  3. [SOLVED] Ethernet MQTT Gateway Slow to connect
11 Posts 5 Posters 3.6k Views 5 Watching
  • G Offline
    G Offline
    Guillermo Schimmel
    Hi guys.
    I'm using an Arduino Uno + 5100 based MQTT Gateway.
    It's working great with sensors and mqtt but I have a couple if issues that may be related.
    1. It is very slow to connect to the ethernet switch
    2. won't send registration nor info about local sensors.
    Power supply is ok, external regulated 5V + 3v3 reg for nrf. All OK's on the radio front.
    Take a look at the startup log:
     MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    17 MCO:REG:NOT NEEDED
    580 GWT:TPC:IP=192.168.1.200
    1583 MCO:BGN:STP
    1585 MCO:BGN:INIT OK,TSP=1
    1587 GWT:TPC:IP=192.168.1.200
    2590 GWT:RMQ:MQTT RECONNECT
    3594 TSM:READY:NWD REQ
    3631 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    3638 TSF:MSG:READ,11-11-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
    3645 GWT:TPC:IP=192.168.1.200
    4647 GWT:RMQ:MQTT RECONNECT
    5652 TSF:MSG:READ,0-11-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    5657 TSF:MSG:BC
    5659 TSF:MSG:READ,2-2-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
    5664 TSF:MSG:READ,0-2-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    5669 TSF:MSG:BC
    5671 GWT:TPC:IP=192.168.1.200
    6674 GWT:RMQ:MQTT RECONNECT
    7678 GWT:TPC:IP=192.168.1.200
    8681 GWT:RMQ:MQTT RECONNECT
    9687 GWT:TPC:IP=192.168.1.200
    10690 GWT:RMQ:MQTT RECONNECT
    11695 GWT:TPC:IP=192.168.1.200
    12697 GWT:RMQ:MQTT RECONNECT
    13702 GWT:TPC:IP=192.168.1.200
    14704 GWT:RMQ:MQTT RECONNECT
    15710 GWT:TPC:IP=192.168.1.200
    16713 GWT:RMQ:MQTT RECONNECT
    17717 GWT:TPC:IP=192.168.1.200
    18720 GWT:RMQ:MQTT RECONNECT
    19725 GWT:TPC:IP=192.168.1.200
    20727 GWT:RMQ:MQTT RECONNECT
    21733 GWT:TPC:IP=192.168.1.200
    22736 GWT:RMQ:MQTT RECONNECT
    23741 GWT:TPC:IP=192.168.1.200
    24743 GWT:RMQ:MQTT RECONNECT
    25749 GWT:TPC:IP=192.168.1.200
    26752 GWT:RMQ:MQTT RECONNECT
    27758 GWT:TPC:IP=192.168.1.200
    28762 GWT:RMQ:MQTT RECONNECT
    29767 GWT:TPC:IP=192.168.1.200
    30770 GWT:RMQ:MQTT RECONNECT
    30777 GWT:RMQ:MQTT CONNECTED
    Only then, it starts working ok.
    When in that MQTT Reconnect, it is not responding any pings. As soon as it gets the ethernet connection running, it connects to the broker at the first attempt.
    It is directly connected to a Cisco switch. I tried everything, auto/auto, 10/full, 100/full. Any ethernet combo it's the same.
    This is the complete sketch:
    #define MY_RADIO_RF24
    #define MY_RF24_CHANNEL 110
    // modulo con amplificador, por ahi recomiendan bajarle la potencia (?)
    // Set MQTT client id
    // descomentó guille
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable these if your MQTT broker requires username/password
    #define MY_IP_ADDRESS 192,168,1,200
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1,2
    #define MY_PORT 8884
      // Enable inclusion mode
      // Set blinking period
      // Flash leds on rx/tx/err
    #include <Ethernet.h>
    // Temperatura
    #include <OneWire.h>
    #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected
    int numSensors=0;
    MyMessage msg(0,V_TEMP);
      // temperatura
        sendSketchInfo("Gateway node with temp", "1.0");
         present(1, S_TEMP);
      wait(conversionTime);
        #if COMPARE_TEMP == 1
    // Estudiar un poco esto. Le pongo algo para que no esté midiendo
    // permanentemente
      wait(1000);
    I'm on 2.3.1
    The main issue here is the failure to use local sensors, but a faster startup time would also be great.
    Thanks in advance for any tip.
    Guillermo
    Y 1 Reply Last reply
    • electrikE Offline
      electrikE Offline
      electrik
      I'm not using a wired connection, but had many connection issues also. It took long time before the gateway was up, MQTT connections dropped.
      Then I replaced my router (the one delivered by the cable supplier) and I have no issues anymore. So that could be worth a try.
      G 1 Reply Last reply
      • G Guillermo Schimmel
        Hi guys.
        4 TSM:INIT
        5 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSM:INIT:GW MODE
        1583 MCO:BGN:STP
        5657 TSF:MSG:BC
        5669 TSF:MSG:BC
        #define MY_SOFTSPI
        // Temperatura
        int numSensors=0;
          // temperatura
             present(1, S_TEMP);
        // permanentemente
          wait(1000);
        I'm on 2.3.1
        Guillermo
        Y Offline
        Y Offline
        @guillermo-schimmel shot in the dark: make sure your Mac ID is unique on your network, or switches will get very confused
        • electrikE electrik
          G Offline
          G Offline
          Guillermo Schimmel
          @electrik said in Ethernet MQTT Gateway Slow to connect:
          Thanks for the help. I'm on a wired connection. And the network element are of great quality. I think there is a delay in ethernet.connect() but can't find it.
            @guillermo-schimmel wouldn't it be a bit surprising if there is a delay that is only active on your system?
            • Y Yveaux
              G Offline
              G Offline
              Guillermo Schimmel
              @yveaux said in Ethernet MQTT Gateway Slow to connect:
              Thank you for the suggestion. This is one of the lines I'm investigating.
                192.168.1.200         de-ad-be-ef-fe-ed     dynamic
              At the moment it seems to be some standard arduino joke, but at least is unique in the network.
                G Offline
                G Offline
                Guillermo Schimmel
                @mfalkvidd said in Ethernet MQTT Gateway Slow to connect:
                Sure. I'm not meaning that. Sometimes not being an english speaker is tough.
                I mean that some combination of settings that I may have done (wrongly?) perhaps generated that delay.
                  @guillermo-schimmel I see. Thanks for explaining.
                  Which ethernet implementation are you using? (depends on which libraries are installed in your IDE)
                  To check, turn on "Show verbose output" in Arduino IDE preferences. Then compile the sketch. At the end, something like this will be shown:
                  Using library Ethernet at version 2.0.0 in folder: C:\Program Files (x86)\Arduino\libraries\Ethernet
                  Using library MySensors at version 2.3.2-alpha in folder: R:\Documents\Arduino\libraries\MySensors
                  Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                  In my implementation, there is a 560ms delay at init, in src/utility/w5100.cpp. It should only happen once though, so it should not be responsible for a 30 second delay. You could uncomment the Serial.println to verify.
                  // Many Ethernet shields have a CAT811 or similar reset chip
                  // connected to W5100 or W5200 chips.  The W5200 will not work at
                  // all, and may even drive its MISO pin, until given an active low
                  // reset pulse!  The CAT811 has a 240 ms typical pulse length, and
                  // a 400 ms worst case maximum pulse length.  MAX811 has a worst
                  // case maximum 560 ms pulse length.  This delay is meant to wait
                  // until the reset pulse is ended.  If your hardware has a shorter
                  // reset time, this can be edited or removed.
                  delay(560);
                  //Serial.println("w5100 init");
                  There are quite a few Serial.println in this file. Activating them all for debugging purposes might be useful.
                  There are 50ms delays in src/Dhcp.cpp and src/Dns.cpp but since you're using fixed IP and no domain names, they should not be used. You could add Serial.println statements before/after them to verify.
                    delay(560);
                    G Offline
                    G Offline
                    Guillermo Schimmel
                    @mfalkvidd Thanks for the tips
                    I did all that
                    0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
                    4 TSM:INIT
                    5 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    13 TSM:INIT:GW MODE
                    w5100 init
                    w5100.cpp: detect W5200 chip
                    Wiznet soft reset
                    mr=0
                    w5100.cpp: detect W5500 chip
                    Wiznet soft reset
                    mr=0
                    w5100.cpp: detect W5100 chip
                    Wiznet soft reset
                    mr=0
                    chip is W5100
                    590 GWT:TPC:IP=192.168.1.200
                    1598 MCO:BGN:STP
                    1600 MCO:BGN:INIT OK,TSP=1
                    1603 GWT:TPC:IP=192.168.1.200
                    2606 GWT:RMQ:MQTT RECONNECT
                    3610 TSM:READY:NWD REQ
                    3647 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                    3656 GWT:TPC:IP=192.168.1.200
                    4660 GWT:RMQ:MQTT RECONNECT
                    5664 TSF:MSG:READ,2-2-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                    5669 TSF:MSG:READ,0-2-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                    5675 TSF:MSG:BC
                    5677 TSF:MSG:READ,11-11-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                    New temp:
                    29.19
                    5709 GWT:TPC:IP=192.168.1.200
                    7717 TSF:MSG:READ,10-2-0,s=1,c=1,t=13,pt=2,l=2,sg=0:48
                    7723 GWT:TPC:IP=192.168.1.200
                    8726 GWT:RMQ:MQTT RECONNECT
                    9732 GWT:TPC:IP=192.168.1.200
                    10735 GWT:RMQ:MQTT RECONNECT
                    11766 GWT:TPC:IP=192.168.1.200
                    12769 GWT:RMQ:MQTT RECONNECT
                    13774 GWT:TPC:IP=192.168.1.200
                    14777 GWT:RMQ:MQTT RECONNECT
                    15783 GWT:TPC:IP=192.168.1.200
                    16786 GWT:RMQ:MQTT RECONNECT
                    17819 GWT:TPC:IP=192.168.1.200
                    18822 GWT:RMQ:MQTT RECONNECT
                    19827 TSF:MSG:READ,10-2-0,s=1,c=1,t=13,pt=2,l=2,sg=0:47
                    19832 TSF:MSG:READ,10-2-0,s=2,c=1,t=0,pt=7,l=5,sg=0:27.62
                    19837 GWT:TPC:IP=192.168.1.200
                    20841 GWT:RMQ:MQTT RECONNECT
                    21849 GWT:TPC:IP=192.168.1.200
                    22851 GWT:RMQ:MQTT RECONNECT
                    23882 GWT:TPC:IP=192.168.1.200
                    24885 GWT:RMQ:MQTT RECONNECT
                    25890 GWT:TPC:IP=192.168.1.200
                    26894 GWT:RMQ:MQTT RECONNECT
                    27901 GWT:TPC:IP=192.168.1.200
                    28904 GWT:RMQ:MQTT RECONNECT
                    29910 TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:62.6
                    29941 GWT:TPC:IP=192.168.1.200
                    30945 GWT:RMQ:MQTT RECONNECT
                    31160 GWT:RMQ:MQTT CONNECTED
                    It seems to detect quickly the w5100 and then the delay is elsewhere.
                    I will try to do the same on some other modules. Perhaps the speed and duplex negotiation.
                      I did all that
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSM:INIT:GW MODE
                      w5100 init
                      Wiznet soft reset
                      mr=0
                      Wiznet soft reset
                      mr=0
                      Wiznet soft reset
                      mr=0
                      chip is W5100
                      1598 MCO:BGN:STP
                      5675 TSF:MSG:BC
                      New temp:
                      29.19
                      G Offline
                      G Offline
                      Guillermo Schimmel
                      @guillermo-schimmel Well, solved.
                      Good brands not means good quality.
                      Replaced my Cisco switch for a unbranded one:
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSM:INIT:GW MODE
                      w5100 init
                      Wiznet soft reset
                      mr=0
                      Wiznet soft reset
                      mr=0
                      Wiznet soft reset
                      mr=0
                      chip is W5100
                      1598 MCO:BGN:STP
                      2615 GWT:RMQ:MQTT CONNECTED
                      Connected at the first attempt.
                      Thank you guys a lot for your time.
                      • L Offline
                        L Offline
                        linkinpio
                        Hi @Guillermo-Schimmel,
                        I know it's closed but just noticed this issue, you most probably had STP (Spanning Tree Protocol) enabled on that port, which is normal for ent switch, and while it waits for a loop it blocks trafic from that port.
                        Disabling that feature should solve this problem.
