  3. Beginner Problems
Beginner Problems
6 Posts 3 Posters 1.4k Views 3 Watching
  • S Offline
    sharpy
    Hi everyone
    I''m already running OpenHAB have been for some time so that's my controller
    but i'm new to Aruino and my sensors, I have got the parts needed to build my Ethernet gateway and my first sensor (DHT22) i have been battling beginner problems all day but i'm not sure if anything is actually working and don't realy know where to go from here
    also on the sensor itself should i see the temp/humidity readout on the serial console i only see errors i dont understand at the moment
    here's a readout from the serial console of the sensor
    20:22:46.849 -> 8084 TSM:FAIL:CNT=1
    20:22:46.849 -> 8086 TSM:FAIL:DIS
    20:22:46.849 -> 8088 TSF:TDI:TSL
    20:22:56.837 -> 18091 TSM:FAIL:RE-INIT
    20:22:56.837 -> 18093 TSM:INIT
    20:22:56.837 -> 18099 TSM:INIT:TSP OK
    20:22:56.837 -> 18101 TSM:FPAR
    20:22:56.883 -> 18104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20:22:58.852 -> 20111 !TSM:FPAR:NO REPLY
    20:22:58.852 -> 20113 TSM:FPAR
    20:22:58.852 -> 20115 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20:23:00.867 -> 22123 !TSM:FPAR:NO REPLY
    20:23:00.867 -> 22125 TSM:FPAR
    20:23:00.867 -> 22127 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20:23:02.883 -> 24135 !TSM:FPAR:NO REPLY
    20:23:02.883 -> 24137 TSM:FPAR
    20:23:02.883 -> 24139 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20:23:04.898 -> 26147 !TSM:FPAR:FAIL
    20:23:04.898 -> 26148 TSM:FAIL:CNT=2
    20:23:04.898 -> 26150 TSM:FAIL:DIS
    20:23:04.898 -> 26152 TSF:TDI:TSL
    20:23:14.919 -> 36156 TSM:FAIL:RE-INIT
    20:23:14.919 -> 36158 TSM:INIT
    20:23:14.966 -> 36164 TSM:INIT:TSP OK
    20:23:14.966 -> 36166 TSM:FPAR
    20:23:14.966 -> 36169 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20:23:16.971 -> 38176 !TSM:FPAR:NO REPLY
    20:23:16.971 -> 38178 TSM:FPAR
    20:23:16.971 -> 38180 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20:23:18.955 -> 40189 !TSM:FPAR:NO REPLY
    20:23:18.955 -> 40192 TSM:FPAR
    20:23:18.955 -> 40194 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    B 1 Reply Last reply
    • S sharpy
      Hi everyone
      B Offline
      B Offline
      bgunnarb
      @sharpy
      It looks like your sensor does not find the gateway.
      What does your sensor sketch look like?
      What interface do you use to OpenHab? Openhab binding?
      Did you set a node-ID manually in the sketch? OH does not assign node-IDs automatically as far as I know.
      I have never been so busy since I retired!
      S 1 Reply Last reply
      • B bgunnarb
        @sharpy
        sharpy
        wrote on last edited by sharpy
        @bgunnarb
        Hi and thanks for a reply
        Yes i used the mysensor binding in openhab i was going too try mqtt but thought best leave learning that for another day
        I think the gateway is working its connected too my network and online, pingable and openhab does say it can connect too it.
        as for the node ID, no I have not manually set it in the sketch as i don't know how too do this but i did need too do something node related in openhab im not sure if this was the needed thing openhab asked me for it
        at the moment i just haven't got a clue what stuff looks like when its working an not
        Sensor Sketch was example on the Humidity Page
         * Version 1.0: Henrik EKblad
         * sensor using a DHT11/DHT-22.
        // Enable debug prints
        #define MY_RADIO_RF24
        //#define MY_RS485
        #define DHT_DATA_PIN 3
        // Set this offset if the sensor has a permanent small offset to the real temperatures.
        // In Celsius degrees (as measured by the device)
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 60000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        DHT dht;
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            // apply the offset before converting to something different than Celsius degrees
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
            nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
        • S Offline
          sharpy
          @bgunnarb
          I have solved this now.
          I was using a NRF24L01+PA+LNA for my gateway radio swapping this for the same radio used on my sensor the NRF24L01 2.4GHZ everything started working straight away.
          i was hoping to use the bigger radio for better range any ideas why it didn't work
          First Radio Used Unsucessful
          Working Radio Used
          • S sharpy
            @bgunnarb
            Working Radio Used
            B Offline
            B Offline
            bgunnarb
            @sharpy
            I have no good idea why one radio worked and the other not. The PA+LNA radio requires more power but that should not be an issue on the gateway. I assume you have a good capacitor, 4.7 μF or more on the radio power connection. I normally use 22 μF since I have plenty of them.
            You set the node-ID manually by including:
            #define NY_NODE_ID    4
            or whatever number you like to use. This should be in your sketch before the
            Like all other #defines
            Look under Configuration on this page: https://www.mysensors.org/download/sensor_api_20
            • A Offline
              A Offline
              aze
              wrote on last edited by aze
              you can see recent article on range test of NRF24L01 PA LNA : http://domotique-diy.over-blog.com/2019/04/test-de-portee-des-modules-nrf24l01-pa-lna.html
              And see more about this on https://twitter.com/ThiDom1
              You can found a demo link on the blog.
              It's in french but you can use google traduction ;)
