  3. Mozilla WebThings Gateway
  4. MySensors add-on crashed ?
Scheduled Pinned Locked Moved Mozilla WebThings Gateway
12 Posts 2 Posters 2.3k Views 2 Watching
  • alowhumA
    alowhumA
    alowhum
    I always run with persistence unchecked too, since I want to know which devices are actually online and responding.
    I can try and create a debug function for the next version. Then perhaps we can find the error.
    You may have to remove things you created before version 0.0.5, since in that version there were a lot of changed to how capabilities work - a lot were removed. And those are the things that can be selected to end up in the center of your thing.
    Still, temperature should work just fine, theoretically.
    Nca78N 1 Reply Last reply
    • alowhumA alowhum
      @alowhum said in MySensors add-on crashed ?:
      At the moment I only set temperature as center of the thing, I only have TH sensors connected to the Things Gateway.
      I also deleted everything and removed/reinstalled the add-on, so I have nothing left from the previous version.
      • alowhumA
        alowhumA
        alowhum
        @Nca78 Great, that will narrow things down. I've created a new version (0.0.6) that exposes the debug options. You will be able to enable 'debugging' and see all the same details I do while developing. Then we can find in more detail what it going on. It should arrive on your system automatically when Mozilla accepts it.
        • Nca78N
          I still had a similar problem today, after restarting the gateway the add-on seemed to have failed to restart properly as the temperatures were showing 0°C.
          I disabled and re-enabled the add-on and the temps sensors got updates. But now this evening I see all sensors back to "Thing" display, the only suspicious thing I see in the log is the same "MaxListenersExceededWarning" message I posted above.
          The fact that they didn't immediately switch back to "Thing" display after restarting add-on might be due to the cache not updated, I'm not sure at all.
          But with the "native" thing on ESP32 also regularly failing and the really annoying and anti-ergonomic logs, I think I'll have a little break and come back to the Things Gateway later, when it will hopefully be a bit more polished and when I'll have had time to learn about the technologies it uses as I'm a bit stuck at the moment and can't check/fix anything myself.
          • alowhumA
            alowhumA
            alowhum
            @Nca78 I understand, sorry to hear it.
            Could you share one log with me in a private chat? Then I could try to use it to figure out what could be the cause on your system.
            • alowhumA
              alowhumA
              alowhum
              @nca78 I'm noticing the same behaviour of things switching back to displaying 'thing' in the center instead of the earlier selected property.
              • alowhumA alowhum
                :( Did you manage to identify the source/cause of the problem ? Restart of mysensors gateway or things gateway ? Version update ?
                It didn't happen to me anymore this week.
                • alowhumA
                  alowhumA
                  alowhum
                  It happens when you restart the add-on / gateway. I'm trying to figure it out here:
                  https://github.com/mozilla-iot/gateway-addon-python/issues/48
                  • alowhumA
                    alowhumA
                    alowhum
                    @Nca78 The second problem you mentioned should be fixed now.
                    https://forum.mysensors.org/topic/10342/mozilla-webthings-mysensors-add-on-adapter/26
                    • alowhumA alowhum
                      I just updated the add-on and it went all smoothly, all sensors are still here showing temperature and dimmed until message is effectively received.
                      I have activated the extra logging in case of a future problem.
                      Thank you for your hard work !
                      • alowhumA
                        alowhumA
                        alowhum
                        @Nca78 My pleasure!
