  3. Possible readymade sensor?
17 Posts 9 Posters 7.0k Views 2 Watching
  • DwaltD Dwalt
    @hek said:
    You could attach a 433Mhz receiver to one of your nodes and use it as a "gateway" to your 433mhz-stuff.
    Could you put the 433Mhz Transmitter on the gateway as opposed to locating on a separate node?
    korttomaK
    korttomaK
    korttoma
    You would in any case need to "invent" your own gateway because these 433MHz sensors all speak there own language ( use different communication protocols).
    Also if you want to use ready made sensors in the 433MHz band with the Vera I would recommend the RFXtrx433 USB interface. It has support for many protocols on the 433MHz band.
    It does not say what brand the sensors in the picture above are so it is tricky to know what protocol they use.
    I use one of these RFXtrx433 devices and also the MySensors gateway on a Vera.
    • Tomas
    • HomerH
      HomerH
      Homer
      I haven't explored this as an option any further, but I will do some looking around now for the usb interface now :-)
      • HomerH
        HomerH
        Homer
        Maybe it's because I'm in australia, but I can't find one of those usb adapters here in oz. Any suggestions of a good supplier where I could get one?
        C 1 Reply Last reply
        • HomerH Homer
          C
          C
          cribben
          @Homer
          You can buy RFXtrx433 from www.m.nu located in Sweden. Good luck.
          • m26872M
            m26872M
            m26872
            Is it just me or has anyone else experienced horrible EMI from cheap 433Mhz stuff ? Receive-only things included.
            • HomerH
              HomerH
              Homer
              I'm bumping my old post from 5 years ago, because I'm finally going to do something with these. I ended up buying 4 lots that have two power plugs plus a box that converts an IR signal into rf433. I've been chatting to a member here for a couple days about this project, and he had been very helpful.
              Currently I'm trying to decide if I should create a rf433 hub, or use my Harmony Remote setup and not worry about the rf433 at all.
              • alowhumA
                alowhumA
                alowhum
                Do you mean the 433 hub I created?
                I've been testing it with random devices I've ordered of Aliexpress, and it's so cool to see that it just immediately takes each and every one.
                The 433Hub can also copy and detect IR signals by the way. You just need to change two settings.
                • HomerH
                  HomerH
                  Homer
                  I'm going to have a bit more of a look at what you have developed to see if it's something I can build. The problem is that I don't have things like screens etc, but I did see that they were optional.
                  • alowhumA
                    alowhumA
                    alowhum
                    Indeed. I do highly recommend buying the $10 touchscreen and attaching it later. It allows the device to visually ask you to press the on and off buttons when it's ready to record their codes.
                    • HomerH
                      HomerH
                      Homer
                      Been doing a bit more research on this. The place I bought the plugs from actually have some projects that they have shared. One of them can be found here : https://www.jaycar.com.au/wi-fi-power-switch I'm hoping to find the time tomorrow to look at their sketch to see what I can come up with myself for the Mysensors environment.
