  3. Update Issues from Master request(...)
19 Posts 3 Posters 2.4k Views 3 Watching
  • UweKU UweK
    @mfalkvidd
    Hi, you're right. I used the Node verbose=5, but indead, verbose=5 on the Mysensor serial is much more saying!
    @rejoe2
    Hmm, i'm using this line numbers. Line 179?? haha, gues i'm looking into something wrong :-)
    https://github.com/mhop/fhem-mirror/blob/master/fhem/FHEM/10_MYSENSORS_DEVICE.pm
    Ok, will play with the verbose messages now to see whgats going on and where my message will die on the way.
    Then i will try to use
    request(CHILD_ID_Rel1, V_LIGHT,1);
    and
    wait(500, CHILD_ID_Rel1, V_LIGHT)
    if this will work better.
    Once finished i will share my solution (2Ch Relay (230V for light) with ESP12E and one input (for Ring) with all.
    LG
    Uwe
    rejoe2R
    rejoe2R
    rejoe2
    @uwek said in Update Issues from Master request(...):
    @rejoe2
    Sorry, that was 3 lines to much, but most likely you noticed the principle :-) . But why looking at some github repo? Most recent code is always in svn: https://svn.fhem.de/trac/browser/trunk/fhem/
    • UweKU
      UweKU
      UweK
      wrote on last edited by UweK
      Hi
      Here is my Log from fhem:
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: /0;255;3;0;9;316561201 TSF:MSG:RE
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: 0;255;3;0;9;316561201 TSF:MSG:RE/AD,100-100-0,s=1,c=2,t=2,pt=0,l=
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: 0;255;3;0;9;316561201 TSF:MSG:READ,100-100-0,s=1,c=2,t=2,pt=0,l=/0,sg=0: 100;1;2;0;2;
      2019.04.16 11:29:42 4 : MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL ) st=009(I_LOG_MESSAGE ) ack=0 '316561201 TSF:MSG:READ,100-100-0,s=1,c=2,t=2,pt=0,l=0,sg=0:'
      2019.04.16 11:29:42 5 : MYSENSORS gateway MySensors_Serial: 316561201 TSF:MSG:READ,100-100-0,s=1,c=2,t=2,pt=0,l=0,sg=0:
      2019.04.16 11:29:42 4 : MYSENSORS Read: Rx: fr=100 ci=001 c=002(C_REQ ) st=002(V_STATUS ) ack=0 ''
      2019.04.16 11:29:42 5 : MYSENSORS **send: Rx: fr=100 ci=001 c=001(C_SET ) st=002(V_STATUS ) ack=1 'off'**
      2019.04.16 11:29:42 5 : SW: 3130303b313b313b313b323b6f66660a
      2019.04.16 11:29:42 1 : PERL WARNING: Use of uninitialized value in addition (+) at ./FHEM/00_MYSENSORS.pm line 542.
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: /0;255;3;0;9;316561860 !TSF:MSG:S
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: 0;255;3;0;9;316561860 !TSF:MSG:S/END,0-0-100-100,s=1,c=1,t=2,pt=0
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: 0;255;3;0;9;316561860 !TSF:MSG:SEND,0-0-100-100,s=1,c=1,t=2,pt=0/,l=3,sg=0,ft=0,st=NACK:off
      2019.04.16 11:29:42 4 : MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL ) st=009(I_LOG_MESSAGE ) ack=0 '316561860 !TSF:MSG:SEND,0-0-100-100,s=1,c=1,t=2,pt=0,l=3,sg=0,ft=0,st=NACK:off'
      2019.04.16 11:29:42 5 : MYSENSORS gateway MySensors_Serial: 316561860 !TSF:MSG:SEND,0-0-100-100,s=1,c=1,t=2,pt=0,l=3,sg=0,ft=0,st=NACK:off
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: /0;255;3;0;9;316561871 TSF:MSG:RE
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: 0;255;3;0;9;316561871 TSF:MSG:RE/AD,100-100-0,s=2,c=2,t=2,pt=0,l=
      2019.04.16 11:29:42 4 : MYSENSORS/RAW: 0;255;3;0;9;316561871 TSF:MSG:READ,100-100-0,s=2,c=2,t=2,pt=0,l=/0,sg=0: 100;2;2;0;2;
      2019.04.16 11:29:42 4 : MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL ) st=009(I_LOG_MESSAGE ) ack=0 '316561871 TSF:MSG:READ,100-100-0,s=2,c=2,t=2,pt=0,l=0,sg=0:'
      2019.04.16 11:29:42 5 : MYSENSORS gateway MySensors_Serial: 316561871 TSF:MSG:READ,100-100-0,s=2,c=2,t=2,pt=0,l=0,sg=0:
      2019.04.16 11:29:42 4 : MYSENSORS Read: Rx: fr=100 ci=002 c=002(C_REQ ) st=002(V_STATUS ) ack=0 ''
      2019.04.16 11:29:42 5 : **MYSENSORS send: Rx: fr=100 ci=002 c=001(C_SET ) st=002(V_STATUS ) ack=1 'off'**
      2019.04.16 11:29:42 5 : SW: 3130303b323b313b313b323b6f66660a
      And here from node:
      37780 MCO:REG:REQ
      38444 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      38659 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      38664 MCO:PIM:NODE REG=1
      38667 MCO:BGN:STP
      38677 TSF:MSG:SEND,100-100-0-0,s=3,c=1,t=16,pt=4,l=4,sg=0,ft=0,st=OK:0
      Relais 1 anfragen
      39192 TSF:MSG:SEND,100-100-0-0,s=1,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
      Relais 2 anfragen
      39861 TSF:MSG:SEND,100-100-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
      39867 MCO:BGN:INIT OK,TSP=1
      Switched!
      39879 TSF:MSG:SEND,100-100-0-0,s=3,c=1,t=16,pt=4,l=4,sg=0,ft=0,st=OK:0
      40098 TSF:MSG:READ,0-0-100,s=3,c=1,t=16,pt=4,l=4,sg=0:0
      40103 TSF:MSG:ACK
      Sensor:3, Payload: 0
      This is an ack from gateway
      40115 TSF:MSG:READ,0-0-100,s=2,c=1,t=2,pt=0,l=3,sg=0:off
      40120 TSF:MSG:ACK REQ
      40331 TSF:MSG:SEND,100-100-0-0,s=2,c=1,t=2,pt=0,l=3,sg=0,ft=0,st=OK:off
      Sensor:2, Payload: 0
      Incoming change for relay:2, New status: 0
      And to complete this post, my actual rubbish code :-)
       * Copyright (C) 2013-2018 Sensnology AB
       * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
       * Version 1.0 - Henrik Ekblad
       * Example sketch showing how to control physical relays.
       * This example will remember relay state after power failure.
       * http://www.mysensors.org/build/relay
      #define SKETCH_NAME "Klingelmodul"                // Change to a fancy name you like
      #define SKETCH_VERSION "1.0"                    // Your version
      #define MY_SPECIAL_DEBUG
      //#define MY_RADIO_RF24
      //#define MY_RADIO_NRF5_ESB
      #define MY_RADIO_RFM69
      #define MY_RFM69_TX_POWER_DBM (12)
      #define MY_RFM69_NEW_DRIVER
      //#define MY_RADIO_RFM95
      //#define MY_REPEATER_FEATURE
      #define RELAY1_PIN 2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define RELAY2_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define INPUT1_PIN 16  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define NUMBER_OF_RELAYS 2 // Total number of attached relays
      #define CHILD_ID_Rel1       1 //Msg ID für Relais 1
      #define CHILD_ID_Rel2       2 //Msg ID für Relais 1
      #define CHILD_ID_Inp        3  //Msg ID für Klingelknopf
      #define CHILD_ID_RSSI_HIGH  4                // RSSI received signal level
      #define CHILD_ID_RSSI_LOW   5                // RSSI background noise level
      Bounce debouncer = Bounce();
      int Send_rssi, Rec_rssi;                                    // Sende/Empfangslevel vomRSSI RFM69 chip
      int oldValue=-1;
      int rssi_send = 0; //Schleifenzähler für RSSI Level Senden
      MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH,  V_LEVEL);
      MyMessage msgRSSI2(CHILD_ID_RSSI_LOW,   V_LEVEL);
      MyMessage msgRel1 (CHILD_ID_Rel1,       V_LIGHT);
      MyMessage msgRel2 (CHILD_ID_Rel2,       V_LIGHT);
      MyMessage msgInp  (CHILD_ID_Inp,        V_TRIPPED);
      void before()
          pinMode(RELAY1_PIN, OUTPUT);
          pinMode(RELAY2_PIN, OUTPUT);
          pinMode(INPUT1_PIN,INPUT);
          digitalWrite(RELAY1_PIN, loadState(1)?RELAY_ON:RELAY_OFF);
          digitalWrite(RELAY2_PIN, loadState(2)?RELAY_ON:RELAY_OFF);
          digitalWrite(INPUT1_PIN,HIGH);
        debouncer.attach(INPUT1_PIN);
        debouncer.interval(5);
        debouncer.update();
        int value = debouncer.read();
        send(msgInp.set(value==HIGH ? 1 : 0));
        Serial.print("Relais 1 anfragen");
        request(CHILD_ID_Rel1,       V_LIGHT,0);
        //wait(1000);
        Serial.print("Relais 2 anfragen");
        request(CHILD_ID_Rel2,       V_LIGHT,0);
        //wait(1000);
        present(CHILD_ID_Rel1,S_LIGHT,      "Relais1", true);
        present(CHILD_ID_Rel2,S_LIGHT,      "Relais2", true);
        present(CHILD_ID_Inp,S_DOOR,        "Klingel", true);
        present(CHILD_ID_RSSI_HIGH, S_SOUND,"RSSI_SendLevel", true);
        present(CHILD_ID_RSSI_LOW, S_SOUND, "RSSI_ReceiveLevel", true);
        //Alle 120Sekunden den RSSI Level schicken
        if (rssi_send > 12000){
        //Sende-Empfangsstaerke
        Serial.print("RSSI Send");
        wait(500); // Allow time for radio if power used as reset
        Send_rssi = RFM69_getSendingRSSI();             // read RSSI in RFM69. Measure reception signal from gw
        send(msgRSSI1.set(Send_rssi),true);                  // send RSSI level
        wait(500);                                 // wait to get idle
        Rec_rssi = RFM69_getReceivingRSSI();           // read RSSI in RFM69. Wait and measure background noise
        send(msgRSSI2.set(Rec_rssi),true);                  // send RSSI level
        rssi_send = 0;
        sendHeartbeat();
        rssi_send +=1;
        //Klingeltaster
        debouncer.update();
        // Get the update value
        if (value != oldValue) {
           // Send in the new value
           Serial.print("Switched!");
           send(msgInp.set(value==HIGH ? 1 : 0),true);
           oldValue = value;
       wait(10);//10ms warten
            Serial.print("Sensor:");
            Serial.print(", Payload: ");
        if (message.isAck()) {
            #ifdef MY_DEBUG
            return;
        if (message.type==V_LIGHT) {
            // Change relay state
            int outputPin = (message.sensor == CHILD_ID_Rel1)?RELAY1_PIN:RELAY2_PIN;
            digitalWrite(outputPin, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
            //saveState(message.sensor, message.getBool());
            #ifdef MY_DEBUG
            Serial.print("Incoming change for relay:");
            // Update the state variables
        else {
            #ifdef MY_DEBUG
      • UweKU
        UweKU
        UweK
        Somehow, Acks are lost and Msg as well.
        Both modules are lying away here just 30cm from each other.
        Ratlos
        • UweKU UweK
          Ratlos
          @uwek 30cm might be too close, especially with such high TX power as 12dBm
          UweKU 1 Reply Last reply
          • rejoe2R
            rejoe2R
            rejoe2
            If there's no ACK, messages will be resent, so your log excerpt from FHEM may be to short (repetition should start with +1 sec, times will be prolonged lateron).
            Remarks on your code:
            • better keep hands off from PINs 2+3 and reserve them for interrupt-based tasks (might be here input Pin 3 for your button, but debounce2() and using differen PIN is ok also)
            • RFM69: Better connect interrupt (PIN2)?
            • RSSI may need #define MY_SIGNAL_REPORT_ENABLED
            • rejoe2R rejoe2
              UweKU
              UweKU
              UweK
              @rejoe2
              I am using a pcb i bought 2 years ago, thus most pins are used somehow.
              I was able to cut some lines and use wire to reconnect to RFM69 for example.
              IT's quite a small pcb to be build inside walls behind switches etc.
              I am using GPIO15 even it's used to start the ESP into programming mode.
              Btw: I am not using WLAN. It was used for that before, but, as i am living on LaPalma,
              the walls include stones with hight part of iron. WLAN is not crossinfg my 60cm walls :-(
              Thats the reason why i am switching to 800MHz. It is working much better, but with 5dbm,
              no chance, thus 12 dbm...
              Because this is my very first experience with MySensors, it is a bit like an adventure :-)
              Maybe later on i can reduce the power...
              Thanks for the tips!
              uwe
              • rejoe2R
                rejoe2R
                rejoe2
                So ok, you want to learn the hard way :grinning: ...
                If the mcu is an ESP8266 also on the node's side, forget about PIN2/3 beeing special, this applies to standard ATMega32P. But perhaps you'd have to define a different interrupt pin for the RFM.
                Frankly spoken, imo it's easier to start off with a more default setup...
                  UweKU
                  UweKU
                  UweK
                  @mfalkvidd
                  Put it 3m away with same result.
                  A monster is eating my packages...
                  If it works with wait(), it must be a timing issue!
                  Also, i wonder why i am getting only ONE Ack if a request every time a ack.
                  I have now added #define MY_SPECIAL_DEBUG as well to see more on serial console.
                  • UweKU
                    UweKU
                    UweK
                    @rejoe2
                    Do you believe the interrupt is not working correctly?
                    • rejoe2R
                      rejoe2R
                      rejoe2
                      @uwek Special-Debug only gives some more info about the sketch, so this most likely will not help.
                      Wrt to ACK, I'm not familiar how the MySensors lib handles that internally, but FHEM will keep all the messages seperate from each other.
                      I also have little experience with RFM modules; for nRF interrupt handling is not necessary, but most likely, this is the exception. Anyhow: It seems to work to some extend, so I'd not bet to much on this as the root cause of your problems.
                      • UweKU
                        UweKU
                        UweK
                        Hi all
                        I solved this issue, this is the solution:
                        I am using wait with additional parameter to wait 1000ms OR for a specific data packet from fhem. This works well!
                        Now i don't need to write into EEPROM, after reboot the node is requesting actual status of the relays from fhem.
                         //request status of Relais 1
                          request(CHILD_ID_Rel1,       V_WATT,0);
                          wait(1000,1,2);
                          //request status of Relais 2
                          request(CHILD_ID_Rel2,       V_WATT,0);
                          wait(1000,1,2);
                        Another "enhancement":
                        I am using the Power readings to set/reset relays and i use the status reading to get the actual status back.
                        I guess this was the initial logic of the fhem modul, but as power only produce a "1" as setpoint, i changed it to "on,off", equal the Power reading.
                        The primitive setup in fhem looks like thios:
                        defmod MYSENSOR_100 MYSENSORS_DEVICE 100
                        attr MYSENSOR_100 DbLogExclude .*
                        attr MYSENSOR_100 IODev mysensors
                        attr MYSENSOR_100 mapReading_armed3 3 armed
                        attr MYSENSOR_100 mapReading_armed4 4 armed
                        attr MYSENSOR_100 mapReading_armed5 5 armed
                        attr MYSENSOR_100 mapReading_level4 4 level
                        attr MYSENSOR_100 mapReading_level5 5 level
                        attr MYSENSOR_100 mapReading_power1 1 power
                        attr MYSENSOR_100 mapReading_power2 2 power
                        attr MYSENSOR_100 mapReading_status1 1 status
                        attr MYSENSOR_100 mapReading_status2 2 status
                        attr MYSENSOR_100 mapReading_tripped3 3 tripped
                        attr MYSENSOR_100 mapReading_tripped4 4 tripped
                        attr MYSENSOR_100 mapReading_tripped5 5 tripped
                        attr MYSENSOR_100 mode node
                        attr MYSENSOR_100 requestAck 1
                        attr MYSENSOR_100 room mysensor
                        attr MYSENSOR_100 setReading_power1 on,off
                        attr MYSENSOR_100 setReading_power2 on,off
                        attr MYSENSOR_100 setReading_status1 on,off
                        attr MYSENSOR_100 setReading_status2 on,off
                        attr MYSENSOR_100 showtime 1
                        attr MYSENSOR_100 timeoutAlive 240
                        attr MYSENSOR_100 verbose 5
                        setstate MYSENSOR_100 alive
                        setstate MYSENSOR_100 2019-04-22 10:54:10 R_RSSI_from_Parent -89
                        setstate MYSENSOR_100 2019-04-22 10:54:09 R_RSSI_to_Parent -82
                        setstate MYSENSOR_100 2019-04-22 10:54:11 R_TX_Powerlevel_Pct 100
                        setstate MYSENSOR_100 2019-04-22 10:54:11 R_TX_Powerlevel_dBm 13
                        setstate MYSENSOR_100 2019-04-22 10:54:12 R_Uplink_Quality -89
                        setstate MYSENSOR_100 2019-04-20 21:20:19 SKETCH_NAME Klingelmodul
                        setstate MYSENSOR_100 2019-04-20 21:20:19 SKETCH_VERSION 1.1
                        setstate MYSENSOR_100 2019-04-22 11:01:15 heartbeat last
                        setstate MYSENSOR_100 2019-04-22 11:01:14 level4 -93
                        setstate MYSENSOR_100 2019-04-22 11:01:15 level5 -88
                        setstate MYSENSOR_100 2019-04-20 21:20:19 parentId 0
                        setstate MYSENSOR_100 2019-04-21 22:49:37 power1 on
                        setstate MYSENSOR_100 2019-04-20 21:32:44 power2 on
                        setstate MYSENSOR_100 2019-04-22 11:01:15 state alive
                        setstate MYSENSOR_100 2019-04-21 22:49:37 status1  1
                        setstate MYSENSOR_100 2019-04-20 21:32:45 status2  1
                        setstate MYSENSOR_100 2019-04-22 10:48:49 tripped3 off
                        tripped3 is my Input from the Doorbell.
                        Ok, guys, 1000 thanks for your help!
                        BR
                        Uwe
