  3. Motion Sensor (PIR) and Boost Converter
6 Posts 3 Posters 1.4k Views 3 Watching
  • ? Offline
    ? Offline
    A Former User
    I hope you guys can help with this. I have a MySensor node running on 2AA batteries. It is a motion sensor with one of those cheap PIR modules.
    I am feeding the PIR sensor using 3.3V directly to the HIGH pin. So far so good up until here. The problem comes when I try to feed the PIR sensor using a boost converter 0.8-3.3v. With that configuration, the sensor throws tons of false positives.
    I attribute it to noise generated by the booster. I have tried adding a 4.7uF capacitor to the power supply but it hasn't helped.
    Any suggestions?
    Thanks!!
    electrikE Y 2 Replies Last reply
    • ? A Former User
      Any suggestions?
      Thanks!!
      electrikE Offline
      electrikE Offline
      electrik
      @david_shb try a bigger capacitor 😁
      470uF or maybe even 1mF
      • ? Offline
        ? Offline
        A Former User
        Thanks @electrik Are you using a similar design?
        electrikE 1 Reply Last reply
        • ? A Former User
          Any suggestions?
          Thanks!!
          Y Offline
          Y Offline
          @david_shb most pir modules are very sensitive to power glitches and require 3..5V power supply.
          Therefore I prefer the 3 battery approach as described here : https://forum.mysensors.org/topic/6511/hc-sr501-3-3v-randomly-sends-tripped-when-radio-is-on/23
          • ? A Former User
            electrikE Offline
            electrikE Offline
            electrik
            @david_shb no I'm using 3 AAA batteries without booster.
            • ? Offline
              ? Offline
              A Former User
              Thanks guys, I have one of those modules I will test it out.
              I have been playing with a combination of 0.1uF and 10uF. It has been performing decently so far.
              Let's see.
