  3. Measure a node's NRF signal or distance value
6 Posts 4 Posters 2.7k Views 4 Watching
  • C
    C
    cdr
    Hi All,
    I was wondering if there is an easy way to ask for the distance or signal level of an NRF node.
    I know there is I_DEBUG, but it seems rather new and I haven't found any docs on that topic.
    Anyone?
    Regards,
      i can't answer about nrf case and signal strength measurement, as i'm using rfm69 which can provide rssi.
      but more generally it might appear soon?
      • I_SIGNAL_STRENGTH which is the internal msg for the Signal strength. For rfm69, it is RX Rssi, but it can be another calculation for other radio module type
      • I_POWER_LEVEL which is the internal msg for the TX radio powerlevel. To get a feedback on the radio power level set by ATC
      F 1 Reply Last reply
      • scalzS scalz
        F
        F
        flopp
        @scalz said in Measure a node's NRF signal or distance value:
        I couldn't find I_POWER_LEVEL here, https://www.mysensors.org/download/serial_api_20#internal
        Is this a command?
        What I want to is to get the Set Level of nRF24. This is set in the sketch but when it has been sent to Arduino, I have no idea what I set that day.
        eg. Repeater Node, I am using the example, make some changes, like PA_LEVEL, then I don't save the sketch
        • F flopp
          Is this a command?
          F
          F
          flopp
          @flopp
          Anyone?
          berkseoB 1 Reply Last reply
          • F flopp
            @flopp
            Anyone?
            berkseoB
            berkseoB
            berkseo
            @flopp I do not know if it is possible to measure truthfully the signal level on nrf24, but on nrf5 it can be done.
            https://youtu.be/23RQcCDS4Xk
            • F
              F
              flopp
              I was thinking about the level that you define in beginning of sketch.
              RF24_PA_LEVEL
              12.5k
