  3. Wrong S_DOOR and V_TRIPPED gives a invalid value, in the log file WHY ?
5 Posts 3 Posters 1.3k Views 3 Watching
    mcrahr
    I see something strange in my homeassistant log file. What might be the issue here ?
    Everything does seem to work ok I do get a nice door that open and close fine :)
    2019-01-04 10:21:42 DEBUG (MainThread) [homeassistant.components.mysensors.helpers] Invalid values: {16: '1'}: switch platform: node 10 child 20: S_DOOR requires value_type V_ARMED @ data[15]
    2019-01-04 10:21:42 DEBUG (MainThread) [homeassistant.components.mysensors.helpers] Invalid values: {16: '1'}: switch platform: node 10 child 21: S_DOOR requires value_type V_ARMED @ data[15]
    According to the spec, S_DOOR should have V_ARMED or V_TRIPPED
    I do send the following from the node.
    sensorgateway1-out/10/21/1/0/16 1
    sensorgateway1-out/10/20/1/0/16 1
    And 16 = V_TRIPPED
    and this is how the json file for sensor node 10 looks like
    "10": {
    "sensor_id": 10,
    "children": {
    "20": {
    "id": 20,
    "type": 0,
    "description": "",
    "values": {
    "16": "1"
    "21": {
    "id": 21,
    "type": 0,
    "description": "",
    "values": {
    "16": "1"
    "type": 17,
    "sketch_name": "Door living room",
    "sketch_version": "1.0",
    "battery_level": 0,
    "protocol_version": "2.3.1-alpha",
    "heartbeat": 0
    YveauxY 1 Reply Last reply
    • M mcrahr
      And 16 = V_TRIPPED
      "10": {
      "sensor_id": 10,
      "children": {
      "20": {
      "id": 20,
      "type": 0,
      "description": "",
      "values": {
      "16": "1"
      "21": {
      "id": 21,
      "type": 0,
      "description": "",
      "values": {
      "16": "1"
      "type": 17,
      "battery_level": 0,
      "heartbeat": 0
      YveauxY
      YveauxY
      @mcrahr said in Wrong S_DOOR and V_TRIPPED gives a invalid value, in the log file WHY ?:
      Seems like a HomeAssistant issue to me. It only accepts V_ARMED for sensor type S_DOOR, while for MySensors V_TRIPPED is also allowed.
      M 1 Reply Last reply
      • YveauxY Yveaux
        mcrahr
        @yveaux
        As you can see the LOG comes from homeassistant.components.mysensors.helpers, not sure who did that, but home assistant work fine, as it does shows everything, looks like it is only the error trace
        • M mcrahr
          @yveaux
          YveauxY
          YveauxY
          Definately HomeAssistant code: https://github.com/home-assistant/home-assistant/blob/dev/homeassistant/components/mysensors/helpers.py#L52 and https://github.com/home-assistant/home-assistant/blob/dev/homeassistant/components/mysensors/const.py#L50
          • S
            Sweetpants
            Any news on this one?
