  2. Bug Reports
  3. NRF51-52 PA not support ???
17 Posts 6 Posters 3.6k Views 5 Watching
  • berkseoB Offline
    berkseoB Offline
    berkseo
    Hello, everyone. Today I tried to connect the module nRF52 PA. Module to work, but had a standard transmission\reception. The module includes a chip 2401С. As I understand it, the work modules nRF51-52 with PA is not implemented in the library as unconnected pins 20 and 24(the scheme). On the forum NORDIK found(for softdevice):
    #ifdef APP_PA_LAN
        pa_lna_assist(24,20);//Pin 0.24 and pin 0.20
    #ifdef APP_PA_LAN
    static void pa_lna_assist(uint32_t gpio_pa_pin, uint32_t gpio_lna_pin)
        ret_code_t err_code;
        nrf_gpio_cfg_output(gpio_pa_pin);
        nrf_gpio_pin_clear(gpio_pa_pin); //
        nrf_gpio_cfg_output(gpio_lna_pin);
        nrf_gpio_pin_clear(gpio_lna_pin); //
        static const uint32_t gpio_toggle_ch = 0;
        static const uint32_t ppi_set_ch = 0;
        static const uint32_t ppi_clr_ch = 1;
        // Configure SoftDevice PA/LNA assist
        static ble_opt_t opt;
        memset(&opt, 0, sizeof(ble_opt_t));
        // Common PA/LNA config
        opt.common_opt.pa_lna.gpiote_ch_id  = gpio_toggle_ch;        // GPIOTE channel
        opt.common_opt.pa_lna.ppi_ch_id_clr = ppi_clr_ch;            // PPI channel for pin clearing
        opt.common_opt.pa_lna.ppi_ch_id_set = ppi_set_ch;            // PPI channel for pin setting
        // PA config
        opt.common_opt.pa_lna.pa_cfg.active_high = 1;                // Set the pin to be active high
        opt.common_opt.pa_lna.pa_cfg.enable      = 1;                // Enable toggling
        opt.common_opt.pa_lna.pa_cfg.gpio_pin    = gpio_pa_pin;      // The GPIO pin to toggle
        // LNA config
        opt.common_opt.pa_lna.lna_cfg.active_high  = 1;              // Set the pin to be active high
        opt.common_opt.pa_lna.lna_cfg.enable       = 1;              // Enable toggling
        opt.common_opt.pa_lna.lna_cfg.gpio_pin     = gpio_lna_pin;   // The GPIO pin to toggle
        err_code = sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, &opt);
        APP_ERROR_CHECK(err_code);
    diagram of the module:
    https://ru.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-module-bluetooth-low-energy-PA-cer/420533_32863558179.html?spm=a2g0v.12010612.8148356.33.1701caa2z0YpG4
    What to do? Help!!!
    orhanyorO 1 Reply Last reply
    • berkseoB Offline
      berkseoB Offline
      berkseo
      https://devzone.nordicsemi.com/b/blog/posts/pa-lna-support-in-s132
      • mfalkviddM Offline
        Seems consistent with another user’s experience: https://github.com/mysensors/MySensors/issues/1265
        berkseoB 1 Reply Last reply
        • berkseoB Offline
          berkseoB Offline
          berkseo
          https://youtu.be/--Wcic833jQ
          • berkseoB Offline
            berkseoB Offline
            berkseo
            https://youtu.be/3_GeKqD8ocY
              berkseoB Offline
              berkseoB Offline
              berkseo
              @mfalkvidd This is about another (levels MY_NRF5_ESB_PA_LEVEL). I had another problem, the signal amplification on the module with the 2401c chip did not work. But I somehow forced the module to increase the range :) The chips nFR51-52 no pins VDD_PA....
              • J Offline
                J Offline
                Jokgi
                wrote on last edited by Jokgi
                I see two issues with this schematic. 1) The Cap C3 looks like it says 100nf. In the non-amplified use, this should be at least 4.7uF. If you are using a PA I would suggest a even larger value be used.
                PO.25 and PO.26 if not used should be tied to ground. If used then they should each have a 12pF cap to ground. The internal bonding wires on the QFN package picks up some stray RF and will probably not pass any agency testing in Korea or Japan. This is probably not that important for personal use. 0_1551034598786_c96f8854-1f40-40f7-8632-1c923ea4f493-image.png
                • J Jokgi
                  berkseoB Offline
                  berkseoB Offline
                  berkseo
                  @jokgi I don't know what you mean. I'm not at all sure that your recommendations would be enough, I have a completely different solution. It is exclusively software. Maybe you can explain ...more details? where this scheme? С3 is understandable. Why should 25 and 26 be be tied to ground (if not used)? But none the less thank you for your interest in the topic and your comment. Now I have radio module with amplifier works, until tested on 200 metres, all normally, consumption in transfer 16mA. The problem is that the mysensors library offers no solution for amplified radio modules. Pins 20 and 24 are used as GPIOs. There is no #def available to initialize pins as TX RX gain controls. For myself, I did it, it is quite simple, but nevertheless. ...A more subtle approach is needed to make changes to the library.
                  • berkseoB Offline
                    berkseoB Offline
                    berkseo
                    Hi, everybody. Modules nRF5 with RFX2401(signal amplifier) control the amplifier from the legs of the microcontroller, as a rule, r0.20 and P0.24.
                    Do I understand correctly that gain control is not implemented in mysensors for nRF5 modules with amplifiers???
                    It probably can be done from the sketch, including a strengthening of the:
                    digitalWrite(TXEN_PIN, high);
                    digitalWrite(RXEN_PIN, high);
                    send.(..
                    digitalWrite(TXEN_PIN, low);
                    wait.(..
                    digitalWrite(RXEN_PIN, low);
                    But there is also internal communication (which is formed inside, for example - find parent, registration..), the functionality of the repeater, how it should be?
                    • berkseoB Offline
                      berkseoB Offline
                      berkseo
                      • S Offline
                        @berkseo
                        I think it might be simple, and you might just have to add your digitalwrites to nrf5 driver, then you can PR on git if you want. team's busy for the moment, but if you don't PR, we'll do it, when more time.
                        • berkseoB berkseo
                          #ifdef APP_PA_LAN
                          #ifdef APP_PA_LAN
                              // PA config
                              // LNA config
                          What to do? Help!!!
                          orhanyorO Offline
                          orhanyorO Offline
                          orhanyor
                          wrote on last edited by orhanyor
                          @berkseo sorry for reviving an old topic but i will try something similar with nrf52840 and rfx2401C. Did you able to work it out with the code you provided. I dont have the module but i placed that code in the sketch and it compiled so im not sure if it is going to work. how did it work out for you?
                          • berkseoB Offline
                            berkseoB Offline
                            berkseo
                            I can't win the battle against nRF5 radio modules with amplifiers. Added a foot control to the radio driver for switching PA LNA. This works, but if you try to get bool send (), it very often returns false, although the message is successfully delivered to the recipient, I tried changing the value in NRF5_ESB_RAMP_UP_TIME, it does not help. Someone tried to achieve normal operation of nRF5 radio modules with amplifiers in Mysensors?
                            • berkseoB berkseo
                              @berkseo the return value of send() indicates whether the sending node received an acknowledgement from the next node. If the next node (the gateway unless you have repeaters) received the message and send() still returns false, it usually means that the acknowledgement was lost.
                              Maybe the PA makes it possible for the sending node to reach the gateway, but the gateway is unable to reach the sending node?
                                berkseoB Offline
                                berkseoB Offline
                                berkseo
                                @mfalkvidd said in NRF51-52 PA not support ???:
                                The network is simple, this node is nrf52 with an amplifier and a gateway with the nrf24 radio module with an amplifier. It would be strange if a gateway with an amplifier could not deliver ACK. Two moments, or I did a very bad control of the amplifier on the node nRF52 or in the radio driver itself, something is not working well, and may need some delay settings. If i send messages with an ECHO (soft ack) request, this works fine over very long distances. Hw ack does not work properly.
                                • berkseoB Offline
                                  berkseoB Offline
                                  berkseo
                                  @berkseo said in NRF51-52 PA not support ???:
                                  Someone was able to do this for mysensors? Gateways and repeaters on nrf5 with amplifier is a very, very cool topic.
                                  • monteM Offline
                                    monteM Offline
                                    monte
                                    12.2k
