  3. Problem with light control between mysensors and HA
arduinolighthome assistant
3 Posts 2 Posters 1.9k Views 2 Watching
    Misna
    wrote on last edited by Misna
    Hi!
    I'm building my first mysensors node and have one problem before I can move it to production. The node is referred here: https://forum.mysensors.org/topic/9863/my-very-first-mysensors-node/3
    It works perfectly reading temperature, humidity and the door status.
    But with the light switch if HA goes to a state where light status is "on" but brightness is "0" it doesn't respond until I manually set the brightness to "100". I tried this with mysensors library version 2.3.1 and 2.2.0 but the behaviour is the same. My gateway version is 2.1.0
    Here is the code for the node. There is nothing special on HA end. I'm running hass.io latest version 0.84.6 and lovelace GUI. Sorry for the comments in the code, they are part english and part finnish :)
    Just this issue to solve and one package from China and I'll get the power supplys and nodes ready. Then pretty soon I'll have 10 mysensors nodes running! I already started with some Sonoff's in the middle froor, four now installed and one waiting for a suitable application.
      * NODE ID: 2
      * Tämä on alasisäeteisen node jossa on:
      * - DHT22 -> lämpö ja kosteus
      * - Releohjaus sisäeteisen valoille (kytkin+rele)
      * - Ovitunnistin (hall-anturi)
      * Kytkennät:
      * - 5=DHT22
      * - 4=Releohjaus
      * - 3=Yläkerran valokytkin
      * - 6=Alakerran valokytkin
      * - 2=Ovitunnistin
    // Enable debug prints
    //#define MY_DEBUG
    // Noden ID (oltava kaikissa eri!!)
    #define MY_NODE_ID 2
    #define MY_RADIO_RF24
    #define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    #include <DHT.h>
    #include <SimpleTimer.h>
    #define DOOR_PIN  2 // Ovikytkin
    #define BUTTON_PIN  3  // Yläkerran valokytkin
    #define BUTTON_PIN_2  6  // Alakerran valokytkin
    #define RELAY_PIN  4 // Rele (valo)
    #define DHT_DATA_PIN 5 // Lämpötila-anturi DHT22
    #define CHILD_ID_LIGHT 1
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 3
    #define CHILD_ID_DOOR 4
    #define LIGHT_OFF 0
    #define LIGHT_ON 1
    #define RELAY_ON 0
    #define RELAY_OFF 1
    #define DOOR_CLOSED 0
    #define DOOR_OPEN 1
    #define SENSOR_TEMP_OFFSET 0 // DHT22 lämpötilan offsetti
    #define SN "kellari_sisaeteinen"
    #define SV "1.2"
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    int16_t last_state = LIGHT_OFF;
    int16_t last_dim = 0;
    // Yläkerran valokytkimen luku
    Bounce debouncer = Bounce();
    // Alakerran valokytkimen luku
    Bounce debouncer_2 = Bounce();
    // Ovikytkimen luku
    Bounce ovidebouncer = Bounce();
    // Lämpötila-anturin oliot
    DHT dht;
    SimpleTimer timer;
    MyMessage light_msg( CHILD_ID_LIGHT, V_STATUS );
    MyMessage dimmer_msg( CHILD_ID_LIGHT, V_PERCENTAGE );
    MyMessage msgOvi(CHILD_ID_DOOR, V_TRIPPED);
      update_light();
      //Serial.println( "Node ready to receive messages..." );
      // Setup the buttons
      pinMode(BUTTON_PIN,INPUT);
      pinMode(BUTTON_PIN_2,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_2,HIGH);
      pinMode(RELAY_PIN, OUTPUT);
      debouncer.attach(BUTTON_PIN, INPUT_PULLUP);
      debouncer.interval(25);
      debouncer_2.attach(BUTTON_PIN_2, INPUT_PULLUP);
      debouncer_2.interval(25);
      // Ovikytkin
      ovidebouncer.attach(DOOR_PIN, INPUT_PULLUP);
      ovidebouncer.interval(25);
      // Timer lämpötila-anturin lukemista varten (millisekunteja) eli luetaan 1min välein
      timer.setInterval(60000, lampotilaLuku);
      //In MySensors2.x, first message must come from within loop()
      static bool first_message_sent = false;
      if ( first_message_sent == false )
        //Serial.println( "Sending initial state..." );
        send_dimmer_message();
        send_status_message();
        lampotilaLuku();
        send(msgOvi.set(DOOR_CLOSED));
        first_message_sent = true;
      debouncer.update(); // Update the Bounce instance (yläkerran valokytkin)
      // Laskevan reunan tunnistus (yläkerran valokytkin)
      if ( debouncer.fell() )
        //Serial.println( "Laskeva reuna" );
        nappiPainettu(); // Valon ohjaus
      // Nousevan reunan tunnistus (yläkerran valokytkin)
      if ( debouncer.rose() )
        //Serial.println( "Nouseva reuna" );
      debouncer_2.update(); // Update the Bounce instance (alakerran valokytkin)
      // Laskevan reunan tunnistus (alakerran valokytkin)
      if ( debouncer_2.fell() )
      // Nousevan reunan tunnistus (alakerran valokytkin)
      if ( debouncer_2.rose() )
      // Ovitunnistimen luku
      if (ovidebouncer.update())
        // Get the update value.
        int value = ovidebouncer.read();
        // Send in the new value.
        //Serial.println( "Oven status muuttui" );
        send(msgOvi.set(value==HIGH ? 1 : 0));
      // Lämpötila-anturin timer pyörii..
      timer.run();
      sendSketchInfo( SN, SV );
      present( CHILD_ID_LIGHT, S_DIMMER );
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_DOOR, S_DOOR);
      metric = true; // Lämpötila-anturi
    // Vastaanotetaan HA:lta komentoja
      //When receiving a V_STATUS command, switch the light between OFF
      //and the last received dimmer value
      // Tämä on ON/OFF viesti HA:lta
      if ( message.type == V_STATUS )
        //Serial.println( "V_STATUS command received..." );
        int lstate = message.getInt();
        if (( lstate < 0 ) || ( lstate > 1 )) {
          //Serial.println( "V_STATUS data invalid (should be 0/1)" );
          return;
        last_state = lstate;
        //If last dimmer state is zero, set dimmer to 100
        if (( last_state == LIGHT_ON ) && ( last_dim == 0 ))
          last_dim=100;
        //Update constroller status
      // Tämä on himmennys viesti HA:lta
      else if ( message.type == V_PERCENTAGE )
        //Serial.println( "V_PERCENTAGE command received..." );
        int dim_value = constrain( message.getInt(), 0, 100 );
        if ( dim_value == 0 ) {
          //Update constroller with dimmer value & status
        else
          last_state = LIGHT_ON;
          last_dim = dim_value;
      else
        //Serial.println( "Invalid command received..." );
        return;
      //Here you set the actual light state/level
      update_light();
    // Releen ohjaus statuksen perusteella
    void update_light()
      if ( last_state == LIGHT_OFF )
        //Serial.println( "Light state: OFF" );
      else
        //Serial.print( "Light state: ON, Level: " );
        //Serial.println( last_dim );
        digitalWrite(RELAY_PIN, RELAY_ON);
    // Lähetetään HA:lle dimmer arvo
    void send_dimmer_message()
      send( dimmer_msg.set( last_dim ) );
    // Lähetetään HA:lle valon status (ON/OFF)
    void send_status_message()
      if ( last_state == LIGHT_OFF ) {
        send( light_msg.set( (int16_t)0) );
      } else {
        send( light_msg.set( (int16_t)1) );
    // Luetaan DHT22 arvot
    void lampotilaLuku()
      dht.readSensor(true);
      if (isnan(temperature)) {
        //Serial.println("Failed reading temperature from DHT!");
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        //Serial.print("T: ");
        //Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        //Serial.println("Failed reading humidity from DHT");
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        //Serial.print("H: ");
        //Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
    // Napin painon jälkeen valon ohjaus ja statuksen päivitys
    void nappiPainettu()
      if (last_state == LIGHT_ON)
        //Serial.println( "Valo OFF napista" );
        last_dim=0;
        update_light(); // Releen toggle
      else
        //Serial.println( "Valo ON napista" );
        last_dim=100;
      //Serial.println( "Lahetetaan HA:lle uusi status" );
      send_status_message(); // Lähetä HA:lle uusi status (ON/OFF)
      send_dimmer_message(); // Lähetä HA:lle uusi dim arvo (0/100)
    Here are parts concerning from configuration.yaml file:
    # Mysensors serial gateway config
    mysensors:
      gateways:
        - device: '/dev/ttyACM0'
          baud_rate: 115200
          persistence_file: '/config/mysensors.json'
      optimistic: false
      persistence: true
      version: 2.0
    • B
      B
      badisensors
      Try persistence: false
        Misna
        Hi!
        Going through examples and forum topics I've noticed that I'm using the wrong S-type and V-type.
        I'm writing a new version of the code with S_LIGHT and V_LIGHT so there is now dimmer functionality (which I don't need).
        Let's see if this helps.
