  3. Domoticz
  4. questioun using multiple sensors on domoticz
4 Posts 3 Posters 1.7k Views 4 Watching
  • fernando alvarez buyllaF
    wrote on last edited by fernando alvarez buylla
    Hi guys i building a multi sensor node , but i have one problem with a water pressure it keeps giving me a weather pressure , any one know what im doing wrong
    #define MY_NODE_ID 1
    #define CHILD_ID_VOLT_1 1
    #define CHILD_ID_VOLT_2 2
    #define CHILD_ID_VOLT_3 3
    #define CHILD_ID_CURRENT_1 4
    #define CHILD_ID_CURRENT_2 5
    #define CHILD_ID_CURRENT_3 6
    #define CHILD_ID_PRESION 7
    #define VOLT_SENSOR_ANALOG_PIN_1 0
    #define VOLT_SENSOR_ANALOG_PIN_2 1
    #define VOLT_SENSOR_ANALOG_PIN_3 2
    #define CURRENT_SENSOR_ANALOG_PIN_1 3
    #define CURRENT_SENSOR_ANALOG_PIN_2 4
    #define CURRENT_SENSOR_ANALOG_PIN_3 5
    #define PressPin      A6
    unsigned long SLEEP_TIME = 20000; // Sleep time between reads (in milliseconds)
    MyMessage msg(CHILD_ID_VOLT_1, V_VOLTAGE);
    MyMessage msg2(CHILD_ID_VOLT_2, V_VOLTAGE);
    MyMessage msg3(CHILD_ID_VOLT_3, V_VOLTAGE);
    MyMessage msg4(CHILD_ID_CURRENT_1, V_CURRENT);
    MyMessage msg5(CHILD_ID_CURRENT_2, V_CURRENT);
    MyMessage msg6(CHILD_ID_CURRENT_3, V_CURRENT);
    MyMessage pressureMsg(CHILD_ID_PRESION, V_PRESSURE);
    float lastVolt1;
    float lastVolt2;
    float lastVolt3;
    float lastCurrent1;
    float lastCurrent2;
    float lastCurrent3;
    float lastPresion;
    int pressure = 0;
    float PSI = 0;
    float PSI_CAL = 2.0;            // Calibration of sensor
    int PSImsb = 0;
    int PSIr = 0;
    void before() {
      sendSketchInfo("Pozo multi sensor", "1.0");  // Send the sketch version information to the gateway and Controller
      present(CHILD_ID_VOLT_1, S_MULTIMETER);   // Register this device as power sensor
      present(CHILD_ID_VOLT_2, S_MULTIMETER);   // Register this device as power sensor
      present(CHILD_ID_VOLT_3, S_MULTIMETER);   // Register this device as power sensor
      present(CHILD_ID_CURRENT_1, S_MULTIMETER);   // Register this device as power sensor
      present(CHILD_ID_CURRENT_2, S_MULTIMETER);   // Register this device as power sensor
      present(CHILD_ID_CURRENT_3, S_MULTIMETER);   // Register this device as power sensor
      present(CHILD_ID_PRESION, S_WATER);   // Register this device as power sensor
      int Voltaje1 = analogRead(A0);
      int Voltaje2 = analogRead(A1);
      int Voltaje3 = analogRead(A2);
      int Corriente1 = analogRead(A3);
      int Corriente2 = analogRead(A4);
      int Corriente3 = analogRead(A5);
      float VoltLevel1 = map(Voltaje1,0,1023,0,500);
      float VoltLevel2 = map(Voltaje2,0,1023,0,500);
      float VoltLevel3 = map(Voltaje3,0,1023,0,500);
      float CorrienteLevel1 = map(Corriente1,0,1023,0,200);
      float CorrienteLevel2 = map(Corriente2,0,1023,0,200);
      float CorrienteLevel3 = map(Corriente3,0,1023,0,200);
      Serial.print("Voltaje L1: ");
      Serial.println(VoltLevel1);
      Serial.print("Voltaje L2: ");
      Serial.println(VoltLevel2);
      Serial.print("Voltaje L3: ");
      Serial.println(VoltLevel3);
      Serial.print("Corriente L1: ");
      Serial.println(CorrienteLevel1);
      Serial.print("Corriente L2: ");
      Serial.println(CorrienteLevel2);
      Serial.print("Corriente L3: ");
      Serial.println(CorrienteLevel3);
      //sensor de voltaje
      if (VoltLevel1 != lastVolt1) {
          send(msg.set(VoltLevel1, 1));
          lastVolt1 = VoltLevel1;
        if (VoltLevel2 != lastVolt2) {
          send(msg2.set(VoltLevel2, 1));
          lastVolt2 = VoltLevel2;
        if (VoltLevel3 != lastVolt3) {
          send(msg3.set(VoltLevel3, 1));
          lastVolt3 = VoltLevel3;
    //sensor de corriente
        if (CorrienteLevel1 != lastCurrent1) {
          send(msg4.set(CorrienteLevel1, 1));
          lastCurrent1 = CorrienteLevel1;
          if (CorrienteLevel2 != lastCurrent2) {
          send(msg5.set(CorrienteLevel2, 1));
          lastCurrent2 = CorrienteLevel2;
          if (CorrienteLevel3 != lastCurrent3) {
          send(msg6.set(CorrienteLevel3, 1));
          lastCurrent3 = CorrienteLevel3;
        pressure  = analogRead    (PressPin) ;        // junk read
        wait(25);
    /* • Output: 0.5V – 4.5V linear voltage output. 0 psi outputs 0.5V, 50 psi outputs 2.5V, 100 psi outputs 4.5V
        0   psi = .33v after scalling 5.0v to 3.3v
        50  psi = 1.65v
        100 psi = 2.97v
        3.3v/1024 = .0032266 volt per bit
        if (pressure < 106) pressure = 106;         // this is minimum of .5v
        PSI = (pressure - 106 ) * .1246;            // where did we get this?? was .119904
        PSI = PSI + PSI_CAL;                        // adjustment
        PSImsb = PSI * 100;
        PSIr = PSImsb % 100;
        send(pressureMsg.set(PSI, 2));            // Send water pressure to gateway
        Serial.print("Presion: ");
        Serial.println(PSI);
        wait(200);
         // end of if (SLEEP_MODE || (cu
      sleep(SLEEP_TIME);
    any help will be very appreciated
    • fernando alvarez buyllaF fernando alvarez buylla
      #define PressPin      A6
      float lastVolt1;
      float lastVolt2;
      float lastVolt3;
      float lastCurrent1;
      float lastCurrent2;
      float lastCurrent3;
      float lastPresion;
      int pressure = 0;
      float PSI = 0;
      int PSImsb = 0;
      int PSIr = 0;
      void before() {
        //sensor de voltaje
          wait(25);
          50  psi = 1.65v
          100 psi = 2.97v
          PSImsb = PSI * 100;
          wait(200);
        sleep(SLEEP_TIME);
      zboblamontZ
      zboblamontZ
      zboblamont
      @fernando-alvarez-buylla S_WATER is a Volume or Flow subset from memory.
      I've not yet got round to installing pressure sensors on the pumped supply, but had already settled on tracking numeric values of hydraulic pressure such as Bar or Metres typical of physical pressure meters, so V_DISTANCE and S_DISTANCE seem more appropriate and might be worth a try your end.
      • alowhumA
        alowhumA
        alowhum
        @fernando-alvarez-buylla said in questioun using multiple sensors on domoticz:
        S_WATER
        Here you will see that with S_WATER you should use another V-TYPE:
        https://www.mysensors.org/download/serial_api_20
        • alowhumA alowhum
          S_WATER
          zboblamontZ
          zboblamontZ
          zboblamont
          @alowhum Always been curious how Domoticz treats the V and S values, so tended to follow the MySensor API and had a few if unexpected moments and results along the way.
          You implied that presentation of V_PRESSURE pre-determines an expectation of S_BARO irrespective of whatever further S_? statement follows.
          Is this understanding correct?
