  3. [SOLVED] A2 interrupt doesn't wake node from sleep
10 Posts 2 Posters 1.9k Views 2 Watching
  • J
    J
    jimmy loyens
    Hello first off here is my code (not all ofcourse):
    //* INTERRUPTS *//
    // Install Pin change interrupt for a pin, can be called multiple times
    void pciSetup(byte pin)
      *digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin));  // enable pin
      PCIFR  |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
      PCICR  |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
    // Use one Routine to handle each group
    ISR (PCINT0_vect) // handle pin change interrupt for D8 to D13 here
      tripped = true;
      GetDigital();
    //  digitalWrite(13, digitalRead(8));
    ISR (PCINT1_vect) // handle pin change interrupt for A0 to A5 here
      //Only on fall interrupt of TSL2561
      if (!digitalRead(A2)) {
        lightInterrupt = true;
        Serial.println("falling trigger");
    ISR (PCINT2_vect) // handle pin change interrupt for D0 to D7 here
      tripped = true;
      GetDigital();
     // digitalWrite(13, digitalRead(2) and digitalRead(3) and digitalRead(5) and digitalRead(6) and digitalRead(7));
      //* BATTERY LEVEL *//
      //processBattLevel();
      //* DHT: TEMPERATURE *//
       //processTemperature();
      //* DHT: HUMIDITY *//
      //processHumidity();
      //* TSL: LIGHTLEVEL *//
        //processLightLevel();
      if (lightInterrupt == true) {
        Serial.println("A2 low!!!!!!!!!!!!!!!!!");
        light.clearInterrupt();
        lightInterrupt = false;
      //* DI: DOOR/WINDOW *//
        //UpdateCurrentState();
      //* SLEEP *//
      sleep(PCINT1_vect, CHANGE, PCINT2_vect, CHANGE,  UPDATE_INTERVAL);
    I have the problem that a change in PCINT1_vect doesn't wake up my node. The interrupt gets triggered but it doesn't seem to run all of the code in the ISR and doesn't exit the sleep. I get the following in the output:
    data0: 1343
     data1: 219
    TSL2561 interrupts thresholds set successfully
    lux: 34.25
    mlux: 36
    lastLux: 36
    gain: 1
    10764 TSF:MSG:SEND,59-59-0-0,s=3,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:34
    LightLevel: 34 lux
    10774 MCO:SLP:MS=30000,SMS=0,I1=186,M1=1,I2=59,M2=1
    10780 MCO:SLP:TPD
    10782 MCO:SLP:WUP=-1
    10784 MCO:SLP:MS=30000,SMS=0,I1=186,M1=1,I2=59,M2=1
    10790 MCO:SLP:TPD
    10792 MCO:SLP:WUP=-1
    10795 MCO:SLP:MS=30000,SMS=0,I1=186,M1=1,I2=59,M2=1
    10801 MCO:SLP:TPD
    10803 MCO:SLP:WUP=-1
    10805 MCO:SLP:MS=30000,SMS=0,I1=186,M1=1,I2=59,M2=1
    10811 MCO:SLP:TPD
    fa⸮
    Last line is supposed to be "falling triggr". This Serial.println is located in the ISR PCINT0_vect, but it seems it doesn't get fully executed. after the node wakes up (on timer), it seems like 'lightInterrupt' has been set in the ISR since the lightlevel is processed and updated.
    A2 low!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    data0: 1440
     data1: 245
    lux: 36.30
    mlux: 35
    lastLux: 35
    gain: 1
    8491 TSF:MSG:SEND,59-59-0-0,s=3,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:36
    LightLevel: 36 lux
    8503 MCO:SLP:MS=30000,SMS=0,I1=186,M1=1,I2=210,M2=1
    8507 MCO:SLP:TPD
    8509 MCO:SLP:WUP=-1
    8511 MCO:SLP:MS=30000,SMS=0,I1=186,M1=1,I2=210,M2=1
    8517 MCO:SLP:TPD
    Stranger even still, PCINT2_vect does work as expected. In this case the node does wake up on interrupt on D2-D7 (if these DI's are enabled in the code). If anyone can help it would be much appreciated. I really don't see the reason PCINT1_vect doesn't wake up the node. If more code is needed tell me, I will happely post the entire code if you want.
    • J jimmy loyens
      //* INTERRUPTS *//
        tripped = true;
        GetDigital();
        tripped = true;
        GetDigital();
        //* SLEEP *//
      data0: 1343
       data1: 219
      lux: 34.25
      mlux: 36
      lastLux: 36
      gain: 1
      LightLevel: 34 lux
      10780 MCO:SLP:TPD
      10790 MCO:SLP:TPD
      10801 MCO:SLP:TPD
      10811 MCO:SLP:TPD
      fa⸮
      data0: 1440
       data1: 245
      lux: 36.30
      mlux: 35
      lastLux: 35
      gain: 1
      LightLevel: 36 lux
      8507 MCO:SLP:TPD
      8509 MCO:SLP:WUP=-1
      8517 MCO:SLP:TPD
      Using Serial from within an ISR is not recommended. See TL;DR at http://gammon.com.au/interrupts
      What does GetDigital() do? ISRs need to be executed quickly, and a lot of things must be avoided (see above link).
      shows that the wake up reason is -1 which is MY_WAKE_UP_BY_TIMER so the wake up reason was timer, not interrupt.
      What is PCINT1_vect and PCINT2_vect ? (they are not defined in the code you've posted).
      Maybe these variables are not what the MySensors sleep function expects? Documentation: https://www.mysensors.org/download/sensor_api_20#sleeping
      J 1 Reply Last reply
        J
        J
        jimmy loyens
        @mfalkvidd Hi, first off thanks for taking a look at my problem.
        I know I'm not supposed to use Serial.print inside an ISR, this was just for debugging purposses to see if this part of the code even was run. I tried without the Serial.print but same result.
        GetDigital looks wich interruptpin was triggered
        boolean GetDigital(void) {
          noInterrupts();
          if (tripped) {
            for (char i = 0; i < NR_OF_SWITCH; i++) {
              currState[i] = digitalRead(intPin[i]);
              if (lastState[i] != currState[i]) {
                lastState[i] = currState[i];
                Serial.print("Pin "); Serial.print(intPin[i]); Serial.print(" triggered: "); Serial.println(currState[i]);
                switch (i) {
                  case 0:
                    send(msgSwitch1.set(currState[i]));
                    break;
                  case 1:
                    send(msgSwitch2.set(currState[i]));
                    break;
                  case 2:
                    send(msgSwitch3.set(currState[i]));
                    break;
                  case 3:
                    send(msgSwitch4.set(currState[i]));
                    break;
                  case 4:
                    send(msgSwitch5.set(currState[i]));
                    break;
                  case 5:
                    send(msgSwitch6.set(currState[i]));
                    break;
                  default:
                    Serial.println("Not an interrupt pin");
            tripped = false; //Clear processed triggers
            interrupts();
            return true;
          interrupts();
          return false;
        Again Serial.print for debugging (but seems to run fine even with Serial.print, granted it takes the ISR alot longer)
        I know the node woke up because the timer expired, this is kind of the problem :wink:
        PCINT0_vect, PCINT1_vect and PCINT2_vect are interruptvectors used in pinchange interrupt on all pins (D8-D13, A1-A5 & D0-D7) see this link: https://playground.arduino.cc/Main/PinChangeInterrupt.
        These variables are probably not what the MySensors Sleep function expects, but it seems to work fine for PCINT0_vect and PCINT2_vect, where the digital pins are connected to. When any of the digital pins change the node wakes up immediatly and sends an update about the pin that changed. Should work the same for the interrupt on the analog pin, but something goes wrong :disappointed:
        I even tried using absolute pinnumbers for analog pins (A0=14,A1=15,A2=16,...) but still same result. see:
        http://forum.arduino.cc/index.php?topic=41238.0
        I will include the entire sketch in next post, so you can follow all of the code if needed. Its devided into several files and i cant upload a zip appearently so get ready for some serious code blocks :grin:
        I have these nodes on every door & window in my house for about a year now and they work great. Just wanted to add interrupt functionality to my light measurement now.
        J mfalkviddM 2 Replies Last reply
        • J jimmy loyens
            noInterrupts();
            if (tripped) {
                  switch (i) {
                    case 0:
                      break;
                    case 1:
                      break;
                    case 2:
                      break;
                    case 3:
                      break;
                    case 4:
                      break;
                    case 5:
                      break;
                    default:
              interrupts();
              return true;
            interrupts();
            return false;
          J
          J
          jimmy loyens
          @jimmy-loyens
          This is the entire code:
          Setup & loop (.ino)
             The MySensors Arduino library handles the wireless radio link and protocol
             between your home built sensors/actuators and HA controller of choice.
             The sensors forms a self healing radio network with optional repeaters. Each
             repeater and gateway builds a routing tables in EEPROM which keeps track of the
             network topology allowing messages to be routed to nodes.
             Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
             Copyright (C) 2013-2015 Sensnology AB
             Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
             Documentation: http://www.mysensors.org
             Support Forum: http://forum.mysensors.org
             This program is free software; you can redistribute it and/or
             modify it under the terms of the GNU General Public License
             version 2 as published by the Free Software Foundation.
             REVISION HISTORY
             Version 1.0: Henrik EKblad
             Version 1.1 - 2016-07-20: Converted to MySensors v2.0 and added various improvements - Torben Woltjen (mozzbozz)
             DESCRIPTION
             Mysensors battery node. With temperature, relative humidity, lightintensity and battery level measurements
             For more information, please visit:
             http://www.mysensors.org/build/
          //** Includes
          #include "Defines.h"
          #include "Globals.h"
          #include <Wire.h>
          //* INTERRUPTS *//
            tripped = true;
            GetDigital();
            if (!digitalRead(16)) {
            tripped = true;
            GetDigital();
            Serial.begin(115200);
            //* SETUP BATTERY LEVEL *//
            setupBattery();
            //* SETUP DHT *//
            setupDHT();
            //* SETUP TSL2561 *//
            setupTSL();
            //* SETUP DI's *//
            setupDI();
            processBattLevel();
            processHumidity();
            //  processLightLevel();
              Serial.println("A2 low!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!");
            //* SLEEP *//
          Battery (.ino)
          void setupBattery(void) {
            // Define internal reference for battry level measurement
            analogReference(INTERNAL1V1);
          #else
            analogReference(INTERNAL);
          void processBattLevel(void) {
            noInterrupts();
            int sensorValue = analogRead(batterySensePin);
            interrupts();
          #ifdef MY_DEBUG
            Serial.print("Battery sensorValue : ");Serial.println(sensorValue);
            //1M, 470K divider across battery and using ADC ref of 1.1V
            //Sense point is bypassed with 0.1µF cap to reduce noise at that point
            //((1e6+470e3) / 470e3) * 1.1 = Vmax = 3.44V
            //3.44 / 1023 = Volt per bit = 0.003363075
          #ifdef MY_DEBUG
            float batteryV = sensorValue * 0.003363075;
            Serial.print(batteryV);
            Serial.println(" V");
            Serial.print("Battery Percent: ");
            Serial.print(batteryPcnt);
            Serial.println(" %");
            if (oldBatteryPcnt != batteryPcnt || nNoUpdatesBatt == FORCE_UPDATE_N_READS_B) {  // Only send battery message when value has changed
              //Power up radio after sleep
              send(msgBatt.set(batteryPcnt));
              //sendBatteryLevel(batteryPcnt);
              oldBatteryPcnt = batteryPcnt;
              nNoUpdatesBatt = 0;
            else {
              // Increase no update counter if the battery level stayed the same
              nNoUpdatesBatt++;
          DHT (.ino)
          void setupDHT(void){
          void processTemperature(void){
            noInterrupts();
            dht.readSensor(true);
            interrupts();
            Serial.print("temperature (float): ");Serial.println(temperature);
            if (isnan(temperature)) {
            else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS_T) {
              lastTemp = temperature;
              if (!metric) {
              // Reset no updates counter
              nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
              Serial.print("Temperature: ");
              Serial.print(temperature);
              Serial.println(" °C");
            else {
              nNoUpdatesTemp++;
          void processHumidity(void){
            noInterrupts();
            interrupts();
            if (isnan(humidity)) {
            else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS_H) {
              lastHum = humidity;
              nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
              Serial.print("Humidity: ");
              Serial.print(humidity);
            else {
              nNoUpdatesHum++;
          Digital (.ino)
          void setupDI(void) {
          #ifdef PULL_UP_EN
            // set pullups, if necessary
            for (int i = 2; i <= 8; i++) {
              digitalWrite(i, HIGH);
            Serial.println("pullup");
            // enable interrupt for pin...
            for (int i = 0; i < NR_OF_SWITCH; i++) {
              pciSetup(intPin[i]);
          #ifdef MY_DEBUG
              Serial.print("Int pin ");
              Serial.print(i);
              Serial.print(": ");
              Serial.println(intPin[i]);
          void UpdateCurrentState(void) {
            noInterrupts();
              Serial.print("Pin "); Serial.print(intPin[i]); Serial.println(" updated: "); Serial.println(currState[i]);
              switch (i) {
                case 0:
                  break;
                case 1:
                  break;
                case 2:
                  break;
                case 3:
                  break;
                case 4:
                  break;
                case 5:
                  break;
                default:
            interrupts();
            noInterrupts();
            if (tripped) {
                  switch (i) {
                    case 0:
                      break;
                    case 1:
                      break;
                    case 2:
                      break;
                    case 3:
                      break;
                    case 4:
                      break;
                    case 5:
                      break;
                    default:
              interrupts();
              return true;
            interrupts();
            return false;
          Presentation (.ino)
            noInterrupts();
            sendSketchInfo(SKETCH_NAME, Sketch_VERSION);
            present(CHILD_ID_BATT, I_BATTERY_LEVEL);
            present(CHILD_ID_HUM, S_HUM);
            if (NR_OF_SWITCH >= 1) {
              present(CHILD_ID_SWITCH1, S_DOOR);
              if (NR_OF_SWITCH >= 2) {
                present(CHILD_ID_SWITCH2, S_DOOR);
                if (NR_OF_SWITCH >= 3) {
                  present(CHILD_ID_SWITCH3, S_DOOR);
                  if (NR_OF_SWITCH >= 4) {
                    present(CHILD_ID_SWITCH4, S_DOOR);
                    if (NR_OF_SWITCH >= 5) {
                      present(CHILD_ID_SWITCH5, S_DOOR);
                      if (NR_OF_SWITCH >= 6) {
                        present(CHILD_ID_SWITCH6, S_DOOR);
            interrupts();
          TSL (.ino)
          void setupTSL(void) {
            pinMode(16,INPUT_PULLUP);//16 = A2
          pciSetup(16);
            // Initialize the SFE_TSL2561 library
            // You can pass nothing to light.begin() for the default I2C address (0x39),
            // or use one of the following presets if you have changed
            // the ADDR jumper on the board:
            // TSL2561_ADDR_0 address with '0' shorted on board (0x29)
            // TSL2561_ADDR   default address (0x39)
            // TSL2561_ADDR_1 address with '1' shorted on board (0x49)
            // For more information see the hookup guide at: https://learn.sparkfun.com/tutorials/getting-started-with-the-tsl2561-luminosity-sensor
            light.begin();
            // The light sensor has a default integration time of 402ms,
            // and a default gain of low (1X).
            // If you would like to change either of these, you can
            // do so using the setTiming() command.
            // If gain = false (0), device is set to low gain (1X)
            // If gain = high (1), device is set to high gain (16X)
            gain = 1;
            // If time = 0, integration will be 13.7ms
            // If time = 1, integration will be 101ms
            // If time = 2, integration will be 402ms
            // If time = 3, use manual start / stop to perform your own integration
            time = 2;
            // setTiming() will set the third parameter (ms) to the
            // requested integration time in ms (this will be useful later):
            light.setTiming(gain, time, ms);
            if (light.setInterruptControl(1,2)) {
              Serial.println("TSL2561 interrupts set successfully");
            if (light.setInterruptThreshold(500, 1800)) {
              Serial.println("TSL2561 interrupts thresholds set successfully");
            // To start taking measurements, power up the sensor:
            light.setPowerUp();
            // The sensor will now gather light during the integration time.
            // After the specified time, you can retrieve the result from the sensor.
            // Once a measurement occurs, another integration period will start.
          void processLightLevel(void) {
            // Wait between measurements before retrieving the result
            // (You can also configure the sensor to issue an interrupt
            // when measurements are complete)
            // This sketch uses the TSL2561's built-in integration timer.
            // You can also perform your own manual integration timing
            // by setting "time" to 3 (manual) in setTiming(),
            // then performing a manualStart() and a manualStop() as in the below
            // commented statements:
            // ms = 1000;
            // light.manualStart();
            //delay(ms);
            // light.manualStop();
            // Once integration is complete, we'll retrieve the data.
            // There are two light sensors on the device, one for visible light
            // and one for infrared. Both sensors are needed for lux calculations.
            // Retrieve the data from the device:
            unsigned int data0, data1;
            if (light.getData(data0, data1))
              // getData() returned true, communication was successful
          #ifdef MY_DEBUGX
              Serial.print("data0: ");
              Serial.println(data0);
              Serial.print(" data1: ");
              Serial.println(data1);
          if(data0>65000){
            gain=0;
          if(data0<500){
            gain=1;
          if (light.setInterruptThreshold(data0-(data0/100*10),data0+(data0/100*10))) {       //light.setInterruptThreshold(data0-50,data0+50)
              double lux;    // Resulting lux value
              boolean good;  // True if neither sensor is saturated
              // Perform lux calculation:
              good = light.getLux(gain, ms, data0, data1, lux);
              if (good) {
          #ifdef MY_DEBUGX
                Serial.print("lux: ");
                Serial.println(lux);
                Serial.print("mlux: ");
                Serial.println(mlux);
                Serial.print("lastLux: ");
                Serial.println(lastLux);
                Serial.print("gain: ");
                Serial.println(gain);
                mlux = int(lux);  // Lux value to be transmitted as integer
                if (isnan(mlux)) {
                  Serial.println("Failed reading lightintensity from TSL2561!");
                } else if (mlux != lastLux || nNoUpdatesTemp == FORCE_UPDATE_N_READS_L) {
                  send(msgLight.set(mlux));
                  lastLux = mlux;
          #ifdef MY_DEBUG
                  Serial.print("LightLevel: ");
                  Serial.print(mlux);
                  Serial.println(" lux");
                else {
                  nNoUpdatesLight++;
          Defines (.h)
          //** Define scetch name and version
          #define SKETCH_NAME "ID59_Kitchen_1(2*window)"
          #define Sketch_VERSION "V1.1"
          //** Enable debug prints
          #define MY_DEBUGX
          //** Define node ID
          #define MY_NODE_ID 59
          //** Define child ID's
          #define CHILD_ID_BATT 0
          #define CHILD_ID_HUM 1
          #define CHILD_ID_TEMP 2
          #define CHILD_ID_LIGHT 3
          #define CHILD_ID_SWITCH1 4
          #define CHILD_ID_SWITCH2 5
          #define CHILD_ID_SWITCH3 6
          #define CHILD_ID_SWITCH4 7
          #define CHILD_ID_SWITCH5 8
          #define CHILD_ID_SWITCH6 9
          #define NR_OF_SWITCH 6  //Window_1+2
          //** Define interrupt pins (doors & windows)
          #define INT_PIN1  2
          #define INT_PIN2  3
          #define INT_PIN3  5
          #define INT_PIN4  6
          #define INT_PIN5  7
          #define INT_PIN6  8
          #define PULL_UP_EN true
          //** Enable and select radio type attached
          #define MY_RF24_CE_PIN  9
          #define MY_RF24_CS_PIN  10
          //** DHT defines
          #define DHT_DATA_PIN 4
          #define SENSOR_TEMP_OFFSET 0
          Globals (.h)
          #include <DHT.h>
          #include <SparkFunTSL2561.h>
          enum {
            ON,
            OFF
          //** Define sleep time
          static const uint64_t UPDATE_INTERVAL = 30000;
          //** Define force values
          static const uint8_t FORCE_UPDATE_N_READS_T = 10; //Temperature force value
          static const uint8_t FORCE_UPDATE_N_READS_H = 10; //Humidity force value
          static const uint8_t FORCE_UPDATE_N_READS_L = 10; //LightLevel force value
          static const uint8_t FORCE_UPDATE_N_READS_B = 50; //Binairy force value
          // Vars for battery level measurement
          int batterySensePin = A0;
          int oldBatteryPcnt = 0;
          uint8_t nNoUpdatesBatt;
          // Vars for DHT sensor
          DHT dht;
          float lastTemp;
          float lastHum;
          uint8_t nNoUpdatesTemp;
          uint8_t nNoUpdatesHum;
          bool metric = true;
          //Vars for TSL2461
          SFE_TSL2561 light;
          int lastLux;
          int mlux;
          boolean gain;     // Gain setting, 0 = X1, 1 = X16;
          unsigned char time;
          unsigned int ms;  // Integration ("shutter") time in milliseconds
          uint8_t nNoUpdatesLight;
          volatile boolean lightInterrupt=true;
          //Vars for DI's
          volatile byte tripped = 0;
          int intPin[] = {2, 3, 5, 6, 7, 8};
          boolean currState[] = {OFF, OFF, OFF, OFF, OFF, OFF};
          volatile boolean lastState[] = {OFF, OFF, OFF, OFF, OFF, OFF};
          // Prepare messages for gateway
          MyMessage msgBatt(CHILD_ID_BATT, I_BATTERY_LEVEL);  // Battery message
          MyMessage msgHum(CHILD_ID_HUM, V_HUM);  // Humidity message
          MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); // Temperature message
          MyMessage msgLight(CHILD_ID_LIGHT, V_TEMP); // Lightlevel message
          MyMessage msgSwitch1(CHILD_ID_SWITCH1, V_TRIPPED);
          MyMessage msgSwitch2(CHILD_ID_SWITCH2, V_TRIPPED);
          MyMessage msgSwitch3(CHILD_ID_SWITCH3, V_TRIPPED);
          MyMessage msgSwitch4(CHILD_ID_SWITCH4, V_TRIPPED);
          MyMessage msgSwitch5(CHILD_ID_SWITCH5, V_TRIPPED);
          MyMessage msgSwitch6(CHILD_ID_SWITCH6, V_TRIPPED);
          • J jimmy loyens
              noInterrupts();
              if (tripped) {
                    switch (i) {
                      case 0:
                        break;
                      case 1:
                        break;
                      case 2:
                        break;
                      case 3:
                        break;
                      case 4:
                        break;
                      case 5:
                        break;
                      default:
                interrupts();
                return true;
              interrupts();
              return false;
            @jimmy-loyens I haven't analyzed everyhing you posted, but calling send from within an ISR will not work. Send will need to communicate over SPI which will be problematic when clocks and interrupts are disabled.
            So you'll need to refactor the code. That doesn't explain why sleep isn't woken up by the interrupts though.
            • J jimmy loyens
              @jimmy-loyens
              Setup & loop (.ino)
                 REVISION HISTORY
                 DESCRIPTION
              //** Includes
              #include <Wire.h>
              //* INTERRUPTS *//
                tripped = true;
                GetDigital();
                tripped = true;
                GetDigital();
                setupBattery();
                //* SETUP DHT *//
                setupDHT();
                setupTSL();
                //* SETUP DI's *//
                setupDI();
                processBattLevel();
                processHumidity();
                //* SLEEP *//
              Battery (.ino)
              #else
                noInterrupts();
                interrupts();
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
                  nNoUpdatesBatt = 0;
                else {
                  nNoUpdatesBatt++;
              DHT (.ino)
                noInterrupts();
                interrupts();
                  if (!metric) {
                  nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
                else {
                  nNoUpdatesTemp++;
                noInterrupts();
                interrupts();
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
                else {
                  nNoUpdatesHum++;
              Digital (.ino)
              #ifdef PULL_UP_EN
              #ifdef MY_DEBUG
                  Serial.print(i);
                  Serial.print(": ");
                noInterrupts();
                  switch (i) {
                    case 0:
                      break;
                    case 1:
                      break;
                    case 2:
                      break;
                    case 3:
                      break;
                    case 4:
                      break;
                    case 5:
                      break;
                    default:
                interrupts();
                noInterrupts();
                if (tripped) {
                      switch (i) {
                        case 0:
                          break;
                        case 1:
                          break;
                        case 2:
                          break;
                        case 3:
                          break;
                        case 4:
                          break;
                        case 5:
                          break;
                        default:
                  interrupts();
                  return true;
                interrupts();
                return false;
              Presentation (.ino)
                noInterrupts();
                interrupts();
              TSL (.ino)
              pciSetup(16);
                light.begin();
                gain = 1;
                time = 2;
                light.setPowerUp();
                // ms = 1000;
                //delay(ms);
              #ifdef MY_DEBUGX
              if(data0>65000){
                gain=0;
              if(data0<500){
                gain=1;
                  if (good) {
              #ifdef MY_DEBUGX
                    if (isnan(mlux)) {
                      lastLux = mlux;
              #ifdef MY_DEBUG
                      Serial.print(mlux);
                    else {
                      nNoUpdatesLight++;
              Defines (.h)
              #define MY_DEBUGX
              //** Define node ID
              #define INT_PIN1  2
              #define INT_PIN2  3
              #define INT_PIN3  5
              #define INT_PIN4  6
              #define INT_PIN5  7
              #define INT_PIN6  8
              //** DHT defines
              Globals (.h)
              #include <DHT.h>
              enum {
                ON,
                OFF
              DHT dht;
              float lastTemp;
              float lastHum;
              bool metric = true;
              //Vars for TSL2461
              SFE_TSL2561 light;
              int lastLux;
              int mlux;
              unsigned char time;
              //Vars for DI's
              J
              J
              jimmy loyens
              @jimmy-loyens Oh I see now, ....
              the node isn't waking up by any of my interrupt vectors. GetDigital does more then just getting the interrupt pin, it allso sends a message inside the ISR. Thats why status changes on digital pins are sent immediatly. the node never wakes up to send them its handeled by the interrupt!!!
              This is not possible for my lightsensor (evaluate & send mssg in ISR) because this uses functions (i think). Is the sleep function expecting interrupt pins on the 'interrupt1' & 'interrupt2' parameters? Does anyone have an idea for a workaround? I have about 50 of these pcb's so its a little late for a re-design :cry: :weary:
              • J
                J
                jimmy loyens
                @mfalkvidd For the digital pins send seems to work just fine, as long as i don't use any functions inside the ISR
                • J jimmy loyens
                  J
                  J
                  jimmy loyens
                  @jimmy-loyens
                  These mssges where all sent from within ISR:
                  Pin 2 triggered: 0
                  8417 !TSF:MSG:SEND,59-59-0-0,s=4,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  Pin 2 triggered: 1
                  8419 !TSF:MSG:SEND,59-59-0-0,s=4,c=1,t=16,pt=1,l=1,sg=0,ft=1,st=NACK:1
                  Pin 3 triggered: 0
                  8421 TSF:MSG:SEND,59-59-0-0,s=5,c=1,t=16,pt=1,l=1,sg=0,ft=2,st=OK:0
                  Pin 3 triggered: 1
                  8423 !TSF:MSG:SEND,59-59-0-0,s=5,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  8425 MCO:SLP:WUP=-1
                  8427 MCO:SLP:MS=30000,SMS=0,I1=114,M1=2,I2=75,M2=1
                  8433 MCO:SLP:TPD
                  Pin 5 triggered: 0
                  8435 !TSF:MSG:SEND,59-59-0-0,s=6,c=1,t=16,pt=1,l=1,sg=0,ft=1,st=NACK:0
                  Pin 5 triggered: 1
                  8437 !TSF:MSG:SEND,59-59-0-0,s=6,c=1,t=16,pt=1,l=1,sg=0,ft=2,st=NACK:1
                  Pin 6 triggered: 0
                  8439 !TSF:MSG:SEND,59-59-0-0,s=7,c=1,t=16,pt=1,l=1,sg=0,ft=3,st=NACK:0
                  Pin 6 triggered: 1
                  8441 !TSF:MSG:SEND,59-59-0-0,s=7,c=1,t=16,pt=1,l=1,sg=0,ft=4,st=NACK:1
                  8443 MCO:SLP:WUP=-1
                  8445 MCO:SLP:MS=30000,SMS=0,I1=114,M1=2,I2=75,M2=1
                  8452 MCO:SLP:TPD
                  Pin 7 triggered: 0
                  8454 !TSF:MSG:SEND,59-59-0-0,s=8,c=1,t=16,pt=1,l=1,sg=0,ft=5,st=NACK:0
                  Pin 7 triggered: 1
                  8456 !TSF:MSG:SEND,59-59-0-0,s=8,c=1,t=16,pt=1,l=1,sg=0,ft=6,st=NACK:1
                  8458 MCO:SLP:WUP=-1
                  8460 !TSM:READY:UPL FAIL,SNP
                  i think the NACK comes from triggering pins in fast tempo
                  • J jimmy loyens
                    @jimmy-loyens
                    Pin 2 triggered: 0
                    Pin 2 triggered: 1
                    Pin 3 triggered: 0
                    Pin 3 triggered: 1
                    8425 MCO:SLP:WUP=-1
                    8433 MCO:SLP:TPD
                    Pin 5 triggered: 0
                    Pin 5 triggered: 1
                    Pin 6 triggered: 0
                    Pin 6 triggered: 1
                    8443 MCO:SLP:WUP=-1
                    8452 MCO:SLP:TPD
                    Pin 7 triggered: 0
                    Pin 7 triggered: 1
                    8458 MCO:SLP:WUP=-1
                    J
                    J
                    jimmy loyens
                    The whole problem seems to originate from the node not waking up by the interruptvectors. If i can get the node to wake up by PCINT0_vect/PCINT1_vect/PCINT2_vect i can process data and send messages outside the ISR. I gues thats why i resorted to sending messages in ISR a year ago. Does anyone know how to wake the node by these interrupt vectors? maybe i can re-write the sleep function to do this?
                    • J
                      J
                      jimmy loyens
                      I just found this post on the forum: https://forum.mysensors.org/topic/6352/pin-change-interrupt-on-any-pin/11
                      It adds "_wokeUpByInterrupt = 0xFE; // Dirty hack to get out of MySensors sleep loop" at the end of every ISR
                      and
                      "// Unset value from dirty hack to get out of sleep loop (set in interrupt)
                      _wokeUpByInterrupt = INVALID_INTERRUPT_NUM;" at the beginning of loop.
                      I tried it, not knowing at all what i'm doing by adding these lines. But i do know it works!!! Even if it is a dirty hack, IT WORKS!!!! :raised_hands: :grin: :+1: :ok_hand: :clap:
                      Now i can rewrite my code to do the processing/messaging in loop outside of the ISR. If anyone can explane what these lines do exactly please let me know.
                      It would be even nicer if somewhere in the future there could be a sleep function in the MySensors library that supports these pinchange interrupt vectors, but this hack makes it work for now.
                      Thanks for all the help!
