  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 809.5k Views 27 Watching
  • andrewA andrew
    @neverdie what was the cost for the overall upgrade?
    for me the 10 mil traces also worked with the default sw/hw configuration.
    did you change any parameter in the grbl firmware? 1400 feedrate is very nice, much faster than mine, however I did not use higher rates than 200 so far.
    your steppers are still the same? is it ok for the high feedrate without any issue?
    #719
    The spindle I'm currently using cost $34:
    https://www.aliexpress.com/item/BEST-300W-Mini-Spindle-motor-DC12-48V-ER11-12000rpm-Engraving-milling-grind-air-cooling-spindle-motor/32799767627.html?spm=a2g0s.9042311.0.0.27424c4dQrDJU8
    I power it with a separate, adjustable power supply, since it can go to 48v.
    I had to 3D print an adapter for the new spindle to fit onto the 2418. Cottingbear has one on thingiverse. Aside from the plastic filament needed for the print (maybe $2 worth), it requires just 4 short linear bearings and a lead nut.
    The 6 chromed steel smooth rods cost around $20-30 in total, including e-packet delivery.
    My feeling is that the steel rods are a worthwhile and very easy upgrade, even though I don't have data to prove they make any difference. Not sure yet whether the new spindle will eventually produce better results or not, although it does run quieter, which is nice. :)
    The yet to be used trinamic drivers cost $42.50: https://www.aliexpress.com/item/5X-MKS-TMC2130-V1-1-For-SPI-Function-Stepstick-Stepper-Motor-Driver-With-Heat-Sink-5PCS/32850180071.html?spm=a2g0s.9042311.0.0.27424c4ddQiQqN
    I got a couple extra in case I accidentally burn one or two of them out. I'll be plugging them into a RAMPS board, which is cheap, and which, as an arduino Mega 2560 shield, will replace the woodpecker board.
    dbemowskD 1 Reply Last reply
      dbemowskD
      dbemowskD
      @neverdie Can you run a stock GRBL build on RAMPS?
      • dbemowskD dbemowsk
        #721
        I don't know. I'm planning to use Marlin, which supposedly can exploit at least some of the TMC2130 driver's special features.
        After I get all that working, then I may upgrade to higher torque stepper drivers, still NEMA 17 though, as the trinamics can support more current than the A4988's that are on the woodpecker.
          I found out that I can buy precision rods and matching linear bearings directly from https://us.misumi-ec.com. Because of the tighter fit, this would, I'm guessing, reduce the deflection on the x-axis.
          • jeremushkaJ
            jeremushkaJ
            jeremushka
            By checking this discussion i have found a project online called: pcb cyclone factory. I am novice. What do you think about it ?
            https://reprap.org/wiki/Cyclone_PCB_Factory
            • jeremushkaJ jeremushka
              @jeremushka Looks like it might be kinda shakey. Vibration is a notable enemy.
              jeremushkaJ 1 Reply Last reply
                jeremushkaJ
                jeremushkaJ
                jeremushka
                @neverdie yes you are right. I have found a more complete machine. Seems we can use not only for milling. Can be interesting as well. What do you think ?
                https://www.banggood.com/2417-3-Axis-Mini-DIY-CNC-Router-Wood-Craving-Engraving-Cutting-Milling-Desktop-Engraver-Machine-240x170x65mm-p-1209292.html?utm_source=youtube&utm_medium=CreativeChannel&utm_campaign=July&utm_content=huangwenjie&cur_warehouse=CN
                  Looks no worse than what I have .
                  • L
                    L
                    lamikr
                    I would like to create pcb's with a 0.5mm pitch as a target and I have tried to follow this thread for hints. Have you @andrew, @NeverDie or @executivul been able to get that done with the milling method?
                    Then one of the problems with the 2418 that @NeverDie seemed to have was that the machine itself was not stable enough. Do you think that the cheap 3018 work better? For example
                    https://www.aliexpress.com/store/product/CNC-3018-laser-options-with-ER11-diy-cnc-engraving-machine-Pcb-Milling-Machine-Wood-Carving-machine/424291_32806004900.html
                    or
                    https://www.amazon.com/Control-Machine-Engraver-Controller-Extension/dp/B07KYH6BTK/ref=sr_1_6?ie=UTF8&qid=1548751586&sr=8-6&keywords=cnc+3018
                    andrewA 1 Reply Last reply
                    • L lamikr
                      or
                      andrewA
                      andrewA
                      andrew
                      @lamikr pls see one of my very first test I made after I built my cnc. check the TQFP100 footprint.
                      for me, the cnc2418 was good choice. with proper assembly it is very stable and its output is stable.
                      I was using the cnc for designs down to 10mil traces without any issue.
                      so, I have good experience with my low cost cnc but do to the lack of hands-on experience with other devices, I cannot compare or recommend others.
                      • D
                        dennisc
                        Hi everyone,
                        can someone help me pick out what to order from amazon.de?
                        I would like to order a 3018 pro, but which one?
                        What drilling bits would I need to order to mill PCB?
                        Any help much appreciated!!
                        • D dennisc
                          Hi everyone,
                          sundberg84S
                          sundberg84S
                          @dennisc - I think its a matter of taste and preference, but there is 728 posts in this thread, many describing the pro and cons with different drillbits and mashines. Since its DIY its very hard to tell exactly what to pick - atleast for me - but lets see if someone else is bolder.
                          • sundberg84S sundberg84
                            dennisc
                            @sundberg84
                            I know there are so many posts!
                            I am under a bit of time pressure and can't wait for aliexpress or bang good, so I was hoping somebody just ordered something off amazon. (and I could copy that).
                            I am interested in the 3018 Pro, that on looks good enough price wise at least. But maybe had an experience with Sainsmart or something else.
                            Other important reason is that there have not been many posts in the last months in this thread.
                            • D
                              dennisc
                              I have bought a 3018 Pro and put it together today.
                              I'm now trying to find out how to calibrate it, any tips would be awesome!
                              Im using GBRL control.
                              thanks!
                              • D
                                dennisc
                                wrote on last edited by dennisc
                                #733
                                Ok calibration was quite easy.
                                I managed to get the x, y and z axis zeroed. Only thing I am wondering is this:
                                I can see my file goes 0.2 mm deep. Is there a button to alter the offset?
                                I found I had to do all kind of fake zeroing to get it deeper!
                                L 1 Reply Last reply
                                • D dennisc
                                  L
                                  L
                                  lamikr
                                  @dennisc I have myself ordered the 2418 from the Jack's store.
                                  I also ordered the parts for Ant's team's PCB machine based on the BOM on
                                  https://bitbucket.org/compactpcbmaker/cpcbm/src/master
                                  It will be intersted in for comparing these two and I think money will not be wasted as other one could in the end anyway be used for drilling if other one does the route milling.
                                  Another thing I am wondering how this will compare to Eleksmaker A3 with 405nm laser and Marco Reps modifications.
                                  https://www.youtube.com/watch?v=ZzO9skEYqwY
                                  Laser is interesting due to it's accuracy but I am worried from the reflected beams. I have only found out so classes for protecting from the beam but would rather like to see a full box made from proper shielding material on top of the Eleksmaker.
                                  Fourths interesting thing is the openpnp based pasta dispenser and pick and place machine.
                                  https://hackaday.io/project/165743-foxbuild-pnp
                                  https://mcuoneclipse.com/2018/06/26/building-a-diy-smt-pickplace-machine-with-openpnp/
                                  • L lamikr
                                    dbemowskD
                                    dbemowskD
                                    @lamikr said in CNC PCB milling:
                                    I made an enclosure for my 3D printer in which I had a plexiglass panel for the door. Not long ago I made a mod for my 3D printer that allows me to change to different tool heads. https://www.thingiverse.com/thing:3407486
                                    One of the tools is a 6 watt laser module. I got a piece of this to replace the plexiglass on the door of my enclosure. It is rated for the wavelength of my laser module which is 450nm. https://jtechphotonics.com/?product=445nm-laser-shielding This might be a bit small if you wanted to make a complete cover made out of this stuff though.
                                      L
                                      L
                                      lamikr
                                      @dbemowsk Thanks for the shielding material tip, I may buy it later if starting to work with 0.5w 405nm laser for engraving. (Some safe enclosure definetly needed)
                                      In the meantime I have not constructed my CNC 2418 from Jack's store and tested that I can control it by seding the g-gode commands from terminal. I have not yet tried to workflow from Kicad, to flatcam and from there to bCNC.
                                      Original GRBL firmware was 0.9j but I managed to upgrade it to v1.1h over USP without need for using another arduino as a ISP programmer and wiring it to woodpecker. Arduino-ide did not detect the board automatically but the flashing to grbl 1.1h worked with a following command out of the box on my linux by using a following avrdude command:
                                      avrdude -v -C/etc/avrdude/avrdude.conf -pm328p -carduino -P /dev/ttyUSB0 -D -Uflash:w:grbl_v1.1h.20190825.hex
                                      This thread is so long that it takes lot of time to try to find all important steps. But what I have gathered is that 3 most important things that I am still missing before trying to mill are the
                                      1. auto leveling
                                        What I read, this should be easy with gBNC. Mostly connect one wire from the drilling bit to A5 pin in woodpecker and another from woodpecker's ground to pcb.
                                      2. Current adjustment for all three A4988 motors.
                                        If I understood correctly @andrew and @NeverDie both changed that from 0.6A to 0.9A? Can that be done only by rotating the potentiometer on a4988 driver boards or do I also need to add some resistors?
                                      3. End stops modules? Could them be connected somehow to woodpecker?
                                        #737
                                        Looks like the price on more precise equipment has come down:
                                        https://www.aliexpress.com/item/32889386703.html?spm=a2g0o.detail.1000014.25.50f15e323iLiE4&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.13338.141931.0&scm_id=1007.13338.141931.0&scm-url=1007.13338.141931.0&pvid=6d201006-5b15-41db-bc2e-2f9421010139
                                        Either this or a more classic mill setup is probably the most cost effective for cutting pcbs more accurately. It's the twisting slop that most limits my current CNC's PCB fidelity.
                                          #738
                                          On my previous attempts, I wasn't aware there existed any options for milling PCB's beyond just v-bits. Now it seems that there's quite a range of actual end-mill bits in diameters as narrow as 0.05mm!
                                          https://youtu.be/MaErWEukcGI
                                          They look like this:
                                          From what I've read, when using end mills with less than 100 micron cutting diameters, it's recommended to do step cutting, due to the delicate nature of the bit. That's fine with me: once I set up the machine with a PCB blank, I can walk away and come back when it's done.
                                          Anyone tried using end mill bits like these for milling PCB's, and if so, how do they compare?
