  3. Candle - signal Hub - A universal 433Mhz signal detector and cloner
29 Posts 4 Posters 9.4k Views 7 Watching
  • alowhumA
    alowhumA
    alowhum
    • It can now handle even more 433 signals.
    • Slight code simplification
    • HomerH
      HomerH
      Homer
      Probably a bit of a noob question, but if I don't have any of the optional items, can I still use this? Will it just save the RF commands until it can't save anymore?
      • alowhumA
        alowhumA
        alowhum
        @Homer yes
        HomerH 1 Reply Last reply
        • alowhumA alowhum
          @Homer yes
          HomerH
          HomerH
          Homer
          @alowhum said in Candle - signal Hub - A universal 433Mhz signal detector and cloner:
          @Homer yes
          Thanks, and thanks for your private messages!
          I managed to build a rf433 sender which is connected to wifi and is outside of the Mysensors environment, and it works, but I can't get my controller (Vera) to communicate with it. This looks like it should work perfectly for what I want it to do!
          Thanks for sharing!
          • HomerH
            HomerH
            Homer
            I am having issues with the device I made myself which doesn't use this code, so I have decided to give this project a go. One problem though... I copied the sketch from you link, and even without any changes or alterations, the sketch doesn't compile. It gets to line 468 and says "detectedMessage" was not declared in this scope.
            • HomerH
              HomerH
              Homer
              Please ignore the above.... I don't know why but I just tried it again and it compiled immediately.
              • HomerH
                HomerH
                Homer
                I just worked out what I did! I had commented that I didn't have a touchsceen and that caused the error. I thought I should do this as I don't have one, but I guess I'll have a go at uploading the sketch as it is.
                • alowhumA
                  alowhumA
                  alowhum
                  Thanks for the feedback. Let me know if you have any issues and I can try to fix them.
                  • alowhumA alowhum
                    HomerH
                    HomerH
                    Homer
                    @alowhum I've finished building this. I have also bought a couple cheap window/door sensors to try, but I've hit a snag.
                    When I joined this to my controller (Vera) it said that it found 2 devices, but when I check my devices I only find one device, and all it says is that it's a node; I have very little in the way of interacting with it. I'm not sure what's going on.... It's weird that it found two devices and only displays one! Seeing that I'm not using any screen, I can't do anything because I thought I could interact with the hub from within my controller. Have I done something wrong?
                    • alowhumA
                      alowhumA
                      alowhum
                      I haven't tested it without a screen myself. I'll look into it for you and see if I can make the code work optimally without it. I'll get back to you with the updated code.
                      • HomerH
                        HomerH
                        Homer
                        Awesome, thanks!!!
                        • alowhumA
                          alowhumA
                          alowhum
                          Here is the new version which should work just fine without a touchscreen attached.
                          https://github.com/createcandle/Devices/blob/master/Signal-hub/Signal-hub.ino
                          I also added a new playlist feature. If multiple replay requests are received in quick succession (perhaps from a home automation rule that wants to trigger multiple sockets), it can remember these requests and replay them one after the other.
                          • HomerH
                            HomerH
                            Homer
                            Awesome, thanks for your work! I'll be giving this a go today.
                            The extra feature of it remembering if multiple commands are given is great too!
                            • HomerH
                              HomerH
                              Homer
                              wrote on last edited by Homer
                              I've finally finished building this, but sadly it doesn't want to work with my controller (Vera). When I start the inclusion process I'm says that it has found 2 devices, but when the controller finishes setting it up it only ends up showing one device, and all it says is that it is a node.
                              Has anyone built this and have had success with Vera? If you are using this, which controller do you use?
                              • alowhumA
                                alowhumA
                                alowhum
                                It should not show a temperature sensor, since it doesn't have one. Are you sure it has actually connected? Try listening to the serial output of the node (using the Arduino IDE's option to do this), and check if it says that it has connected ok, and that is is showing you the decoded signals then you play the RF signal. You can even try enabling the debug option to get even more details about the node's state.
                                • HomerH
                                  HomerH
                                  Homer
                                  Thanks for the reply!
                                  It doesn't show a temp sensor. I circled the device that it shows, but of course I only circled one because the second device doesn't show.
                                  dbemowskD 1 Reply Last reply
                                  • HomerH Homer
                                    dbemowskD
                                    dbemowskD
                                    @homer Look at your device list on a computer web browser. It appears that you are viewing it with the Vera app on your phone or tablet. I have seen where some devices don't show correctly on the Vera app. I don't know what type of device it will identify as, but you should see "<some device type> (12)" with the key being the (12) as that identifies the node that presented it. Also, do you have any 433Mhz devices that it may be detecting? Looking at the code a bit, it looks like it will present any 433Mhz devices that it sees to your Vera controller.
                                    • dbemowskD dbemowsk
                                      HomerH
                                      HomerH
                                      Homer
                                      @dbemowsk thanks for your reply. Yes the screenshot was taken Vera using my phone, but I only did that as I was using the phone at the time. I went out to have a smoke lol after I tried on my laptop.
                                      From what I understand, it should have created devices that then allow for the inclusion of rf433 devices, but if that isn't the case, I'm happy to be corrected!
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        @homer It creates one device. This device will get more children when it learns more codes.
                                        For example:
                                        • If you teach it a on+off code, the new child will be a toggle switch.
                                        • If you teach it to recognize a signal, the new child will be a motion sensor.
                                        If you are not using the touch screen, then you will also have 4 children that allow you to toggle the recording of the new signals.
                                        • A button to record a single signal that you want to be able to replay.
                                        • A button to start learning of an of+off combo signal (like a power socket that you can turn of and off).
                                        • A button to start learning a single detection signal (like a basic 433 window sensor)
                                        • A button to start learning a on+off detection signal (like a fancy 433 window sensor that supports both open and closed states).
                                        • alowhumA alowhum
                                          For example:
                                          HomerH
                                          HomerH
                                          Homer
                                          @alowhum for some reason I'm never seeing those 4 children.
                                          alowhumA 1 Reply Last reply
