  3. Atmega328P + RFM69HW(868) not working
13 Posts 3 Posters 1.8k Views 4 Watching
  • MasMatM MasMat
    @mfalkvidd Exactly. That's where it just gets stuck. The other node didn't have the void-before so it just gets stuck when I power it up.
    @masmat see if adding #define MY_DEBUG_VERBOSE_RFM69 at top of the sketch can give useful information
    (Link)
    • mfalkviddM
      You can also try removing define MY_IS_RFM69HW - sometimes the vendors send non-HW versions with wrong label.
      MasMatM 1 Reply Last reply
        MasMatM
        MasMatM
        MasMat
        wrote on last edited by MasMat
        @mfalkvidd Verbose_rfm69 did nothing but uncommenting the HW seems to have worked. I'm getting 2m range now, so probably same problem on the GW as well?
        I looked at the modules and compared pictures. They're Chinese but the smd's on the board do match the HW-version.
        • MasMatM
          MasMatM
          MasMat
          I added the NEW_DRIVER to gw and node and re-added HW-option as well.
          Now within 1m of each other I get this output from node:
                  |___/                      2.3.1
          32 MCO:BGN:INIT NODE,CP=RPNNAS--,REL=255,VER=2.3.1
          53 MCO:BGN:BFR
          2082 TSM:INIT
          2086 TSF:WUR:MS=0
          2088 RFM69:INIT
          2093 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
          2099 RFM69:PTX:LEVEL=5 dBm
          2105 TSM:INIT:TSP OK
          2109 TSM:INIT:STATID=51
          2113 TSF:SID:OK,ID=51
          2117 TSM:FPAR
          2119 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
          2129 RFM69:CSMA:RSSI=-92
          2134 RFM69:CSMA:RSSI=-96
          2138 TSF:MSG:SEND,51-51-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          3012 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
          3020 RFM69:CSMA:RSSI=-100
          3026 TSF:MSG:READ,0-0-51,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
          4153 !TSM:FPAR:NO REPLY
          4157 TSM:FPAR
          4159 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
          4167 RFM69:CSMA:RSSI=-93
          4171 RFM69:CSMA:RSSI=-95
          4179 TSF:MSG:SEND,51-51-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4710 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
          4718 RFM69:CSMA:RSSI=-94
          4724 RFM69:CSMA:RSSI=-95
          4730 TSF:MSG:READ,0-0-51,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          4741 TSF:MSG:FPAR OK,ID=0,D=1
          6195 TSM:FPAR:OK
          6197 TSM:ID
          6199 TSM:ID:OK
          6203 TSM:UPL
          6205 RFM69:SWR:SEND,TO=0,SEQ=4,RETRY=0
          6213 RFM69:CSMA:RSSI=-92
          6217 RFM69:CSMA:RSSI=-94
          6221 RFM69:CSMA:RSSI=-91
          6227 RFM69:CSMA:RSSI=-92
          6232 RFM69:CSMA:RSSI=-90
          6236 RFM69:CSMA:RSSI=-93
          6240 RFM69:CSMA:RSSI=-98
          6301 RFM69:SWR:ACK,FROM=0,SEQ=5,RSSI=-46
          6309 RFM69:ATC:ADJ TXL,cR=-46,tR=-78..-82,TXL=5
          6318 RFM69:PTX:LEVEL=4 dBm
          6322 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          7012 RFM69:SAC:SEND ACK,TO=0,RSSI=-55
          7020 RFM69:CSMA:RSSI=-89
          7024 RFM69:CSMA:RSSI=-91
          7028 RFM69:CSMA:RSSI=-88
          7032 RFM69:CSMA:RSSI=-91
          7038 RFM69:CSMA:RSSI=-95
          7045 TSF:MSG:READ,0-0-51,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          7055 TSF:MSG:PONG RECV,HP=1
          7061 TSM:UPL:OK
          7063 TSM:READY:ID=51,PAR=0,DIS=1
          7069 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=0
          7077 RFM69:CSMA:RSSI=-96
          7139 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-50
          7147 RFM69:ATC:ADJ TXL,cR=-50,tR=-78..-82,TXL=4
          7155 RFM69:PTX:LEVEL=3 dBm
          7159 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
          7839 RFM69:SAC:SEND ACK,TO=0,RSSI=-55
          7845 RFM69:CSMA:RSSI=-92
          7852 RFM69:CSMA:RSSI=-93
          7856 RFM69:CSMA:RSSI=-99
          7862 TSF:MSG:READ,0-0-51,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
          7874 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=0
          7882 RFM69:CSMA:RSSI=-93
          7886 RFM69:CSMA:RSSI=-93
          7890 RFM69:CSMA:RSSI=-96
          7952 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-50
          7960 RFM69:ATC:ADJ TXL,cR=-50,tR=-78..-82,TXL=3
          7968 RFM69:PTX:LEVEL=2 dBm
          7972 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
          8806 RFM69:SAC:SEND ACK,TO=0,RSSI=-57
          8814 RFM69:CSMA:RSSI=-92
          8818 RFM69:CSMA:RSSI=-92
          8824 RFM69:CSMA:RSSI=-92
          8828 RFM69:CSMA:RSSI=-94
          8833 RFM69:CSMA:RSSI=-94
          8837 RFM69:CSMA:RSSI=-93
          8843 RFM69:CSMA:RSSI=-90
          8847 RFM69:CSMA:RSSI=-95
          8851 RFM69:CSMA:RSSI=-93
          8855 RFM69:CSMA:RSSI=-90
          8861 RFM69:CSMA:RSSI=-92
          8865 RFM69:CSMA:RSSI=-91
          8869 RFM69:CSMA:RSSI=-92
          8873 RFM69:CSMA:RSSI=-94
          8880 RFM69:CSMA:RSSI=-93
          8884 RFM69:CSMA:RSSI=-91
          8888 RFM69:CSMA:RSSI=-91
          8892 RFM69:CSMA:RSSI=-91
          8898 RFM69:CSMA:RSSI=-93
          8902 RFM69:CSMA:RSSI=-91
          8906 RFM69:CSMA:RSSI=-96
          8914 TSF:MSG:READ,0-0-51,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
          8972 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=0
          8980 RFM69:CSMA:RSSI=-93
          8986 RFM69:CSMA:RSSI=-91
          8990 RFM69:CSMA:RSSI=-96
          9056 RFM69:SWR:ACK,FROM=0,SEQ=11,RSSI=-51
          9062 RFM69:ATC:ADJ TXL,cR=-51,tR=-78..-82,TXL=2
          9070 RFM69:PTX:LEVEL=1 dBm
          9076 TSF:MSG:SEND,51-51-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.3.1
          9091 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=0
          9099 RFM69:CSMA:RSSI=-96
          9162 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-54
          9171 RFM69:ATC:ADJ TXL,cR=-54,tR=-78..-82,TXL=1
          9179 RFM69:PTX:LEVEL=0 dBm
          9185 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
          10354 RFM69:SAC:SEND ACK,TO=0,RSSI=-56
          10362 RFM69:CSMA:RSSI=-97
          10369 TSF:MSG:READ,0-0-51,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
          10427 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=0
          10436 RFM69:CSMA:RSSI=-91
          10440 RFM69:CSMA:RSSI=-93
          10446 RFM69:CSMA:RSSI=-93
          10450 RFM69:CSMA:RSSI=-91
          10456 RFM69:CSMA:RSSI=-93
          10460 RFM69:CSMA:RSSI=-93
          10464 RFM69:CSMA:RSSI=-94
          10470 RFM69:CSMA:RSSI=-96
          10534 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-53
          10542 RFM69:ATC:ADJ TXL,cR=-53,tR=-78..-82,TXL=0
          10550 RFM69:PTX:LEVEL=-1 dBm
          10556 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
          12570 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=0
          12578 RFM69:CSMA:RSSI=-96
          12643 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-58
          12649 RFM69:ATC:ADJ TXL,cR=-58,tR=-78..-82,TXL=-1
          12660 RFM69:PTX:LEVEL=-2 dBm
          12664 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
          13553 RFM69:SAC:SEND ACK,TO=0,RSSI=-56
          13561 RFM69:CSMA:RSSI=-95
          13567 TSF:MSG:READ,0-0-51,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
          13626 RFM69:SWR:SEND,TO=0,SEQ=16,RETRY=0
          13634 RFM69:CSMA:RSSI=-94
          13638 RFM69:CSMA:RSSI=-93
          13644 RFM69:CSMA:RSSI=-94
          13648 RFM69:CSMA:RSSI=-94
          13655 RFM69:CSMA:RSSI=-93
          13659 RFM69:CSMA:RSSI=-90
          13663 RFM69:CSMA:RSSI=-92
          13669 RFM69:CSMA:RSSI=-91
          13673 RFM69:CSMA:RSSI=-98
          13739 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-58
          13747 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=11,pt=0,l=23,sg=1,ft=0,st=OK:RFID Lock & Door sensor
          13763 RFM69:SWR:SEND,TO=0,SEQ=17,RETRY=0
          13771 RFM69:CSMA:RSSI=-96
          13984 !RFM69:SWR:NACK
          13988 RFM69:SWR:SEND,TO=0,SEQ=18,RETRY=1
          13997 RFM69:CSMA:RSSI=-91
          14001 RFM69:CSMA:RSSI=-93
          14005 RFM69:CSMA:RSSI=-91
          14011 RFM69:CSMA:RSSI=-92
          14015 RFM69:CSMA:RSSI=-92
          14021 RFM69:CSMA:RSSI=-91
          14025 RFM69:CSMA:RSSI=-91
          14029 RFM69:CSMA:RSSI=-91
          14036 RFM69:CSMA:RSSI=-93
          14040 RFM69:CSMA:RSSI=-93
          14044 RFM69:CSMA:RSSI=-91
          14050 RFM69:CSMA:RSSI=-89
          14054 RFM69:CSMA:RSSI=-93
          14060 RFM69:CSMA:RSSI=-96
          14271 !RFM69:SWR:NACK
          14275 RFM69:SWR:SEND,TO=0,SEQ=18,RETRY=2
          14283 RFM69:CSMA:RSSI=-91
          14287 RFM69:CSMA:RSSI=-91
          14292 RFM69:CSMA:RSSI=-93
          14298 RFM69:CSMA:RSSI=-89
          14302 RFM69:CSMA:RSSI=-90
          14308 RFM69:CSMA:RSSI=-89
          14312 RFM69:CSMA:RSSI=-91
          14316 RFM69:CSMA:RSSI=-91
          14322 RFM69:CSMA:RSSI=-91
          14326 RFM69:CSMA:RSSI=-52
          14330 RFM69:CSMA:RSSI=-51
          14337 RFM69:CSMA:RSSI=-52
          14341 RFM69:CSMA:RSSI=-94
          14347 RFM69:CSMA:RSSI=-91
          14351 RFM69:CSMA:RSSI=-92
          14355 RFM69:CSMA:RSSI=-94
          14361 RFM69:CSMA:RSSI=-91
          14365 RFM69:CSMA:RSSI=-90
          14369 RFM69:CSMA:RSSI=-93
          14376 RFM69:CSMA:RSSI=-93
          14380 RFM69:CSMA:RSSI=-93
          14386 RFM69:CSMA:RSSI=-91
          14390 RFM69:CSMA:RSSI=-94
          14394 RFM69:CSMA:RSSI=-95
          14400 RFM69:CSMA:RSSI=-90
          14404 RFM69:CSMA:RSSI=-91
          14408 RFM69:CSMA:RSSI=-91
          14414 RFM69:CSMA:RSSI=-91
          14419 RFM69:CSMA:RSSI=-91
          14425 RFM69:CSMA:RSSI=-91
          14429 RFM69:CSMA:RSSI=-96
          14634 !RFM69:SWR:NACK
          14638 RFM69:SWR:SEND,TO=0,SEQ=18,RETRY=3
          14646 RFM69:CSMA:RSSI=-91
          14650 RFM69:CSMA:RSSI=-93
          14654 RFM69:CSMA:RSSI=-93
          14660 RFM69:CSMA:RSSI=-93
          14664 RFM69:CSMA:RSSI=-95
          14670 RFM69:CSMA:RSSI=-93
          14675 RFM69:CSMA:RSSI=-91
          14679 RFM69:CSMA:RSSI=-89
          14685 RFM69:CSMA:RSSI=-93
          14689 RFM69:CSMA:RSSI=-93
          14693 RFM69:CSMA:RSSI=-94
          14699 RFM69:CSMA:RSSI=-95
          14703 RFM69:CSMA:RSSI=-90
          14709 RFM69:CSMA:RSSI=-92
          14713 RFM69:CSMA:RSSI=-90
          14718 RFM69:CSMA:RSSI=-91
          14724 RFM69:CSMA:RSSI=-95
          14935 !RFM69:SWR:NACK
          14939 RFM69:SWR:SEND,TO=0,SEQ=18,RETRY=4
          14947 RFM69:CSMA:RSSI=-93
          14951 RFM69:CSMA:RSSI=-96
          15164 !RFM69:SWR:NACK
          15168 RFM69:SWR:SEND,TO=0,SEQ=18,RETRY=5
          15176 RFM69:CSMA:RSSI=-95
          15387 !RFM69:SWR:NACK
          15391 !TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
          15404 !TSF:MSG:SIGN FAIL
          15408 RFM69:SWR:SEND,TO=0,SEQ=18,RETRY=0
          15418 RFM69:CSMA:RSSI=-93
          15422 RFM69:CSMA:RSSI=-93
          15426 RFM69:CSMA:RSSI=-97
          15461 !RFM69:SWR:NACK
          15465 RFM69:SWR:SEND,TO=0,SEQ=19,RETRY=1
          15473 RFM69:CSMA:RSSI=-95
          15494 !RFM69:SWR:NACK
          15498 RFM69:SWR:SEND,TO=0,SEQ=19,RETRY=2
          15506 RFM69:CSMA:RSSI=-93
          15512 RFM69:CSMA:RSSI=-97
          15725 !RFM69:SWR:NACK
          15729 RFM69:SWR:SEND,TO=0,SEQ=19,RETRY=3
          15737 RFM69:CSMA:RSSI=-94
          15742 RFM69:CSMA:RSSI=-93
          15746 RFM69:CSMA:RSSI=-96
          15959 !RFM69:SWR:NACK
          15963 RFM69:SWR:SEND,TO=0,SEQ=19,RETRY=4
          15971 RFM69:CSMA:RSSI=-93
          15975 RFM69:CSMA:RSSI=-94
          15979 RFM69:CSMA:RSSI=-93
          15985 RFM69:CSMA:RSSI=-94
          15989 RFM69:CSMA:RSSI=-94
          15995 RFM69:CSMA:RSSI=-91
          16000 RFM69:CSMA:RSSI=-94
          16004 RFM69:CSMA:RSSI=-93
          16010 RFM69:CSMA:RSSI=-94
          16014 RFM69:CSMA:RSSI=-51
          16018 RFM69:CSMA:RSSI=-52
          16024 RFM69:CSMA:RSSI=-94
          16028 RFM69:CSMA:RSSI=-92
          16034 RFM69:CSMA:RSSI=-96
          16239 !RFM69:SWR:NACK
          16243 RFM69:SWR:SEND,TO=0,SEQ=19,RETRY=5
          16251 RFM69:CSMA:RSSI=-94
          16256 RFM69:CSMA:RSSI=-91
          16260 RFM69:CSMA:RSSI=-91
          16266 RFM69:CSMA:RSSI=-92
          16270 RFM69:CSMA:RSSI=-91
          16276 RFM69:CSMA:RSSI=-89
          16280 RFM69:CSMA:RSSI=-90
          16284 RFM69:CSMA:RSSI=-93
          16290 RFM69:CSMA:RSSI=-93
          16294 RFM69:CSMA:RSSI=-91
          16299 RFM69:CSMA:RSSI=-90
          16305 RFM69:CSMA:RSSI=-94
          16309 RFM69:CSMA:RSSI=-92
          16315 RFM69:CSMA:RSSI=-93
          16319 RFM69:CSMA:RSSI=-92
          16323 RFM69:CSMA:RSSI=-94
          16329 RFM69:CSMA:RSSI=-95
          16516 !RFM69:SWR:NACK
          16520 !TSF:MSG:SEND,51-51-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=2,st=NACK:
          16532 !TSF:MSG:SIGN FAIL
          16536 RFM69:SWR:SEND,TO=0,SEQ=19,RETRY=0
          16546 RFM69:CSMA:RSSI=-91
          16550 RFM69:CSMA:RSSI=-93
          16555 RFM69:CSMA:RSSI=-92
          16561 RFM69:CSMA:RSSI=-91
          16565 RFM69:CSMA:RSSI=-92
          16571 RFM69:CSMA:RSSI=-92
          16575 RFM69:CSMA:RSSI=-92
          16579 RFM69:CSMA:RSSI=-92
          16585 RFM69:CSMA:RSSI=-92
          16589 RFM69:CSMA:RSSI=-93
          16593 RFM69:CSMA:RSSI=-91
          16600 RFM69:CSMA:RSSI=-93
          16604 RFM69:CSMA:RSSI=-93
          16610 RFM69:CSMA:RSSI=-91
          16614 RFM69:CSMA:RSSI=-92
          16618 RFM69:CSMA:RSSI=-93
          16624 RFM69:CSMA:RSSI=-93
          16628 RFM69:CSMA:RSSI=-95
          16632 RFM69:CSMA:RSSI=-90
          16639 RFM69:CSMA:RSSI=-93
          16643 RFM69:CSMA:RSSI=-93
          16649 RFM69:CSMA:RSSI=-92
          That implies bad radio-levels, right?
          • MasMatM MasMat
                    |___/                      2.3.1
            53 MCO:BGN:BFR
            2082 TSM:INIT
            2086 TSF:WUR:MS=0
            2088 RFM69:INIT
            2117 TSM:FPAR
            4157 TSM:FPAR
            6195 TSM:FPAR:OK
            6197 TSM:ID
            6199 TSM:ID:OK
            6203 TSM:UPL
            7061 TSM:UPL:OK
            @masmat -46 rssi is very good signal.
            Csma measures high noise level. I’m on mobile now but Search the forum for MY_RFM69_CSMA_LIMIT_DBM
            https://www.mysensors.org/apidocs/group__RFM69Newgrp.html#gaa39d55e3916acaee71754c676b6fc048
              MasMatM
              MasMatM
              MasMat
              @mfalkvidd OK, I did research that a little bit.
              If the signal is good, why all the NACKs?
              This?
              • MasMatM MasMat
                This?
                @masmat nack happens either because the receiver is unable to hear the message, or because the ack from the receiver is not heard by the sender.
                  MasMatM
                  MasMatM
                  MasMat
                  @mfalkvidd What could be causing it? The two are in the same room 2m apart.
                  I have "overpowered" gw (wall wart) and node (usb+battery) to make sure power wouldnt again be the typical culprit here. Also re-verified all connections.
                  Built extra sensor too but thats not working at all (gotta re-check solders etc again and bootloader&sketch upload).
                  • MasMatM MasMat
                    @masmat first step would be to check the logs from the gateway to see which part fails.
                    The most common cause for problems are unstable power, unstable power and unstable power - in that order ;-) See the troubleshooting guide at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ if you haven't already.
                    • K
                      K
                      kimot
                      Try my 100% working testing setup:
                      Wemos D1 gateway:
                       * Version 1.0 - Henrik EKblad
                       * Contribution by Ivo Pullens (ESP8266 support)
                       * The EthernetGateway sends data received from sensors to the WiFi link.
                       * VERA CONFIGURATION:
                       * LED purposes:
                       * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
                       * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                       * nRF24L01+  ESP8266
                       * VCC        VCC
                       * CE         GPIO4
                       * CSN/CS     GPIO15
                       * SCK        GPIO14
                       * MISO       GPIO12
                       * MOSI       GPIO13
                       * GND        GND
                        * Inclusion mode button:
                      #define MY_BAUD_RATE 9600
                      //#define MY_RADIO_NRF24
                      #define MY_RADIO_RFM69
                      #define MY_IS_RFM69HW // Omit if your RFM is not "H"
                      #define MY_RF69_IRQ_PIN D1
                      #define MY_RFM69_CS_PIN D8 // NSS. Use MY_RF69_SPI_CS for older versions (before 2.2.0)
                      //#define MY_RADIO_RFM95
                      #define MY_GATEWAY_ESP8266
                      #define MY_ESP8266_SSID "SSID"
                      #define MY_ESP8266_PASSWORD "password"
                      // Enable UDP communication
                      //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                      //#define MY_ESP8266_HOSTNAME "sensor-gateway"
                      #define MY_IP_ADDRESS 192,168,1,252
                      #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
                      #define MY_PORT 5003
                      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 17
                      // Enable inclusion mode
                      // Set blinking period
                      // Flash leds on rx/tx/err
                      #if defined(MY_USE_UDP)
                      #include <WiFiUdp.h>
                      #include <ESP8266WiFi.h>
                      Node - motion sensor:
                       * Version 1.0 - Henrik Ekblad
                      // Enable debug prints
                      // RFM69
                      //#define MY_RFM69_NEW_DRIVER   // ATC on RFM69 works only with the new driver (not compatible with old=default driver)
                      //#define MY_RFM69_ATC_TARGET_RSSI_DBM (-70)  // target RSSI -70dBm
                      //#define MY_RFM69_MAX_POWER_LEVEL_DBM (10)   // max. TX power 10dBm = 10mW
                      // RFM95
                      //#define MY_RFM95_ATC_TARGET_RSSI_DBM (-70)  // target RSSI -70dBm
                      //#define MY_RFM95_MAX_POWER_LEVEL_DBM (10)   // max. TX power 10dBm = 10mW
                      #define MY_NODE_ID 20
                      uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                      // Initialize motion message
                      	pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);      // sets the motion sensor digital pin as input
                      	sendSketchInfo("Motion Sensor 2", "1.0");
                      	present(CHILD_ID, S_MOTION);
                      	// Read digital motion value
                      	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                      	Serial.println(tripped);
                      Antena - piece of wire on both sides.
                      Receiving distance - min 60m ( gateway at home, sensor in garden )
                      12.5k
