  3. 💬 nrf52832 PIR
💬 nrf52832 PIR
19 Posts 5 Posters 3.4k Views 4 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/691/nrf52832-PIR
    • N Offline
      N Offline
      NW27
      What exactly is this?
      • W Offline
        W Offline
        waspie
        its the start of a nrf52832-based motion sensor similar to neverdie's Multi-Sensor: Temp/Humidity/PIR/ Leak/Magnet/Light/Accel seen here:
        https://www.openhardware.io/view/510/Multi-Sensor-TempHumidityPIR-LeakMagnetLightAccel
        The nrf51822 is a bit finicky. I made it slightly bigger to accommodate a cr2450 and use a nrf52832 which is allegedly more reliable for low power sensors. I have a PIR hat, too, that i need to upload. I made my version adjustable. Neverdie's version works, but, the pir triggers quite a lot at the minimum reset time which means its triggering often in a busy room which uses a lot more battery.
        • W Offline
          W Offline
          waspie
          I'll be updating this with pictures of actual boards soon, including my PIR "hat"
          I've been running several of them for about two months now on a single CR2450 (~620mah) and they're still showing just slightly over 3 volts. These are detecting motion many times per hour during the day.
          • W Offline
            W Offline
            waspie
            Some pictures of an assembled unit with 3d printed case
            4_1560857780234_20190618_073230.jpg 3_1560857780234_20190618_073218.jpg 2_1560857780233_20190618_073211.jpg 1_1560857780233_20190618_073200.jpg 0_1560857780233_20190618_073136.jpg
            berkseoB N 2 Replies Last reply
            • W waspie
              berkseoB Offline
              berkseoB Offline
              berkseo
              @waspie
              Hello, great project! Can you provide a link to the datasheet of the pir sensor?
              • W waspie
                N Offline
                N Offline
                @waspie nice, with this case color you should get black fresnel lenses, it would look great :)
                @berkseo I guess it's an AM612, you will easily get datasheet on google
                berkseoB 1 Reply Last reply
                • N Nca78
                  berkseoB Offline
                  berkseoB Offline
                  berkseo
                  @nca78 said in 💬 nrf52832 PIR:
                  AM612
                  I thought something more original than AM612. It has a supply voltage of 2.4-3.2V, if I'm not mistaken.
                  N 1 Reply Last reply
                  • berkseoB berkseo
                    AM612
                    N Offline
                    N Offline
                    @berkseo said in 💬 nrf52832 PIR:
                    AM612
                    No it's 2.7-3.3, which is not great for button cell as a fair share of the capacity will not be available.
                    • W Offline
                      W Offline
                      waspie
                      Yeah, it's an AM612. I think when I originally put this together I didn't realize the low cutoff voltage :|
                      We'll see how long it lasts...
                      I guess options then are to add a buck converter or strap AAAs on the back instead
                      Black fresnel lens? what?? I might have to find some of those
                      N berkseoB 2 Replies Last reply
                      • W waspie
                        N Offline
                        N Offline
                        @waspie said in 💬 nrf52832 PIR:
                        They are on Aliexpress. Not even expensive.
                        • W waspie
                          berkseoB Offline
                          berkseoB Offline
                          berkseo
                          ...search on aliexpress
                          • W Offline
                            W Offline
                            waspie
                            wrote on last edited by waspie
                            thanks guys, i just ordered a few :)
                            @berkseo i was searching for buck/boost converters and found TPS61098 which when i searched for turned up on one of you designs :)
                            what i can't figure out just yet is how to wire it up for our application. can you shed any light on that, please?
                            well, i think i may have sorted it.... GND and MODE to ground. VSUB is 3.3 (or 3v if i do the 61098) out (not being used in this application?).
                            SW inductor, vin of course, and vmain is the output for the mcu i think
                            • berkseoB berkseo
                              N Offline
                              N Offline
                              Are these for the S16 smd sensors ? If yes, can you please give me a link of where you ordered them ? I couldn't get any, LCSC sold me the sensors but refused to order the lenses for me, and Senba can send them "for free" but with a very high express shipping fee.
                              • N Nca78
                                berkseoB Offline
                                berkseoB Offline
                                berkseo
                                Only through Alibaba (not aliexpress) at Senba (((
                                • W waspie
                                  berkseoB Offline
                                  berkseoB Offline
                                  berkseo
                                  @waspie
                                  TPS610981DSE, see table in datasheet, paragraph 5
                                  I use the schema from the datasheet, paragraph 9.2.2
                                  • berkseoB Offline
                                    berkseoB Offline
                                    berkseo
                                    I would like to find an available pir sensor powered by 1.8 V :(
                                    W 1 Reply Last reply
                                    • berkseoB berkseo
                                      W Offline
                                      W Offline
                                      waspie
                                      yeah, that'd be nice
                                      • W Offline
                                        W Offline
                                        waspie
                                        5 months and voltage still holding decently high
                                        /77/28/1/0/38 2.964
                                        12.2k
