  3. [SOLVED] arduino no longer compiles Gateway W5100MQTTClient
5 Posts 2 Posters 1.2k Views 2 Watching
  • J
    J
    jimmy loyens
    When trying to compile the example from the mysensors library : "GatewayW5100MQTTClient" arduino throws error:
    C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\EthernetClient.cpp: In member function 'operator==':
    C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\EthernetClient.cpp:177:1: internal compiler error: Segmentation fault
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <http://gcc.gnu.org/bugs.html> for instructions.
    lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
    compilation terminated.
    c:/program files/windowsapps/arduinollc.arduinoide_1.8.19.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
    collect2.exe: error: ld returned 1 exit status
    compiled just fine yesterday :sleepy: :anguished:
    When i copy and paste the code from https://www.mysensors.org/build/mqtt_gateway everything compiles fine :dizzy_face:
    YveauxY 1 Reply Last reply
    • J jimmy loyens
      YveauxY
      YveauxY
      @jimmy-loyens said in arduino no longer compiles Gateway W5100MQTTClient:
      So, what changed?
      Try arduino ide 1.8.8 from arduino.cc website
      J 1 Reply Last reply
      • YveauxY Yveaux
        So, what changed?
        J
        J
        jimmy loyens
        @yveaux yesterday i allso copied the code from the link (forgot). Its the same code as far as i can see. Code from link compiles, example doesnt 🤔
        • J jimmy loyens
          YveauxY
          YveauxY
          @jimmy-loyens seems that you are not alone : http://forum.arduino.cc/index.php?topic=576749.0
          At the end of that thread is a workaround you can give a try.
          • J
            J
            jimmy loyens
            That workaround did it, now the library example compiles. Thanks:clap: :clap: :clap:
