  3. Auto resend on NACK
Auto resend on NACK
23 Posts 6 Posters 5.6k Views 6 Watching
  • electrikE
    electrikE
    electrik
    @skywatch said in Auto resend on NACK:
    @electrik & @Marek - Are you both sure about that? It seems to me that both those statements are doing what was intended.
    Now that I see it again, I'm not so sure anymore actually.
    In your code you used the variable msg. That should be one of msgFgeHum, msgFgeTemp, msgFzrHum, msgFzrTemp.
    That is why the compiler complains msg is unknown.
    You also enabled the ack message, this is just a software acknowledge, while the send function returns the status of the hardware acknowledge. So if you check with
    if (send(msgFgeHum.set(fgehum),true))
    // this is sent ok
    // sending failed
    you check if the hardware acknowledge was successful. The software ack should be tested differently and some more logic is needed for it.
    Hope this helps
    • alowhumA
      alowhumA
      alowhum
      @electrik Is this a correct understanding?
      • Hardware ACK is just that is reaches the next node in the network, right? It could be a repeater saying "I got something from you". It doesn't 100% guarantee that it reached the controller correctly.
      • Software ACK is the controller sending back the exact same message you sent, but this time with the ACK bit set to true? It goes up and down your entire network. It's the best way to be sure that the message reached the controller, since you could theoretically even check if the message details are still the same as when you sent it.
      Both will happen when you set ACK to true in your send() function?
      So:
      if (send(msgFgeHum.set(fgehum),true)) is just checking the hardware ACK, meaning it got sent away ok.
      And then for software ACK you should use the receive function to check for a returning "echo" message:
        Serial.print("Incoming message for child: ");
        if (message.isAck() && message.sensor == RELAY_1_CHILD_ID) { // We got the ACK!
          Serial.println("- Received ACK for relay");
          retryCounter = 0;
      Is this a correct summary?
      • alowhumA
        alowhumA
        alowhum
        As a quick follow-up: is this a message stating that the hardware ACK failed?
        362547 !TSF:MSG:SEND,27-27-0-0,s=3,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=NACK:120
        • alowhumA alowhum
          @alowhum yes
          • electrikE
            electrikE
            electrik
            @alowhum said in Auto resend on NACK:
            Yes exactly
            Yes
            Yes correct again
            I didn't use the software ack myself but I think this last point is also correct.
            • alowhumA alowhum
              So:
                  retryCounter = 0;
              This is incorrect. Setting ACK to true in the send() function will enable software ACK.
              Hardware ACK is not affected by the vale of ACK in the send() function.
              • alowhumA
                alowhumA
                alowhum
                @mfalkvidd Then how is hardware ACK enabled? I that what you enable in the presentation?
                present(TEXT_CHILD_ID, S_INFO, F("Status"),true);
                I always thought that enabling it in presentation() just means you didn't have to do it manually anymore, that it would be done for all messages of that child.
                Or it hardware ACK always on? And it's just a matter of whether you use the return of the send function or not?
                • alowhumA alowhum
                  Exactly.
                  There might be some way to turn it off, but I don't know how.
                  • alowhumA
                    alowhumA
                    alowhum
                    While we're on the subject: is there any built-in retry functionality for the hardware and/or software ACK? I believe if you set the ACK bit in the send function, then the hardware ACK will try to re-send the message a few times? I seem to remember seeing the ft value increase by one each time after a NACK.
                    2070 TSF:MSG:SEND,27-27-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    I suspect this hardware-retry only works if you set the ACK to true?
                    And another one:
                    Does the isTransportReady() function check..
                    A. If the radio works
                    B. If there is a connection to a neighbour (repeater or gateway)
                    C. If a handshake had been made with the controller
                      if(isTransportReady()){
                        Serial.println(F("Connected to gateway!"));
                      else {
                        Serial.println(F("! NO CONNECTION"));
                    • alowhumA alowhum
                      And another one:
                        else {
                      @alowhum again, setting the ACK parameter in the send call will NEVER affect hardware ack.
                      For nrf24, up to 15 retries will be done by the hardware ack.
                      • mfalkviddM
                        isTransportReady will return true if the node has seen a valid route to the gateway and there have been fewer than MY_TRANSPORT_MAX_TSM_FAILURES transport failures since the node saw the valid route. I do not know what constitutes a transport failure though. I think "Failed uplink counter" (ft= in the log) is the counter that's used for comparison.
                        The controller is not involved in isTransportReady
                        So maybe something between B and C.
                        • alowhumA
                          alowhumA
                          alowhum
                          @mfalkvidd Thank you so much for the explanation! I feel I'm getting a grasp on things.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            @mfalkvidd said in Auto resend on NACK:
                            https://forum.mysensors.org/post/33832
                            Would someone be kind enough to point me in the direction of a good software acknowledgement example? I've been building MySensors for 4 years and still have sensors that don't send reliable messages. While most have been replaced with ESP's - these sensors are extremely remote and battery powered (MySensors wins here!).
                            Currently I use:
                            void resend(MyMessage &msg, int repeats) {
                                    int repeat = 1;
                                    const int repeatDelay = 100;
                                    boolean sendOK = false;
                                    while ((sendOK == false) and (repeat <= repeats)) {
                                            if (send(msg) == true) {
                                                    sendOK = true;
                                                    sendOK = false;
                                                    #ifdef MY_DEBUG
                                                    Serial.print(F("Send error: "));
                                                    Serial.println(repeat);
                                                    repeat++;
                                                    wait(repeatDelay);
                            But this doesn't seem to ensure reliable delivery (some nodes send 10 msgs before sleeping). Often I get multiple messages arriving (I assume this is the burst), but some (often vital) never make it.
                            • electrikE
                              electrikE
                              electrik
                              You will get multiple messages, if the message arrives correctly but the hardware ACK doesn't.
                              Do you have a repeater in between the sender and gateway? It could be that the repeater does receive the initial message (and the sensor gets a hardware ACK), but that never reaches the gateway because of a transmission error between the repeater and the gateway.
                              12.5k
