  3. NodeManager
  4. Newbie, adding more than one relay to nodemanager
7 Posts 2 Posters 2.7k Views 3 Watching
  • MGHaffM
    MGHaffM
    MGHaff
    wrote on last edited by MGHaff
    I just started using nodemanager. GREAT WORK! Might be a dumb question but how do i add more than one relay to the sketch? I would like to control 4 but only can get one to work. Thanks in advance!
    U 1 Reply Last reply
    • MGHaffM MGHaff
      U
      U
      user2684
      Hi @mghaff, just add additional instances of the relay and you can configure them individually. E.g.
      #include <sensors/SensorRelay.h>
      SensorRelay relay1(4);
      SensorRelay relay2(5);
      SensorRelay relay3(6);
      MGHaffM 3 Replies Last reply
      • U user2684
        MGHaffM
        MGHaffM
        MGHaff
        This post is deleted!
        • U user2684
          MGHaffM
          MGHaffM
          MGHaff
          @user2684 Perfect Thanks!
          • U user2684
            MGHaffM
            MGHaffM
            MGHaff
            @user2684 Another Question.... Thanks in advance!
            Where do i put this to get my relay to invert operation?
            // [109] Invert the value to write. E.g. if ON is received, write LOW (default: false)
            void setInvertValueToWrite(bool value);
            And how should it be written.
            I tried this.
            SensorRelay relay1(8);
            SensorRelay relay4(7);
            SensorRelay setInvertValueToWrite(true);
            • MGHaffM MGHaff
              I tried this.
              U
              U
              user2684
              @mghaff inside before() you have to call the function setInvertValueToWrite() on the relay you want to apply it to. E.g.
              relay1.setInvertValueToWrite(true);
              relay2.setInvertValueToWrite(true);
              • MGHaffM
                MGHaffM
                MGHaff
                @user2684 said in Newbie, adding more than one relay to nodemanager:
                WOW Thanks Again! This is really fun and easy to work with! Thank you!!!!
