  3. IoT Fluid Sensors
IoT Fluid Sensors
4 Posts 4 Posters 1.0k Views 4 Watching
  • S Offline
    Stephen Albright
    I would like to find IoT sensors that can do the following:
    • Calculate the amount of fluid that flows through a plastic tube on a daily basis.
    • Determine the concentation of water in a cleaning solution / water mix by optical means. That means that the percent dilution is calculated optically by analyzing the color of a solution (ex. green solutions diluted by x amount of water)
    • Calculate the amount of fluid remaining in a plastic container, sending an alert when a low level is reached
    Do you know of any sensors that might be able to help here?
    Steve Albright
    monteM 1 Reply Last reply
    • P Offline
      P Offline
      pilid
      Banned
      wrote on last edited by pilid
      • S Stephen Albright
        Steve Albright
        monteM Offline
        monteM Offline
        monte
        @stephen-albright to do the fisrt thing you need a simple flow meter like this:
        For the second task I have doubts that there is available and affordable solution. At least I've never heard of something like this.
        For the third task you may use something like this:
        or this https://store.fut-electronics.com/products/under-water-depth-sensor
          There are also some waterproof ultrasound distance sensors you could use
          12.1k
