  3. Sensebender multiple controller
6 Posts 3 Posters 1.2k Views 3 Watching
  • R Offline
    R Offline
    rafael156
    wrote on last edited by rafael156
    Hello!
    How is it possible to operate two controllers simultaneously with one Sensebender Gateway?
    i have this sketch on the sensebender, but i can only connect openhab OR mycontroller.org, not both at the same time.
    The last controller that connects to the sensebender gets the data. the other one doesn't.
    Is this due to the sketch?
     * Copyright (C) 2013-2018 Sensnology AB
     * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
     * Version 1.0 - Henrik EKblad
     * LED purposes:
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
    //@changed
    // Define sketch version
    #define SKETCH_VERSION "0.4"
    //@changed
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    #define MY_GATEWAY_MAX_CLIENTS  3
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 192,168,1,110
    #define MY_PORT 5003
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS XXXXXXXXXXX
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    //@changed
    #include <SD.h>
    #include <drivers/ATSHA204/ATSHA204.cpp>
    Sd2Card card;
    #define EEPROM_VERIFICATION_ADDRESS 0x01
    static uint8_t num_of_leds = 5;
    static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
    //@changed
     sleep(250);      // wait for the W5100
    //@changed
    void preHwInit()
      pinMode(MY_SWC1, INPUT_PULLUP);
      pinMode(MY_SWC2, INPUT_PULLUP);
      if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
        return;
      uint8_t tests = 0;
      for (int i=0; i< num_of_leds; i++) {
        pinMode(leds[i], OUTPUT);
      if (digitalRead(MY_SWC1)) {
        uint8_t led_state = 0;
        while (!Serial) {
          digitalWrite(LED_BLUE, led_state);
          led_state ^= 0x01;
          delay(500);
        } // Wait for USB to be connected, before spewing out data.
      digitalWrite(LED_BLUE, LOW);
      if (Serial) {
        Serial.println("Sensebender GateWay test routine");
        Serial.print("MySensors core version : ");
        Serial.println(MYSENSORS_LIBRARY_VERSION);
        Serial.print("GateWay sketch version : ");
        Serial.println("----------------------------------");
        Serial.println();
      if (testSha204()) {
        digitalWrite(LED_GREEN, HIGH);
        tests++;
      if (testSDCard()) {
        digitalWrite(LED_YELLOW, HIGH);
        tests++;
      if (testEEProm()) {
        digitalWrite(LED_ORANGE, HIGH);
        tests++;
      if (testAnalog()) {
        digitalWrite(LED_BLUE, HIGH);
        tests++;
      if (tests == 4) {
        while(1) {
          for (int i=0; i<num_of_leds; i++) {
            digitalWrite(leds[i], HIGH);
            delay(200);
            digitalWrite(leds[i], LOW);
        while (1) {
          digitalWrite(LED_RED, HIGH);
          delay(200);
          digitalWrite(LED_RED, LOW);
          delay(200);
    bool testSha204()
      uint8_t ret_code;
      if (Serial) {
        Serial.print("- > SHA204 ");
      atsha204_init(MY_SIGNING_ATSHA204_PIN);
      ret_code = atsha204_wakeup(rx_buffer);
      if (ret_code == SHA204_SUCCESS) {
        ret_code = atsha204_getSerialNumber(rx_buffer);
          if (Serial) {
            Serial.println(F("Failed to obtain device serial number. Response: "));
          if (Serial) {
            Serial.print(F("Ok (serial : "));
            for (int i=0; i<9; i++) {
              if (rx_buffer[i] < 0x10) {
              Serial.print(rx_buffer[i], HEX);
            Serial.println(")");
          return true;
        if (Serial) {
          Serial.println(F("Failed to wakeup SHA204"));
      return false;
    bool testSDCard()
      if (Serial) {
        Serial.print("- > SD CARD ");
      if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
        if (Serial) {
          Serial.println("SD CARD did not initialize!");
        if (Serial) {
          Serial.print("SD Card initialized correct! - ");
          Serial.print("type detected : ");
          switch(card.type()) {
          case SD_CARD_TYPE_SD1:
            Serial.println("SD1");
          case SD_CARD_TYPE_SD2:
            Serial.println("SD2");
          case SD_CARD_TYPE_SDHC:
            Serial.println("SDHC");
          default:
            Serial.println("Unknown");
        return true;
      return false;
    bool testEEProm()
      uint8_t eeprom_d1, eeprom_d2;
      SerialUSB.print(" -> EEPROM ");
      eeprom_d1 = hwReadConfig(EEPROM_VERIFICATION_ADDRESS);
      delay(500);
      eeprom_d1 = ~eeprom_d1; // invert the bits
      hwWriteConfig(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
      delay(500);
      eeprom_d2 = hwReadConfig(EEPROM_VERIFICATION_ADDRESS);
      if (eeprom_d1 == eeprom_d2) {
        SerialUSB.println("PASSED");
        hwWriteConfig(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
        return true;
      SerialUSB.println("FAILED!");
      return false;
    bool testAnalog()
      int bat_detect = analogRead(MY_BAT_DETECT);
      Serial.print("-> analog : ");
      Serial.print(bat_detect);
      if (bat_detect < 400 || bat_detect > 650) {
        Serial.println(" Failed");
        return false;
      Serial.println(" Passed");
      return true;
    //@changed```
    • T Offline
      T Offline
      tbowmo
      I'm not expert on the networking details in the gateway (even though I designed the hardware :) ).
      But if you want to use multiple controllers, I would recommend that you use MQTT as transport layer instead, and then have a mqtt broker, like mosquitto, on your HA server.
      • R Offline
        R Offline
        rafael156
        if i understood everything correctly, only the auto-id feature isn't available in mqtt, right?
        I can still use autodiscovery and ota, right?
        • T Offline
          T Offline
          tbowmo
          To my best knowledge, you should be able to use all the standard features, together with mqtt, including auto-id assignment
          But then again, I have never used OTA yet so I can't tell you if that part works.
          • R Offline
            R Offline
            rafael156
            ok, i tried a username and password for mqtt binding (http://www.steves-internet-guide.com/mqtt-username-password-example/), but getting the error "connection can´t be established".
            Is it a bug? i found several threads with the same failure...
            • M Offline
              M Offline
              mbedarff
              I experience the same behaviour with an ESP8266 wifi gateway. In the MySensors sources I found the reason why this doesn't work:
              In the file core\MyGatewayTransportEthernet.cpp in lines 98 to 106 the ethernet server is initialized:
              #if defined(MY_GATEWAY_CLIENT_MODE)
              EthernetUDP _ethernetServer;
              #endif /* End of MY_USE_UDP */
              #elif defined(MY_GATEWAY_LINUX) /* Elif part of MY_GATEWAY_CLIENT_MODE */
              EthernetServer _ethernetServer(_ethernetGatewayPort, MY_GATEWAY_MAX_CLIENTS);
              #else /* Else part of MY_GATEWAY_CLIENT_MODE */
              EthernetServer _ethernetServer(_ethernetGatewayPort);
              #endif /* End of MY_GATEWAY_CLIENT_MODE */
              For my gateway the last statement without the constant MY_GATEWAY_MAX_CLIENTS is used to define the server. Thus it is clear why only one connection is kept.
              Maybe the ESP8266 examples should be updated. Or the ethernet server code should be reworked. :/
              12.1k
