  3. MKR1000 gateway problem
8 Posts 3 Posters 920 Views 3 Watching
  • Z Offline
    Z Offline
    ziovic
    Hello all,
    I have a problem with a serial gateway based on a MKR1000 compatible board ( Dustino ).
    It inits properly and receives message from a test node equipped with a BMP180 sensor. The problem is that the sensor value ( both humidity and temperature ) are always zero. The node is sending correct values, as shown in the serial terminal, and if I connect another gateway based on an Arduino uno board I receive correct values.
    I have logs of the node, the Arduino Uno gateway and the MKR1000 gateway if needed.
    Any ideas?
    Thank you,
    Vittorio
    • Z ziovic
      Hello all,
      Any ideas?
      Thank you,
      Vittorio
      Hi @ziovic, welcome to the MySensors forum.
      The debug log from node + gateway and the sketch would be useful, yes.
      • Z Offline
        Z Offline
        ziovic
        thanks for your answer.
        Here follow the three logs. As an additional information I have also connected a node with a relay and I can properly switch the state with the SAMD Gateway. It looks like a parsing problem to me.
        Node log from serial console:
        0 NM:INIT:VER=1.8
        0 NM:INIT:INO=NodeManager v1.0
        0 NM:INIT:LIB VER=2.3.1 CP=RNNNA---
        0 NM:INIT:RBT p=255
        20 NM:BFR:INIT
        2184 NM:BFR:OK
        2203 NM:PRES:BMP180(1) p=6 t=0
        2238 NM:PRES:BMP180(2) p=8 t=4
        2275 NM:PRES:BMP180(3) p=8 t=5
        2335 NM:STP:ID=110 M=1
        2360 NM:SENS:BMP180:I2C a=0x77
        2471 NM:STP:HW V=4892 F=17 M=1076
        2513 NM:LOOP:BMP180(1):SET t=0 v=17.60
        2588 NM:LOOP:BMP180(2):SET t=4 v=985.-57
        2665 NM:LOOP:BMP180(3):SET t=5 v=stable```
        Working Arduino nano Gateway log:
        0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
        0;255;3;0;9;8 TSM:INIT
        0;255;3;0;9;12 TSF:WUR:MS=0
        0;255;3;0;9;23 TSM:INIT:TSP OK
        0;255;3;0;9;28 TSM:INIT:GW MODE
        0;255;3;0;9;34 TSM:READY:ID=0,PAR=0,DIS=0
        0;255;3;0;9;41 MCO:REG:NOT NEEDED
        0;255;0;0;18;2.2.0
        0;255;3;0;9;49 MCO:BGN:STP
        0;255;3;0;9;62 MCO:BGN:INIT OK,TSP=1
        0;255;3;0;9;8285 TSF:MSG:READ,110-110-0,s=1,c=1,t=0,pt=7,l=5,sg=0:17.80
        110;1;1;0;0;17.80
        0;255;3;0;9;8298 TSF:MSG:READ,110-110-0,s=2,c=1,t=4,pt=7,l=5,sg=0:985.11
        110;2;1;0;4;985.11
        0;255;3;0;9;8313 TSF:MSG:READ,110-110-0,s=3,c=1,t=5,pt=0,l=6,sg=0:stable
        110;3;1;0;5;stable```
        SAMD faulty Gateway log:
        0;255;3;0;9;120220 MCO:BGN:INIT GW,CP=RNNGS---,REL=255,VER=2.3.1
        0;255;3;0;9;120230 TSF:LRT:OK
        0;255;3;0;9;120240 TSM:INIT
        0;255;3;0;9;120250 TSF:WUR:MS=0
        0;255;3;0;9;120265 TSM:INIT:TSP OK
        0;255;3;0;9;120275 TSM:INIT:GW MODE
        0;255;3;0;9;120285 TSM:READY:ID=0,PAR=0,DIS=0
        0;255;3;0;9;120295 MCO:REG:NOT NEEDED
        0;255;0;0;18;2.3.1
        0;255;3;0;9;120305 MCO:BGN:STP
        0;255;3;0;9;120315 MCO:BGN:INIT OK,TSP=1
        0;255;3;0;9;120325 TSM:READY:NWD REQ
        0;255;3;0;9;120370 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        0;255;3;0;9;127494 TSF:MSG:READ,110-110-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;127504 TSF:MSG:BC
        0;255;3;0;9;127514 TSF:MSG:FPAR REQ,ID=110
        0;255;3;0;9;127524 TSF:PNG:SEND,TO=0
        0;255;3;0;9;127534 TSF:CKU:OK
        0;255;3;0;9;127544 TSF:MSG:GWL OK
        0;255;3;0;9;128123 TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        0;255;3;0;9;129530 TSF:MSG:READ,110-110-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        0;255;3;0;9;129540 TSF:MSG:PINGED,ID=110,HP=1
        0;255;3;0;9;129556 TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        0;255;3;0;9;129566 TSF:MSG:READ,110-110-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        0;255;3;0;9;129578 TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        0;255;3;0;9;129588 TSF:MSG:READ,110-110-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.1
        110;255;0;0;17;2.3.1
        0;255;3;0;9;129598 TSF:MSG:READ,110-110-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
        110;255;3;0;6;0
        0;255;3;0;9;131600 TSF:MSG:READ,110-110-0,s=255,c=3,t=11,pt=0,l=11,sg=0:NodeManager
        110;255;3;0;11;NodeManager
        0;255;3;0;9;131611 TSF:MSG:READ,110-110-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        110;255;3;0;12;1.0
        0;255;3;0;9;131637 TSF:MSG:READ,110-110-0,s=1,c=0,t=6,pt=0,l=6,sg=0:BMP180
        110;1;0;0;6;BMP180
        0;255;3;0;9;131673 TSF:MSG:READ,110-110-0,s=2,c=0,t=8,pt=0,l=6,sg=0:BMP180
        110;2;0;0;8;BMP180
        0;255;3;0;9;131708 TSF:MSG:READ,110-110-0,s=3,c=0,t=8,pt=0,l=6,sg=0:BMP180
        110;3;0;0;8;BMP180
        0;255;3;0;9;131718 TSF:MSG:READ,110-110-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        0;255;3;0;9;131734 TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
        0;255;3;0;9;132646 TSF:MSG:READ,110-110-0,s=1,c=1,t=0,pt=7,l=5,sg=0:0.00
        110;1;1;0;0;0.00
        0;255;3;0;9;132657 TSF:MSG:READ,110-110-0,s=2,c=1,t=4,pt=7,l=5,sg=0:0.00
        110;2;1;0;4;0.00
        0;255;3;0;9;132668 TSF:MSG:READ,110-110-0,s=3,c=1,t=5,pt=0,l=6,sg=0:stable
        Vittorio
        • Z Offline
          Z Offline
          ziovic
          Sorry for the mistake, I repost the Arduino nano gatewaylog:
          0;255;0;0;18;2.2.0
          110;1;1;0;0;17.80
          110;2;1;0;4;985.11
          110;3;1;0;5;stable
          • Z Offline
            Z Offline
            ziovic
            The sketches are the serialGateway example with no modification, and the node manager template with the BMP180 lines uncommented.
            • Z ziovic
              Thanks for the updates @ziovic
              I am not familiar with NodeManager, but hopefully someone else can assist.
              • Z Offline
                Z Offline
                ziovic
                it seems I found the problem:
                The dtostrf function included in MyHwSAMD.h is the AVR one ( avr/dtostrf.h) does not work with SAMD core.
                I found a working replacement here: https://forum.arduino.cc/index.php?topic=368720.0
                and the SAMD board Gateway is now working properly.
                Thanks for your help,
                Ciao,
                Vittorio
                • Z ziovic
                  Ciao,
                  Vittorio
                  YveauxY Offline
                  YveauxY Offline
                  @ziovic said in MKR1000 gateway problem:
                  Well, this implementation is part of the official arduino Samd core: https://github.com/arduino/ArduinoCore-samd/blob/master/cores/arduino/avr/dtostrf.c
                  You could file a bug report there if you like.
                  11.8k
                  113.2k
