  3. Broken gateway with local sensors on MQTT ESP8266 GW
16 Posts 3 Posters 2.8k Views 2 Watching
    mrumpf
    wrote on last edited by mrumpf
    Setup (IDE: VSCode@MacOSX):
    • Node: Arduino Pro Mini (Clone)
      • BME280 - Temperature & Humidity & Pressure
      • BH1750 - Light
      • nRF24L01 - Radio
      • PL-2303HX (replaced 5V by DTR) -- Connection
    • Gateway: NodeMCU ESP8266 (Amica)
      • BH1750 - Light
      • nRF24L01 - Radio
      • ESP8266 USB -- Connection
    • M mrumpf
      The strange thing is that after 930865s a re-init was done and afterwards the messages from node 1 were received successfully.
      930865 TSM:FAIL:RE-INIT
      930869 TSM:INIT
      930877 TSM:INIT:TSP OK
      930881 TSM:INIT:GW MODE
      930886 TSM:READY:ID=0,PAR=0,DIS=0
      930892 TSM:READY:NWD REQ
      930932 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
      959517 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      959528 TSF:MSG:BC
      959531 TSF:MSG:FPAR REQ,ID=1
      959536 TSF:PNG:SEND,TO=0
      959540 TSF:CKU:OK
      959544 TSF:MSG:GWL OK
      959609 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      961577 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
      961587 TSF:MSG:PINGED,ID=1,HP=1
      961600 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
      962080 TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=3,l=2,sg=0:0
      962090 GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/23,MSG SENT
      962102 TSF:MSG:READ,1-1-0,s=2,c=1,t=1,pt=7,l=5,sg=0:31.76
      962112 GWT:TPS:TOPIC=mygateway1-out/1/2/1/0/1,MSG SENT
      962124 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.56
      962134 GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/0,MSG SENT
      962145 TSF:MSG:READ,1-1-0,s=3,c=1,t=4,pt=7,l=5,sg=0:963.05
      962156 GWT:TPS:TOPIC=mygateway1-out/1/3/1/0/4,MSG SENT
      and on the node side
      113469 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      115478 !TSM:FPAR:NO REPLY
      115480 TSM:FPAR
      115517 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      117526 !TSM:FPAR:FAIL
      117528 TSM:FAIL:CNT=7
      117530 TSM:FAIL:DIS
      117532 TSF:TDI:TSL
      177537 TSM:FAIL:RE-INIT
      177539 TSM:INIT
      177545 TSM:INIT:TSP OK
      177549 TSM:INIT:STATID=1
      177551 TSF:SID:OK,ID=1
      177553 TSM:FPAR
      177590 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      178278 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      178284 TSF:MSG:FPAR OK,ID=0,D=1
      179599 TSM:FPAR:OK
      Might this be related to an unstable power supply? I do not have the capacitor yet. Both devices (gateway via ESP8266 USB & node via PL-2303HX) are attached to the USB ports of my 2015 Macbook Pro.
      tekkaT
      tekkaT
      tekka
      @mrumpf Could be a power issue or one of the included libraries interfering with the SPI. The full debug log (from the beginning) may give additional hints - please upload them here (as .zip)
        mrumpf
        Here are the logs.
        Again, after 930000 seconds the gateway did a re-init and after that the 2 devices could communicate.
        Uploading a file gives me an error that only image types are supported!?0_1551391304790_Archive.zip.png
        OK, please try to extract the image. It has a zip appended :)
        Archive:  1551391305174-archive.zip.png
        warning [1551391305174-archive.zip.png]:  59815 extra bytes at beginning or within zipfile
          (attempting to process anyway)
          Length      Date    Time    Name
            31016  02-28-2019 22:18   gateway.serial.log
                0  02-28-2019 22:19   __MACOSX/
              210  02-28-2019 22:18   __MACOSX/._gateway.serial.log
            18271  02-28-2019 22:18   node.serial.log
              210  02-28-2019 22:18   __MACOSX/._node.serial.log
            49707                     5 files
        tekkaT 1 Reply Last reply
        • M mrumpf
          Here are the logs.
              49707                     5 files
          tekkaT
          tekkaT
          tekka
          @hek Is there a pic-only limitation with the file uploader?
          @mrumpf said in Broken gateway with local sensors on MQTT ESP8266 GW:
          Here are the logs.
          [0_1551388989628_Archive.zip](Uploading 100%)
          ![0_1551389194077_Archive.zip.png](Uploading 100%)
            mrumpf
            My current assumption is that there is a incompatibility with the BH1750 sensor library. When I set the symbols "LOCAL_SENSORS" and "LOCAL_SENSORS_BME280" it works. I will continue tomorrow evening...
            • M mrumpf
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              @mrumpf From the GW log:
              21822 MCO:BGN:INIT OK,TSP=0
              I see the RF24 sanity check failing and this is likely due to the BH1750 initialization code meddling with the RF24 SPI. Most probably you can fix the issue by moving the sensor setup code to preHwInit(), i.e.
              #define MY_BAUD_RATE 57600
              #define MY_RADIO_RF24
              #define MY_GATEWAY_ESP8266
              #define MY_MQTT_CLIENT_ID "mygateway1"
              #define MY_WIFI_SSID "*****"
              #define MY_WIFI_PASSWORD "*********************"
              #define MY_HOSTNAME "mygateway1"
              #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 58
              // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
              #define MY_PORT 1883
              #define LOCAL_SENSORS
              #define LOCAL_SENSORS_BH1750
              #define LOCAL_SENSORS_BME280
              #include <ESP8266WiFi.h>
              #ifdef LOCAL_SENSORS
              #include <i2cdetect.h>
              #ifdef LOCAL_SENSORS_BH1750
              #include <BH1750FVI.h>
              // light
              #define CHILD_ID_LIGHT 0
              BH1750FVI lightSensor(13, BH1750FVI::k_DevAddress_L, BH1750FVI::k_DevModeContHighRes);
              MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
              #ifdef LOCAL_SENSORS_BME280
              // temperature & humidity & pressure
              #include <Adafruit_Sensor.h>
              #include <Adafruit_BME280.h>
              #define CHILD_ID_TEMPERATURE 1
              #define CHILD_ID_HUMIDITY 2
              #define CHILD_ID_PRESSURE 3
              #define CHILD_ID_DEWPOINT 4
              Adafruit_BME280 bme;
              MyMessage temperatureMsg(CHILD_ID_TEMPERATURE, V_TEMP);
              MyMessage humidityMsg(CHILD_ID_HUMIDITY, V_HUM);
              MyMessage pressureMsg(CHILD_ID_PRESSURE, V_PRESSURE);
              #endif // LOCAL_SENSORS
              void preHwInit()
                Wire.begin(D3, D4);
                //Wire.setClock(100000);
                Serial.println("Init: BH1750 (Light)");
                lightSensor.begin();
                Serial.println("Init: BME280 (Temperature, Humidity, Pressure)");
                if (!bme.begin(0x77)) {
                  Serial.println("Could not find a valid BME280 sensor, check wiring!");
                  while (1);
                sendSketchInfo("Light/Temperature/Humidity/Pressure Gateway", "1.0");
                present(CHILD_ID_TEMPERATURE, S_TEMP);
                present(CHILD_ID_HUMIDITY, S_HUM);
                present(CHILD_ID_PRESSURE, S_BARO);
                i2cdetect();
                // light
                uint16_t lux = lightSensor.GetLightIntensity();
                Serial.print("Light: ");
                Serial.println(lux);
                send(lightMsg.set(lux));
                // humidity
                float humidity = bme.readHumidity();
                Serial.print("Humidity: ");
                Serial.println(humidity);
                send(humidityMsg.set(humidity, 2));
                // temperature
                float temperatureC = bme.readTemperature();
                Serial.print("Temperature: ");
                Serial.println(temperatureC);
                send(temperatureMsg.set(temperatureC, 2));
                // pressure
                float pressure = bme.readPressure() / 100.0F;
                Serial.print("Pressure: ");
                Serial.println(pressure);
                send(pressureMsg.set(pressure, 2));
                wait(10000);
              This also explains why the GW "recovers" after 930000ms ~= 15mins, which happens to be the GW transport sanity check interval followed by a successful transport re-init:
              920856 !TSF:SAN:FAIL
              920859 TSM:FAIL:CNT=1
              920863 TSM:FAIL:DIS
              920867 TSF:TDI:TSL
              930871 TSM:FAIL:RE-INIT
              930876 TSM:INIT
              930884 TSM:INIT:TSP OK
                mrumpf
                Thanks for your analysis! I used the BH1750FVI library which is listed in the Arduino 1.8.8 IDE under Manage libraries. The MySensors wiki however references the claws library.
                The name of the include file is different "BH1750FVI.h" (PeterEmbedded) to "BH1750.h" (claws).
                After switching to the claws library everyting works as expected!
                Maybe this could be added to the Wiki to make sure people use the right library!
                Thanks for your time!
                tekkaT mfalkviddM 2 Replies Last reply
                • M mrumpf
                  tekkaT
                  tekkaT
                  tekka
                  @mrumpf Thanks for your feedback - just for reference, did you try the BH1750FVI library and the sensor init code in preHwInit()?
                  • tekkaT tekka
                    mrumpf
                    @tekka No, but I can do that...
                    It works as well. Thanks again!
                    Here is the code:
                    // Before radio initialization
                    void preHwInit()
                      Serial.begin(57600);
                      Serial.println("preHwInit()");
                      Wire.begin(D3, D4);
                      i2cdetect();
                        while (1);
                    setup() is empty.
                    • M mrumpf
                      Great work!
                      The wiki says ”This example uses the external BH1750 library found here. Please install it and restart the Arduino IDE before trying to compile.” and links to the library. Do you have any siggestions on how we could make it clearer?
                        mrumpf
                        How about adding some warning message (highlighted) that the default Arduino IDE library requires the initialization in the preHwInit() function and not in the setup() function.
                        My mistake was missing the sentence "This example uses the external BH1750 library found here. Please install it and restart the Arduino IDE before trying to compile."
                        I was just using the library that comes with the IDE.
                        12.5k
