28.4
                            22/04/2020 18:35:04 ERROR ErrorFlag=255, Msg=2441081 TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:28.4
                            22/04/2020 18:35:04 RX 2441081 GWT:TPS:TOPIC=mygateway2-out/23/1/1/0/0,MSG SENT
                            Any suggestions anyone? Thanks.
                            tekkaT 1 Reply Last reply
                            • A andy5211d
                              tekkaT
                              tekkaT
                              tekka
                              wrote on last edited by tekka
                              #43
                              @andy5211d MYSController won't work with GW debug output. Use the GatewaySerial or GatewayW5100 example sketch to interact with your nodes.
                              • A
                                andy5211d
                                @tekka, thanks for the pointer. I'm using the GatewayW5100MQTTClient sketch, is this not the correct one? Works well though! Or, I do have MY_DEBUG at the beginning enabled, is then incorrect? However I can't connect MYSController via the IP port either. So if it is MY_DEBUG enabled as the problem then it impacts on both connections?
                                Jan SpiesJ 1 Reply Last reply
                                • A andy5211d
                                  Jan SpiesJ
                                  Jan SpiesJ
                                  Jan Spies
                                  @andy5211d It seems that MYScontroller does not work when MQTT is involved. I've tested both sketches, GatewayW5100 and GatewayW5100MQTTClient, and only GatewayW5100 could connect to MYSController.
                                  • A
                                    andy5211d
                                    @Jan Spies, Thanks for your help. Was about to try different sketches over the weekend but guess I'll try some other approach now. Would really like to get MYSController or something similar to work. I can see data on the serial port (as shown below) but nothing on the ethernet port that looks useful other than what is sent and is returned from MQTT (I'm using Home Assistant). I have Lazerus so may have a play with the data on the serial port. Perhaps could feed the serial data into another Arduino and make it available on another IP address for different MySensor controller software. as not easy to get to my gateway hardware with a serail connection. Or seeing that the data is in MQTT perhaps feeding it into another app to display similar to MYSController. Wonder if the source of MYSController in in Guthub. Will have a look; no point in re-inventing the wheel... Wish I could work out what the ERROR ErrorFlag=255, etc means in my serial port output in the post below.
                                    • A
                                      andy5211d
                                      @Jan Spies But wait, just noticed that Home Assistant can take MySensors data direct from either a serial port of IP connection. Must be a new option. My implementation is from some 5 years or more ago and think then only MQTT was the way into the Controller. Guess it could have been because I started out with OpenHAB and perhaps that controller only had a MQTT option then. When i moved over to HA it just worked so did not look at anything else. Now want more sensors has have a solar power system I'd like to monitor closely and i can't easily interface to the solar power units. So more sensors and some sort of MYSController.
                                      • A andy5211d
                                        Jan SpiesJ
                                        Jan SpiesJ
                                        Jan Spies
                                        @andy5211d this is good news! I'm going to take a look at HA's direct access. I hope it works, I really would like the remote programming.
                                        • JoeridemanJ
                                          JoeridemanJ
                                          Joerideman
                                          wrote on last edited by Joerideman
                                          #49
                                          So is there a gateway where it also possible to use the serial connection for Home Assistant and the IP connection for mysensors?
                                          With your input, this post could be even better πŸ’—
