  3. [lib 2.3.0, IDE 1.8.8] [UNO + 5100 shield] gateway hangs
5 Posts 3 Posters 1.2k Views 3 Watching
  • macieiksM
    macieiksM
    macieiks
    Hello everyone,
    I really appreciate hard work for everyone who is involved in MySensors project.
    I am having the following issue:
    After upgrading Arduino IDE (1.8.8 MAC) and MySensors library (2.3.0) I am having difficulties with my Arduino UNO + W5100 shield gateway.
    Generally it works randomly, sometimes it is working without any issues, sometimes crashing after 5-10 minutes.
    To makes things simple I disconnected all other nodes and this time it is running only on gateway with 1 node (in close range).
    I tried to catch some logs, as you can see below, my node 98 is sending temperature update every 10 seconds.
    From what I have observed. When I power off node 98 and power on again, in Domoticz logs I see the node is not reporting data anymore. To add more, when I was troubleshooting it previously I observed that even data from other nodes was not updated in Domoticz after powercycle of one node).
    However, checking further in Arduino IDE serial monitor logs I indeed see that after node reboot, gateway IS reading data from rebooted node - it is really confusing, sounds like issue between gateway and controller. But, sometimes, when I power cycle node, I see that even gateway itself is rebooting - this reset is visible in domoticz logs as "gateway reset".
    I really appreciate any hints & advise ! :)
    Thank you,
    Maciek
    FYI: Timestamps are almost synchronised (Arduino IDE <-> Domoticz).
    Domoticz logs:
    2019-01-23 13:28:12.705 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:28:24.683 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:28:36.662 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:28:48.639 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:29:00.618 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:29:12.597 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:29:24.575 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:29:36.552 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:29:48.531 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:30:00.505 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:30:12.486 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:30:24.463 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:30:36.441 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:30:41.866 (Xiaomi GW) Temp (Biuro)
    2019-01-23 13:30:41.868 (Xiaomi GW) Humidity (Xiaomi Humidity)
    2019-01-23 13:30:41.875 (Xiaomi GW) General/Pressure (Xiaomi Pressure)
    2019-01-23 13:30:41.896 (Xiaomi GW) Temp (Biuro)
    2019-01-23 13:30:41.898 (Xiaomi GW) Humidity (Xiaomi Humidity)
    2019-01-23 13:30:41.899 (Xiaomi GW) General/Pressure (Xiaomi Pressure)
    ## LAST UPDATE FROM NODE 98 - 2019-01-23 13:30:48.434
    2019-01-23 13:30:48.434 (MySensors GW) Temp (Dallas TEST)
    2019-01-23 13:31:37.959 (Z-Wave GW) Lux (Hol Jasność)
    2019-01-23 13:31:37.977 (Z-Wave GW) Temp (Hol)
    2019-01-23 13:33:05.179 (Xiaomi GW) Temp (Salon)
    2019-01-23 13:33:05.181 (Xiaomi GW) Humidity (Xiaomi Humidity)
    2019-01-23 13:33:05.240 (Xiaomi GW) General/Pressure (Xiaomi Pressure)
    Arduino Serial Monitor logs:
    13:28:02.708 -> 291276 GWT:TSA:ETH OK
    13:28:02.708 -> 291281 GWT:RFC:MSG=0;0;3;0;2;
    13:28:02.708 -> 291287 GWT:RFC:MSG=0;0;3;0;2;Get Version
    13:28:11.683 -> 300228 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:28:12.720 -> 301272 GWT:RFC:MSG=0;0;3;0;18;PING
    13:28:22.698 -> 311266 GWT:RFC:MSG=0;0;3;0;18;PING
    13:28:23.635 -> 312200 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:28:32.710 -> 321261 GWT:RFC:MSG=0;0;3;0;18;PING
    13:28:35.640 -> 324170 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:28:42.718 -> 331255 GWT:RFC:MSG=0;0;3;0;18;PING
    13:28:47.596 -> 336141 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:28:52.709 -> 341250 GWT:RFC:MSG=0;0;3;0;18;PING
    13:28:59.563 -> 348111 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:29:02.719 -> 351245 GWT:RFC:MSG=0;0;3;0;18;PING
    13:29:11.546 -> 360082 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:29:12.734 -> 361239 GWT:RFC:MSG=0;0;3;0;18;PING
    13:29:22.726 -> 371233 GWT:RFC:MSG=0;0;3;0;18;PING
    13:29:23.538 -> 372052 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:29:32.704 -> 381229 GWT:RFC:MSG=0;0;3;0;18;PING
    13:29:35.532 -> 384022 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.3
    13:29:42.738 -> 391223 GWT:RFC:MSG=0;0;3;0;18;PING
    13:29:47.504 -> 395994 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:29:52.732 -> 401217 GWT:RFC:MSG=0;0;3;0;18;PING
    13:29:59.469 -> 407964 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.3
    13:30:02.738 -> 411211 GWT:RFC:MSG=0;0;3;0;18;PING
    13:30:11.441 -> 419934 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.3
    13:30:12.729 -> 421207 GWT:RFC:MSG=0;0;3;0;18;PING
    13:30:22.715 -> 431201 GWT:RFC:MSG=0;0;3;0;18;PING
    13:30:23.428 -> 431903 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.3
    13:30:32.717 -> 441195 GWT:RFC:MSG=0;0;3;0;18;PING
    13:30:35.416 -> 443874 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.3
    13:30:42.723 -> 451190 GWT:RFC:MSG=0;0;3;0;18;PING
    13:30:47.408 -> 455860 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:30:52.721 -> 461185 GWT:RFC:MSG=0;0;3;0;18;PING
    ##(Around this time I plug off / plug in temperature sensor node 98, and Gateway W5100 hangs)
    13:30:58.753 -> 467210 TSF:MSG:READ,98-98-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    13:30:58.753 -> 467215 TSF:MSG:BC
    13:30:58.753 -> 467217 TSF:MSG:FPAR REQ,ID=98
    13:30:58.753 -> 467219 TSF:PNG:SEND,TO=0
    13:30:58.753 -> 467222 TSF:CKU:OK
    13:30:58.753 -> 467223 TSF:MSG:GWL OK
    13:31:00.880 -> 469321 !TSF:MSG:SEND,0-0-98-98,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    13:31:00.880 -> 469327 TSF:MSG:READ,98-98-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    13:31:00.880 -> 469334 !TSF:MSG:LEN,0!=7
    13:31:00.880 -> 469336 TSF:MSG:READ,98-98-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    13:31:00.880 -> 469341 !TSF:MSG:LEN,0!=7
    13:31:00.880 -> 469344 TSF:MSG:READ,98-98-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    13:31:00.880 -> 469349 !TSF:MSG:LEN,0!=7
    13:31:00.880 -> 469351 TSF:MSG:READ,98-98-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    13:31:00.915 -> 469357 !TSF:MSG:LEN,0!=7
    13:31:02.730 -> 471179 GWT:RFC:MSG=0;0;3;0;18;PING
    13:31:02.839 -> 471306 TSF:MSG:READ,98-98-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    13:31:02.877 -> 471311 TSF:MSG:PINGED,ID=98,HP=1
    13:31:02.877 -> 471318 TSF:MSG:SEND,0-0-98-98,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    13:31:02.877 -> 471331 TSF:MSG:READ,98-98-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    13:31:02.877 -> 471339 TSF:MSG:SEND,0-0-98-98,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    13:31:02.877 -> 471348 TSF:MSG:READ,98-98-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
    13:31:02.913 -> 471358 TSF:MSG:READ,98-98-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    13:31:04.908 -> 473368 TSF:MSG:READ,98-98-0,s=255,c=3,t=11,pt=0,l=11,sg=0:Szafa Media
    13:31:04.942 -> 473380 TSF:MSG:READ,98-98-0,s=255,c=3,t=12,pt=0,l=5,sg=0:2.3.0
    13:31:04.942 -> 473391 TSF:MSG:READ,98-98-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
    13:31:04.942 -> 473401 TSF:MSG:READ,98-98-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    13:31:04.978 -> 473417 TSF:MSG:SEND,0-0-98-98,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    13:31:05.849 -> 474311 TSF:MSG:READ,98-98-0,s=255,c=3,t=0,pt=1,l=1,sg=0:83
    13:31:05.884 -> 474320 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:31:12.721 -> 481174 GWT:RFC:MSG=0;0;3;0;18;PING
    13:31:17.854 -> 486290 TSF:MSG:READ,98-98-0,s=255,c=3,t=0,pt=1,l=1,sg=0:79
    13:31:17.854 -> 486299 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:31:22.743 -> 491168 GWT:RFC:MSG=0;0;3;0;18;PING
    13:31:29.822 -> 498269 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:31:32.727 -> 501163 GWT:RFC:MSG=0;0;3;0;18;PING
    13:31:41.814 -> 510238 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    13:31:42.717 -> 511157 GWT:RFC:MSG=0;0;3;0;18;PING
    13:31:52.739 -> 521152 GWT:RFC:MSG=0;0;3;0;18;PING
    13:31:53.803 -> 522208 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.3
    13:32:02.714 -> 531146 GWT:RFC:MSG=0;0;3;0;18;PING
    13:32:05.779 -> 534176 TSF:MSG:READ,98-98-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.4
    Gateway sketch (almost the same as default)
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,0,6
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    #define MY_PORT 5006
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 8  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  9  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  10  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Node 98 sketch (It is Arduino Pro Mini 3.3v on sundberg84 PCB (big appreciate for author work on this project :) )
    #define MY_NODE_ID 98
    #include <OneWire.h>
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    #define MAX_ATTACHED_DS18B20 1
    unsigned long SLEEP_TIME = 10000; // Sleep time between reads (in milliseconds)
    float currentTemperature[MAX_ATTACHED_DS18B20];
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    int oldBatteryPcnt = 0;
    void before()
      sensors.begin();
      analogReference(INTERNAL1V1);
    #else
      analogReference(INTERNAL);
    void presentation() {
      sendSketchInfo("Szafa Media", "2.3.0");
         present(i, S_TEMP);
        // get the battery Voltage
      #ifdef MY_DEBUG
      Serial.println(sensorValue);
      #ifdef MY_DEBUG
      float batteryV  = sensorValue * 0.003363075;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
      sleep(conversionTime);
        // Fetch and round temperature to one decimal sensors.getTempCByIndex(i)
        //currentTemperature[i] = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        currentTemperature[i] = sensors.getTempCByIndex(i);
        lastTemperature[i]=currentTemperature[i];
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
          #if COMPARE_TEMP == 1
          if (lastTemperature[i] != currentTemperature[i] && currentTemperature[i] != -127.00 && currentTemperature[i] != 85.00) {
          #else
          if (currentTemperature[i] != -127.00 && currentTemperature[i] != 85.00) {
          send(msg.setSensor(i).set(currentTemperature[i],1));
      sleep(SLEEP_TIME);
    RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
    RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
    RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
    G mfalkviddM 2 Replies Last reply
    • macieiksM macieiks
      Hello everyone,
      Thank you,
      Maciek
      Domoticz logs:
       * LED purposes:
      #define MY_SOFTSPI
      int numSensors=0;
      bool metric = true;
      void before()
        sensors.begin();
      #else
           present(i, S_TEMP);
        #ifdef MY_DEBUG
        #ifdef MY_DEBUG
            #else
        sleep(SLEEP_TIME);
      G
      G
      Guillermo Schimmel
      @macieiks Hi!
      How are you powering the node?
      I had a lot of trouble with heat with mine. The 1117 regulator on the arduino uno wasn't coping with the w5100 power requirements.
      It was triggering the thermal cut on it (100+ ºC!!!)
      Is your Uno hot?
      macieiksM 1 Reply Last reply
        Hello everyone,
        Thank you,
        Maciek
        Domoticz logs:
         * LED purposes:
        #define MY_SOFTSPI
        int numSensors=0;
        bool metric = true;
        void before()
          sensors.begin();
        #else
             present(i, S_TEMP);
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
              #else
          sleep(SLEEP_TIME);
        @macieiks how is the nrf24 on the gateway powered? I see that you're using RF24_PA_MAX which puts even higher stress on the power supply than normal. What capacitor(s) are you using?
        See if reverting to the default power level helps.
        • G Guillermo Schimmel
          @macieiks Hi!
          Is your Uno hot?
          macieiksM
          macieiksM
          macieiks
          wrote on last edited by macieiks
          @guillermo-schimmel
          I think it is not a case. It has normal temperature. It was running fine before ;)
          @mfalkvidd
          I have AMS1117-3.3V pcb adapter soldered directly to UNO (under USB TypeB) connection. It is feeding 5V directly from 2A usb charger and converting to 3.3V. I am installing always 4,7uF capacitor near NRF antenna pins across all my nodes / gateway.
          I tried before adjusting to "LOW" settings. Powering from built-in Uno's 3.3V socket - unfortunately it is the same.
          I think this is somehow related with other thing, because I am receiving "reads" from the node 98.
          But I do not give up :D This is excellent project ;)
          Checking further, please see attached Domoticz log.
          After 14:58:00 I have powercycled node 98. As you can see it did not came up after, but in Serial Monitor (on Gateway) I could see reads from it. I have 5 min timeout configured in Domoticz hardware tab. After 5 minutes, Domoticz restarted MySensors service. After that it came up and updates were visible in the domoticz system.
          2019-01-23 14:57:36.335 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 14:57:48.316 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 14:58:00.297 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:01:11.563 (Z-Wave GW) Lux (Hol Jasność)
          2019-01-23 15:01:11.581 (Z-Wave GW) Temp (Hol)
          2019-01-23 15:04:17.440 (Xiaomi GW) Temp (Zewnętrzny)
          2019-01-23 15:04:17.457 (Xiaomi GW) Humidity (Xiaomi Humidity)
          2019-01-23 15:04:17.481 (Xiaomi GW) General/Pressure (Xiaomi Pressure)
          2019-01-23 15:04:19.500 Error: MySensors GW hardware (7) nothing received for more than 5 Minutes!....
          2019-01-23 15:04:20.501 Status: MySensors: TCP/IP Worker stopped...
          2019-01-23 15:04:20.504 Status: MySensors: trying to connect to: 192.168.0.6:5006
          2019-01-23 15:04:20.505 Status: MySensors: connected to: 192.168.0.6:5006
          2019-01-23 15:04:20.501 Error: Restarting: MySensors GW
          2019-01-23 15:06:10.013 (Z-Wave GW) Lux (Hol Jasność)
          2019-01-23 15:06:10.031 (Z-Wave GW) Temp (Hol)
          2019-01-23 15:09:27.956 Error: MySensors GW hardware (7) nothing received for more than 5 Minutes!....
          2019-01-23 15:09:28.966 MySensors: Gateway Ready...
          2019-01-23 15:09:28.972 MySensors: Gateway Version: 2.3.0
          2019-01-23 15:09:28.978 MySensors: Gateway Version: 2.3.0
          2019-01-23 15:09:28.958 Status: MySensors: TCP/IP Worker stopped...
          2019-01-23 15:09:28.961 Status: MySensors: trying to connect to: 192.168.0.6:5006
          2019-01-23 15:09:28.962 Status: MySensors: connected to: 192.168.0.6:5006
          2019-01-23 15:09:28.957 Error: Restarting: MySensors GW
          2019-01-23 15:09:37.743 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:09:49.721 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:10:01.698 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:10:13.678 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:10:25.656 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:10:37.634 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:10:49.612 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:11:01.589 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:11:08.538 (Z-Wave GW) Lux (Hol Jasność)
          2019-01-23 15:11:08.556 (Z-Wave GW) Temp (Hol)
          2019-01-23 15:11:13.570 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:11:25.548 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:11:37.526 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:11:49.505 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:12:01.481 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:12:13.461 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:12:25.439 (MySensors GW) Temp (Dallas TEST)
          2019-01-23 15:12:37.418 (MySensors GW) Temp (Dallas TEST)```
          • macieiksM
            macieiksM
            macieiks
            [UPDATE]
            I have tried in several way with no luck - even formatting Raspberry Pi card with fresh Domoticz. I did workaround and changed gateway to Raspberry Pi + NRF24 option. It is working perfectly and I have got ability to check and investigate MySensors debug logs remotely thanks to logging to pipe :)
            Regards,
            Maciek
