  2. Announcements
  • А
    А
    Артем ТИхонович
    This is my old dream to connect directly nrf to Cubieboard GPIOs. Few years ago i try to do this without success using this lib - https://github.com/bearpawmaxim/librf24-sunxi
    • А Артем ТИхонович
      #968
      Hi @артем-тихонович, welcome to the MySensors forum!
      For the NRF24, the same defines as for normal sketches are used. Documentation: https://www.mysensors.org/apidocs/group__RF24SettingGrpPub.html
      The defines can be added to the Raspberry Pi gateway by following the instructions on https://www.mysensors.org/build/raspberry#advanced
      I have not heard about anyone using the Cubieboard but hopefully someone else has. The information provided on https://www.mysensors.org/build/orange might be useful if the Cubieboard is similar to the Orange Pie.
      oh, and in case you haven't already, see the ./configure --help text about the most common NRF24 defines; you might not need the advanced build options.
      • А
        А
        Артем ТИхонович
        Thank you, @mfalkvidd. Ihave a little troubles with correct defining gpios from Cubie. In fex file the gpios defines is:
        [gpio_para]
        gpio_used = 1
        gpio_num = 2
        gpio_pin_1 = port:PH07<0><default><default><default>
        gpio_pin_2 = port:PH15<6><default><default><default>
        in sys/gpio:
        [root@Archey boot]# ls -ls /sys/class/gpio/
        total 0
        0 --w------- 1 root root 4096 Nov 21 11:58 export
        0 lrwxrwxrwx 1 root root 0 Nov 18 17:01 gpio1_ph7 -> ../../devices/platform/gpio-sunxi/gpio/gpio1_ph7
        0 lrwxrwxrwx 1 root root 0 Nov 21 11:54 gpio2_ph15 -> ../../devices/platform/gpio-sunxi/gpio/gpio2_ph15
        0 lrwxrwxrwx 1 root root 0 Nov 18 10:45 gpiochip1 -> ../../devices/platform/gpio-sunxi/gpio/gpiochip1
        0 --w------- 1 root root 4096 Nov 18 16:52 unexport
        When i define in configure: --my-rf24-ce-pin=1 --my-rf24-cs-pin=2 build is ok, but test failed with error:
        Nov 21 11:58:15 ERROR Could not open /sys/class/gpio/gpio1/direction[root@Archey MySensors]#
        when i define --my-transport=nrf24 --my-rf24-ce-pin=gpio1_ph7 the build failed wirh error:
        ./drivers/RF24/RF24.cpp: In function 'void RF24_ce(bool)':
        <command-line>:0:16: error: 'gpio1_ph7' was not declared in this scope
        ./drivers/RF24/RF24.cpp:52:17: note: in expansion of macro 'MY_RF24_CE_PIN'
        hwDigitalWrite(MY_RF24_CE_PIN, level);
        How can i resolve this problem? Please help.
        • А
          А
          Артем ТИхонович
          I just see for another app using nrf24 on cubieboard
          and funcrtion to use nrf24 have GPIO defining is RF24 radio(SUNXI_GPB(10), SUNXI_GPB(11), "/dev/spidev0.0");
          GPIO set using this style: SUNXI_GPB(10), this type of gpio defined in #include "gpio_sun4i.h" file. Maybe this specific defining in ARCHLINUX ARM distro.
          • alowhumA
            alowhumA
            alowhum
            I hereby donate these images:
            4_1542918057729_step1.png 3_1542918057729_step2.png 2_1542918057728_step3.png 1_1542918057727_step4.png 0_1542918057727_step5.png
            • А Артем ТИхонович
              In case someone can help @артем-тихонович, please post the answer in https://forum.mysensors.org/post/95304 so we don’t unnecessarily discuss the same thing in separate threads.
              • MasMatM
                MasMatM
                MasMat
                wrote on last edited by MasMat
                #973
                I get weird errors when "make"ing. Branch master.
                My command:
                sudo ./configure --my-transport=rf24 --my-rf24-irq-pin=15 --my-signing-debug --my-signing=password --my-security-password=ZZZZZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-config-file=/etc/mysensors.conf
                M -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                In file included from ./MySensors.h:148:0,
                                 from examples_linux/mysgw.cpp:82:
                ./core/MySigningAtsha204Soft.cpp: In function ‘bool signerAtsha204SoftGetNonce(MyMessage&)’:
                ./core/MySigningAtsha204Soft.cpp:173:55: error: no matching function for call to ‘min(unsigned int, int)’
                  msg.set(_signing_verifying_nonce, MIN(MAX_PAYLOAD, 32));
                In file included from /usr/include/c++/6/algorithm:62:0,
                                 from ./drivers/Linux/Arduino.h:32,
                                 from ./MySensors.h:39,
                /usr/include/c++/6/bits/stl_algo.h:3453:5: note: candidate: template<class _Tp, class _Compare> constexpr _Tp std::min(std::initializer_list<_Tp>, _Compare)
                     min(initializer_list<_Tp> __l, _Compare __comp)
                /usr/include/c++/6/bits/stl_algo.h:3453:5: note:   template argument deduction/substitution failed:
                ./core/MySigningAtsha204Soft.cpp:173:55: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned int’
                /usr/include/c++/6/bits/stl_algo.h:3447:5: note: candidate: template<class _Tp> constexpr _Tp std::min(std::initializer_list<_Tp>)
                     min(initializer_list<_Tp> __l)
                /usr/include/c++/6/bits/stl_algo.h:3447:5: note:   template argument deduction/substitution failed:
                In file included from /usr/include/c++/6/bits/char_traits.h:39:0,
                                 from /usr/include/c++/6/ios:40,
                                 from /usr/include/c++/6/ostream:38,
                                 from /usr/include/c++/6/iostream:39,
                                 from examples_linux/mysgw.cpp:20:
                /usr/include/c++/6/bits/stl_algobase.h:243:5: note: candidate: template<class _Tp, class _Compare> constexpr const _Tp& std::min(const _Tp&, const _Tp&, _Compare)
                     min(const _Tp& __a, const _Tp& __b, _Compare __comp)
                /usr/include/c++/6/bits/stl_algobase.h:243:5: note:   template argument deduction/substitution failed:
                ./core/MySigningAtsha204Soft.cpp:173:55: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned int’ and ‘int’)
                /usr/include/c++/6/bits/stl_algobase.h:195:5: note: candidate: template<class _Tp> constexpr const _Tp& std::min(const _Tp&, const _Tp&)
                     min(const _Tp& __a, const _Tp& __b)
                /usr/include/c++/6/bits/stl_algobase.h:195:5: note:   template argument deduction/substitution failed:
                ./core/MySigningAtsha204Soft.cpp: In function ‘void signerAtsha204SoftPutNonce(MyMessage&)’:
                ./core/MySigningAtsha204Soft.cpp:190:89: error: no matching function for call to ‘min(unsigned int, int)’
                  (void)memcpy((void *)_signing_nonce, (const void *)msg.getCustom(), MIN(MAX_PAYLOAD, 32));
                ./core/MySigningAtsha204Soft.cpp:190:89: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned int’
                ./core/MySigningAtsha204Soft.cpp:190:89: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned int’ and ‘int’)
                ./core/MySigningAtsha204Soft.cpp: In function ‘bool signerAtsha204SoftSignMsg(MyMessage&)’:
                ./core/MySigningAtsha204Soft.cpp:229:50: error: no matching function for call to ‘min(unsigned int, int)’
                               MIN(MAX_PAYLOAD-mGetLength(msg), 32));
                ./core/MySigningAtsha204Soft.cpp:229:50: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned int’
                ./core/MySigningAtsha204Soft.cpp:229:50: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned int’ and ‘int’)
                ./core/MySigningAtsha204Soft.cpp: In function ‘bool signerAtsha204SoftVerifyMsg(MyMessage&)’:
                ./core/MySigningAtsha204Soft.cpp:283:55: error: no matching function for call to ‘min(unsigned int, int)’
                                    MIN(MAX_PAYLOAD-mGetLength(msg), 32))) {
                ./core/MySigningAtsha204Soft.cpp:283:55: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned int’
                ./core/MySigningAtsha204Soft.cpp:283:55: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned int’ and ‘int’)
                ./core/MySigningAtsha204Soft.cpp: In function ‘void signerCalculateSignature(MyMessage&, bool)’:
                ./core/MySigningAtsha204Soft.cpp:307:48: error: no matching function for call to ‘min(uint8_t&, int)’
                   uint8_t bytes_to_include = MIN(bytes_left, 32);
                ./core/MySigningAtsha204Soft.cpp:307:48: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned char’
                ./core/MySigningAtsha204Soft.cpp:307:48: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned char’ and ‘int’)
                ./core/MySigningAtsha204Soft.cpp:289:1: warning: control reaches end of non-void function [-Wreturn-type]
                Can someone better versed help?
                EDIT: tested branch development, no problems.
                • mfalkviddM
                  Could be same as https://forum.mysensors.org/topic/10036/unable-to-compile-raspberry-pi-gateway-when-signing-enable
                  MasMatM 1 Reply Last reply
                    MasMatM
                    MasMatM
                    MasMat
                    #975
                    @mfalkvidd It sure looks the same. I did a fresh git clone to update my gateway, so shouldn't it be fixed? From what appears on github it looked fixed..
                    EDIT appears fixed in development branch. But not master?
                    • MasMatM MasMat
                      Yes that is correct
                      • R
                        R
                        Robert Król
                        hi,
                        is it possible to conect NRF24 to SPI1 channel on RBpi3?
                        (i mean pins 26, 35, 36,38,40)??
                        • R Robert Król
                          hi,
                          #978
                          Welcome to the forum @robert-król
                          I have not tried it myself, but I beleive https://forum.mysensors.org/post/76079 shows how to do it.
                          • B
                            B
                            barrydou
                            wrote on last edited by barrydou
                            #979
                            Hello
                            Is it possible to redefine pin used for DI00 with rfm69 (with configure option for example) ?
                            Indeed, DI00 is on pin 22 on raspberry, and pin 2 on arduino.
                            But with NRF, pin 2 on arduino is for IRQ, which is connected to pin 15 on raspberry.
                            So if it was possible to force pin 15 for DI00, we could use adaptator card like this one https://www.mysensors.org/hardware/nrf2rfm69.
                            gohanG 1 Reply Last reply
                            • R
                              R
                              Rolo6442u
                              Hi, just build an Ethernet gateway on a raspberry pi B+ following the instructions on this site. And it works! I'm running raspbian stretch lite and used the master branch. No issues. I use the RFM69 radio and this gateway has the HW model. I did have to update al my nodes to use the new RFM69 drivers but that was clearly mentioned in the article.
                              I have two questions:
                              1. In this section :
                              log_pipe=0
                              log_pipe_file=/tmp/mysgw.pipe
                              Is this correct, I think there should be a 1 to enable this type of logging.
                              1. When a new version of mysensors is released, how do I update the gateway version on the raspberry pi?
                              And here is a picture of my work:
                              Thanks for the effort you put into this project!
                              • K
                                K
                                kted
                                Has the issue with RFM automatic transmission control been addressed?
                                R 1 Reply Last reply
                                • K kted
                                  R
                                  R
                                  Rolo6442u
                                  wrote on last edited by Rolo6442u
                                  #982
                                  @kted Can you give me a pointer to the details of this issue? I'm willing to do some tests and report back my findings. Some info about my configuration, I have 5 nodes at this moment, all battery feeded, they are sending only nodes. They all work but they have a interval of several minutes between sending. The gateway is connected to Domoticz running on another Raspberry PI.
                                  K 1 Reply Last reply
                                  • R Rolo6442u
                                    K
                                    K
                                    kted
                                    wrote on last edited by kted
                                    #983
                                    @rolo6442u I built an Raspberry gateway using an RFM69 radio, to replace one built around a NodeMCU.
                                    All nodes are transmit only, and using the latest stable API.
                                    I noticed that all sensors were using max TX power after the first couple of transmissions, although they were respecting the ATC setting before, and were using minimum power most of the time.
                                    Now I am concerned about battery life, so I switched back to the NodeMCU gateway, waiting for a fix.
                                    I'll put together a temporary net, with a RPi0 gateway and a single node later, to show some real data, if you need any more information.
                                    R mfalkviddM 2 Replies Last reply
                                    • K kted
                                      R
                                      R
                                      Rolo6442u
                                      #984
                                      @kted I wil do some tests to check if I see this behavior. Just build a simple test node with a pushbutton, on 2 AA batteries. This node has the low power W radio module. How did you discover/measure that the max TX power was used?
                                      • K kted
                                        @kted could be the same problem as discussed in https://forum.mysensors.org/topic/9796/rfm69-atc-not-working/
                                        • R Rolo6442u
                                          K
                                          K
                                          kted
                                          @rolo6442u From what the node itself reports from transportGetSignalReport(SR_TX_POWER_PERCENT). It starts from say 50%, and after a coule of transmissions it goes up to 100%, when the nodes are 1m apart. When using a stand alone ESP8266 gateway, it drops to 0%.
                                          I'll have the nodes ready in a couple of hours, after I come home from work...
