  3. Sensor for Vallox DigitSE RS485 ventilation system with integration into FHEM.
rs485valloxfhem
36 Posts 12 Posters 27.7k Views 12 Watching
  • HeinzH
    HeinzH
    Heinz
    My house contains an air ventilation system from the company vallox. The controller of this device is an old school wall mounted micky-mouse-button device with an ugly LCD display. Using this controller is really annoying and the user expirience is really too much "last-century".
    The mission was to have the display data as well as the control buttons on my tablet. Another unflexible thing is the so-called boost-switch which can be pressed right before you have a shower. The switch makes the ventilation system run on max for 45minutes. if somebody accidentaly pressed the button in the midnight thinking it is a light-switch, the ventilation started roaring for 45minutes. I finally had to get up from bed walk downstairs and switch the system off to find some sleep again. This should also be a problem of the past. The idea was to handle the button using my new mysensors device. One click should start the ventilation for 45minutes, two clicks for 30minutes and a long click should stop the boost mode. I want to be able to interrupt the boost switch mode even from my iphone...
    I will post some pictures of the project the next days together with some details. I uploaded the library to control the vallox device via RS485 together with a mysensors sketch at: https://github.com/windkh/valloxserial.git
    The sensor uses around 40 different child sensors as the vallox device offers so many different data.
    ... to be continued
    RJ_MakeR 1 Reply Last reply
    • HeinzH Heinz
      ... to be continued
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @Heinz Holy cow 40? I bet that took a while..
      RJ_Make
      • HeinzH
        HeinzH
        Heinz
        wrote on last edited by Heinz
        This is the original controller of the ventilation system. It displays the fan speed as well as the 4 temperatures: incomming air, exhaust air, inside temp, outside temp. You can control the fan speed level 1-8 by pressing the up and down buttons.
        The controller communicates with the main device via a RS485 bus. To read the data sent between both parties I used an arduino mega as it has more than one hardware serial lines. This leads to less corrupt telegrams when communicating via RS485. You need at least one RS485 to TTL converter. As I had two of em I used one for sending and one for receiving telegrams:
        I had to develop a serial library that is able to interpret the vallox protocol. The protocol description can be found here:
        http://knx-user-forum.de/gebaeudetechnik-ohne-knx-eib/18274-vallox-rs485-schnittstellenbeschreibung.html
        The library is used by the vallox-sensor-sketch to retrieve the data from the RS485 bus. The variables are send to the mysensors controller as different sensor values (41 different variables!).
        integration into FHEM was very easy. The following picture shows the most important variables and their readings. I did not import the other ones as I do not have any original CO2 Sensor nor humidty sensors attached.
        I also added some buttons to FHEM to make controlling of the vallox device easier:
        Inspired by samppa I added some calculations for efficiency of the heat exchanger see also
        http://forum.mysensors.org/topic/38/measuring-efficiency-of-home-air-ventilation-heat-exchanger-unit/3
        The fan speed can be controlled by any tablet or phone in my house now. If somebody accidentally pushes the boost switch in the shower in the night it does not bother me any longer. I can easily turn it off using my iPhone ;)
        • HeinzH
          HeinzH
          Heinz
          Code for integration of the sensor into FHEM:
          define MYSENSOR_Vallox MYSENSORS_DEVICE 100
          attr MYSENSOR_Vallox IODev MYSENSOR_Gateway
          attr MYSENSOR_Vallox alias digitSE
          attr MYSENSOR_Vallox group MySensors
          attr MYSENSOR_Vallox icon vent_ventilation_control
          attr MYSENSOR_Vallox mapReading_BoostSwitch 40 dimmer
          attr MYSENSOR_Vallox mapReading_CO2AdjustState 9 value1
          attr MYSENSOR_Vallox mapReading_DCFanInputAdjustment 26 dimmer
          attr MYSENSOR_Vallox mapReading_DCFanOutputAdjustment 27 dimmer
          attr MYSENSOR_Vallox mapReading_EfficiencyAverage 7 value1
          attr MYSENSOR_Vallox mapReading_EfficiencyIn 5 value1
          attr MYSENSOR_Vallox mapReading_EfficiencyOut 6 value1
          attr MYSENSOR_Vallox mapReading_FanSpeed 0 dimmer
          attr MYSENSOR_Vallox mapReading_FanSpeedMax 24 dimmer
          attr MYSENSOR_Vallox mapReading_FanSpeedMin 25 dimmer
          attr MYSENSOR_Vallox mapReading_FaultIndicator 14 value1
          attr MYSENSOR_Vallox mapReading_FilterGuardIndicator 12 value1
          attr MYSENSOR_Vallox mapReading_HeatingIndicator 13 value1
          attr MYSENSOR_Vallox mapReading_HeatingState 11 value1
          attr MYSENSOR_Vallox mapReading_HumidityAdjustState 10 value1
          attr MYSENSOR_Vallox mapReading_InputFanStopThreshold 28 temperature
          attr MYSENSOR_Vallox mapReading_PowerState 8 value1
          attr MYSENSOR_Vallox mapReading_ServiceReminderIndicator 15 value1
          attr MYSENSOR_Vallox mapReading_TempExhaust 3 temperature
          attr MYSENSOR_Vallox mapReading_TempIncomming 4 temperature
          attr MYSENSOR_Vallox mapReading_TempInside 1 temperature
          attr MYSENSOR_Vallox mapReading_TempOutside 2 temperature
          attr MYSENSOR_Vallox mode node
          attr MYSENSOR_Vallox room Sensoren
          attr MYSENSOR_Vallox setReading_BoostSwitch slider,0,1,60
          attr MYSENSOR_Vallox setReading_DCFanInputAdjustment slider,1,1,100
          attr MYSENSOR_Vallox setReading_DCFanOutputAdjustment slider,1,1,100
          attr MYSENSOR_Vallox setReading_FanSpeed slider,1,1,8
          attr MYSENSOR_Vallox setReading_FanSpeedMax slider,1,1,8
          attr MYSENSOR_Vallox setReading_FanSpeedMin slider,1,1,8
          attr MYSENSOR_Vallox stateFormat {sprintf "Lüfterstufe: %d  Zuluft: %.0f  Abluft: %.0f  Außen: %.0f  Innen: %.0f", ReadingsVal($name,     "FanSpeed", 0), ReadingsVal($name, "TempIncomming", 0), ReadingsVal($name, "TempExhaust", 0), ReadingsVal($name, "TempOutside", 0), ReadingsVal($name, "TempInside", 0)}
          attr MYSENSOR_Vallox version 1.4.1
          #attr MYSENSOR_Vallox mapReading_Humidity 16 humidity
          #attr MYSENSOR_Vallox mapReading_BasicHumidityLevel 17 humidity
          #attr MYSENSOR_Vallox mapReading_HumiditySensor1 18 humidity
          #attr MYSENSOR_Vallox mapReading_HumiditySensor2 19 humidity
          #attr MYSENSOR_Vallox mapReading_CO2High 20 value1
          #attr MYSENSOR_Vallox mapReading_CO2Low 21 value1
          #attr MYSENSOR_Vallox mapReading_CO2SetPointHigh 22 value1
          #attr MYSENSOR_Vallox mapReading_CO2SetPointLow 23 value1
          #attr MYSENSOR_Vallox mapReading_HeatingSetPoint 29 temperature
          #attr MYSENSOR_Vallox mapReading_PreHeatingSetPoint 30 temperature
          #attr MYSENSOR_Vallox mapReading_HrcBypassThreshold 31 temperature
          #attr MYSENSOR_Vallox mapReading_CellDefrostingThreshold 32 temperature
          #attr MYSENSOR_Vallox mapReading_AdjustmentIntervalMinutes 33 value1
          #attr MYSENSOR_Vallox mapReading_AutomaticHumidityLevelSeekerState 34 value1
          #attr MYSENSOR_Vallox mapReading_BoostSwitchMode 35 value1
          #attr MYSENSOR_Vallox mapReading_RadiatorType 36 value1
          #attr MYSENSOR_Vallox mapReading_CascadeAdjust 37 value1
          #attr MYSENSOR_Vallox mapReading_MaxSpeedLimitMode 38 value1
          #attr MYSENSOR_Vallox mapReading_ServiceReminder 39 value1
          You can see that I commented out the CO2 Sensor and the humidity sensor ones.
          To control the device you need some further controls:
          define MYSENSOR_Vallox_FanSpeed dummy
          attr MYSENSOR_Vallox_FanSpeed alias Lüfterstufe
          attr MYSENSOR_Vallox_FanSpeed devStateIcon 1:rc_1 2:rc_2 3:rc_3 4:rc_4 5:rc_5 6:rc_6 7:rc_7 8:rc_8
          attr MYSENSOR_Vallox_FanSpeed group Lüftung
          attr MYSENSOR_Vallox_FanSpeed icon vent_ventilation_control
          attr MYSENSOR_Vallox_FanSpeed room Lüftung
          attr MYSENSOR_Vallox_FanSpeed setList state:slider,1,1,8
          attr MYSENSOR_Vallox_FanSpeed webCmd state
          define MYSENSOR_Vallox_FanSpeed_Notify notify MYSENSOR_Vallox:FanSpeed:.* { my $d =   ReadingsVal("MYSENSOR_Vallox","FanSpeed", 1);; fhem("set MYSENSOR_Vallox_FanSpeed $d");;}
          define MYSENSOR_Vallox_FanSpeed_Notify2 notify MYSENSOR_Vallox_FanSpeed set MYSENSOR_Vallox FanSpeed %
          define MYSENSOR_Vallox_BoostSwitch dummy
          attr MYSENSOR_Vallox_BoostSwitch alias Stoßlüftung
          attr MYSENSOR_Vallox_BoostSwitch devStateIcon 0:vent_ventilation_level_0 15:vent_ventilation_level_1 30:vent_ventilation_level_2     45:vent_ventilation_level_3
          attr MYSENSOR_Vallox_BoostSwitch eventMap aus:0 kurz:15 mittel:30 lang:45
          attr MYSENSOR_Vallox_BoostSwitch group Lüftung
          attr MYSENSOR_Vallox_BoostSwitch icon vent_ventilation_level_manual_m
          attr MYSENSOR_Vallox_BoostSwitch room Lüftung
          attr MYSENSOR_Vallox_BoostSwitch setList state:aus,kurz,mittel,lang
          attr MYSENSOR_Vallox_BoostSwitch webCmd state
          define MYSENSOR_Vallox_BoostSwitch_Notify notify MYSENSOR_Vallox_BoostSwitch set MYSENSOR_Vallox BoostSwitch %
          define MYSENSOR_Vallox_BoostSwitch_Time dummy
          attr MYSENSOR_Vallox_BoostSwitch_Time alias Stoßlüftung min
          attr MYSENSOR_Vallox_BoostSwitch_Time group Lüftung
          attr MYSENSOR_Vallox_BoostSwitch_Time icon time_timer
          attr MYSENSOR_Vallox_BoostSwitch_Time room Lüftung
          define MYSENSOR_Vallox_BoostSwitch_Time_Notify notify MYSENSOR_Vallox:BoostSwitch:.* { my $d = sprintf ("%%.0f min", ReadingsVal("MYSENSOR_Vallox","BoostSwitch", 0));; fhem("set MYSENSOR_Vallox_BoostSwitch_Time $d");;}
          define MYSENSOR_Vallox_TempInside dummy
          attr MYSENSOR_Vallox_TempInside alias Temperatur Abluft
          attr MYSENSOR_Vallox_TempInside event-on-change-reading state
          attr MYSENSOR_Vallox_TempInside group Temperaturen
          attr MYSENSOR_Vallox_TempInside icon vent_used_air
          attr MYSENSOR_Vallox_TempInside room Lüftung
          define MYSENSOR_Vallox_TempInside_Notify notify MYSENSOR_Vallox:TempInside:.* { my $d = sprintf ("%%.0f C",     ReadingsVal("MYSENSOR_Vallox","TempInside", 0));; fhem("set MYSENSOR_Vallox_TempInside $d");;}
          define MYSENSOR_Vallox_TempOutside dummy
          attr MYSENSOR_Vallox_TempOutside alias Temperatur Frischluft
          attr MYSENSOR_Vallox_TempOutside event-on-change-reading state
          attr MYSENSOR_Vallox_TempOutside group Temperaturen
          attr MYSENSOR_Vallox_TempOutside icon vent_ambient_air
          attr MYSENSOR_Vallox_TempOutside room Lüftung
          define MYSENSOR_Vallox_TempOutside_Notify notify MYSENSOR_Vallox:TempOutside:.* { my $d = sprintf ("%%.0f C", ReadingsVal("MYSENSOR_Vallox","TempOutside", 0));; fhem("set MYSENSOR_Vallox_TempOutside $d");;}
          define MYSENSOR_Vallox_TempExhaust dummy
          attr MYSENSOR_Vallox_TempExhaust alias Temperatur Fortluft
          attr MYSENSOR_Vallox_TempExhaust event-on-change-reading state
          attr MYSENSOR_Vallox_TempExhaust group Temperaturen
          attr MYSENSOR_Vallox_TempExhaust icon vent_exhaust_air
          attr MYSENSOR_Vallox_TempExhaust room Lüftung
          define MYSENSOR_Vallox_TempExhaust_Notify notify MYSENSOR_Vallox:TempExhaust:.* { my $d = sprintf ("%%.0f C", ReadingsVal("MYSENSOR_Vallox","TempExhaust", 0));; fhem("set MYSENSOR_Vallox_TempExhaust $d");;}
          define MYSENSOR_Vallox_TempIncomming dummy
          attr MYSENSOR_Vallox_TempIncomming alias Temperatur Zuluft
          attr MYSENSOR_Vallox_TempIncomming event-on-change-reading state
          attr MYSENSOR_Vallox_TempIncomming group Temperaturen
          attr MYSENSOR_Vallox_TempIncomming icon vent_supply_air
          attr MYSENSOR_Vallox_TempIncomming room Lüftung
          define MYSENSOR_Vallox_TempIncomming_Notify notify MYSENSOR_Vallox:TempIncomming:.* { my $d = sprintf ("%%.0f C", ReadingsVal("MYSENSOR_Vallox","TempIncomming", 0));; fhem("set MYSENSOR_Vallox_TempIncomming $d");;}
          define MYSENSOR_Vallox_EfficiencyIn dummy
          attr MYSENSOR_Vallox_EfficiencyIn alias Effizienz Eingang
          attr MYSENSOR_Vallox_EfficiencyIn event-on-change-reading state
          attr MYSENSOR_Vallox_EfficiencyIn group Auswertung
          attr MYSENSOR_Vallox_EfficiencyIn icon vent_ambient_air
          attr MYSENSOR_Vallox_EfficiencyIn room Lüftung
          define MYSENSOR_Vallox_EfficiencyIn_Notify notify MYSENSOR_Vallox:EfficiencyIn:.* { my $d = sprintf ("%%.0f \%%", ReadingsVal("MYSENSOR_Vallox","EfficiencyIn", 0));; fhem("set MYSENSOR_Vallox_EfficiencyIn $d");;}
          define MYSENSOR_Vallox_EfficiencyOut dummy
          attr MYSENSOR_Vallox_EfficiencyOut alias Effizienz Ausgang
          attr MYSENSOR_Vallox_EfficiencyOut event-on-change-reading state
          attr MYSENSOR_Vallox_EfficiencyOut group Auswertung
          attr MYSENSOR_Vallox_EfficiencyOut icon vent_exhaust_air
          attr MYSENSOR_Vallox_EfficiencyOut room Lüftung
          define MYSENSOR_Vallox_EfficiencyOut_Notify notify MYSENSOR_Vallox:EfficiencyOut:.* { my $d = sprintf ("%%.0f \%%", ReadingsVal("MYSENSOR_Vallox","EfficiencyOut", 0));; fhem("set MYSENSOR_Vallox_EfficiencyOut $d");;}
          define MYSENSOR_Vallox_EfficiencyAverage dummy
          attr MYSENSOR_Vallox_EfficiencyAverage alias Effizienz
          attr MYSENSOR_Vallox_EfficiencyAverage event-on-change-reading state
          attr MYSENSOR_Vallox_EfficiencyAverage group Auswertung
          attr MYSENSOR_Vallox_EfficiencyAverage icon vent_bypass
          attr MYSENSOR_Vallox_EfficiencyAverage room Lüftung
          define MYSENSOR_Vallox_EfficiencyAverage_Notify notify MYSENSOR_Vallox:EfficiencyAverage:.* { my $d = sprintf ("%%.0f \%%", ReadingsVal("MYSENSOR_Vallox","EfficiencyAverage", 0));; fhem("set MYSENSOR_Vallox_EfficiencyAverage $d");;}
          • HeinzH
            HeinzH
            Heinz
            BTW finding an appropriate housing for your sensors is not very easy. Housings should be nice and fit into their environment. Therefore I put my gateway in a sporty metal adidas housing:
            Later if found a sticker at the bottom of the box: "medium impact sports bra"!
            Oups!
            BulldogLowellB DwaltD 2 Replies Last reply
            • HeinzH Heinz
              Oups!
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              I'd be worried about shorting against the walls of the can, and shielding my RF signals... But if it works and you like it... well there you go!
              • HeinzH
                HeinzH
                Heinz
                there is an external antenna for the radio...
                • HeinzH Heinz
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @Heinz
                  Ha!
                  looked like a cable to me at first glance!!
                  • HeinzH Heinz
                    Oups!
                    DwaltD
                    DwaltD
                    Dwalt
                    @Heinz said:
                    BTW finding an appropriate housing for your sensors is not very easy. Housings should be nice and fit into their environment...
                    Hiding sensors in plain sight:
                    One of my "Book-Sensors":
                    • HeinzH
                      HeinzH
                      Heinz
                      The old book trick... very nice!
                      • HeinzH
                        HeinzH
                        Heinz
                        After some months of testing a little update:
                        I received some e-mails questioning the so called "heat recovery cell bypass" mode. There is a damper inside the device that can
                        is switched automatically by the vallox-controller to bypass the heat recovery cell (HRC) to avoid heating up the house during the
                        summer months. Well, when you open the device on a hot summer day you will probably see the damper in an obvious wrong position:
                        the air does not bypass the HRC! Huh! whats wrong here?
                        Explanation:
                        The device tries to cool down the incoming air by leading it through the HRC which is still colder than the temperature outside. If the temperature outside is colder than the air inside the house the damper is switched to the expected position. There are two things to you have to do to make all that work correctly:
                        • turn off heating mode (the LED of the left most button on your control device must be off)
                        • the HRC bypass temperature must be set to a value below the outside temperature (e.g. 14 degrees)
                        To illustrate that effect I logged the temperatures in FHEM:
                        Sorry for the german labels.
                        The first plot shows the damper position: blue background: HRC bypass is active.
                        The second plot shows the temperature outside the house (blue) and the temperature inside the house (red)
                        As soon as the temperature outside is greater than the temperature inside the HRC bypass is deactivated to cool the incoming air by leading the air through the "colder" HRC.
                        The fourth diagram shows the temperature of the air that is entering the rooms (purple) and the temperature outside the house (blue).
                        You can see that the fresh air entering the rooms is lower than the temperature outside: the cooling effect works (even if it is only few degrees)
                        To all guys thinking about how to control the damper on their own logic from a raspi or arduino. This is not neccessary as the vallox logic works very well.
                        m26872M 1 Reply Last reply
                        • HeinzH
                          HeinzH
                          Heinz
                          Some people asked if the library is able to control other parameters than the fan speed. The answer is yes. The following screenshot shows my sliders and buttons in FHEM:
                          Sorry for the german labels again:
                          The first group shows the power state (ON/OFF), the heating-state (winter season=ON, summer season=OFF) and the HRC damper position (inactive=OFF). See last post.
                          The second group shows some alerts (none at the moment)
                          the third group shows a button to switch between summer and winter season. The sliders control some temperature thresholds and other parameters.
                          If you want to have a look at the bus data yourself you can download my sniffer tool which is a .Net port of the serial library described above under valloxserial.net
                          • HeinzH Heinz
                            Explanation:
                            m26872M
                            m26872M
                            m26872
                            @Heinz What Fhem plot style and font are you using?
                            • HeinzH
                              HeinzH
                              Heinz
                              @m26872
                              I modified the dark style. If you need the files I will upload em with a description how to integrate those.
                              • HeinzH Heinz
                                @m26872
                                m26872M
                                m26872M
                                m26872
                                @Heinz Yes please! I really liked those plots.
                                I wouldn't mind it in german (as usual with Fhem stuff), but it's a lot easier for me with english.
                                • HeinzH
                                  HeinzH
                                  Heinz
                                  @m26872
                                  I simply copied the dark style of FHEM and named it dark2:
                                  copy the following files to your FHEM subfolder www/pgm2
                                  dark2style.css
                                  dark2svg_defs.svg
                                  dark2svg_style.css
                                  In your FHEM.cfg select this style for your WEB Frontend e.g.:
                                  define WEB FHEMWEB 8083 global
                                  attr WEB stylesheetPrefix dark2
                                  That's it.
                                  If you want to have other plot colours edit the files starting with dark2svg... I think it is self explaining.
                                  • HeinzH
                                    HeinzH
                                    Heinz
                                    For those who want to have the FHEM files here they are:
                                    _MYSENSOR_Vallox.cfg
                                    simply place the file in FHEM's subfolder FHEM and include it your fhem.cfg:
                                    include ./FHEM/_MYSENSOR_Vallox.cfg
                                    And here are the plot files which have to be placed in the subfolder www\gplot
                                    SVG_FileLog_Vallox_6.gplot
                                    SVG_FileLog_Vallox_5.gplot
                                    SVG_FileLog_Vallox_4.gplot
                                    SVG_FileLog_Vallox_3.gplot
                                    SVG_FileLog_Vallox_2.gplot
                                    SVG_FileLog_Vallox_1.gplot
                                    You will likely have to adapt the room and group names, and of course the german names, sorry for that.
                                    m26872M ausbremenA 3 Replies Last reply
                                    • HeinzH Heinz
                                      m26872M
                                      m26872M
                                      m26872
                                      @Heinz
                                      Nice! Now I really want to buy a Vallox ... (and a house...)
                                      • SkjallS
                                        SkjallS
                                        Skjall
                                        Moin @Heinz,
                                        is it possible to use a RS485 USB-Stick (http://shop.in-circuit.de/product_info.php?cPath=38&products_id=81) instead of this construction? I've tried it with your .net Sniffer on my Windows PC and it worked well.
                                        Skjall
                                        • HeinzH
                                          HeinzH
                                          Heinz
                                          You can use this rs485 to usb adapter to control the vallox device, no problem there. But do you intend to use your windows pc as controller then? Or do you want to use the stick directly with fhem? this would require some software which takes the serial telegrams and imports the values into fhem... or any other homeautomation controller.
