  3. Which Lab Power Supply?
24 Posts 14 Posters 16.0k Views 10 Watching
  • AWIA AWI
    @HenryWhite Looks good. I did something similar (not completely finished) but went too cheap ;-(
    A huge (0.3 V) noise/ripple on the output.... Are you able to measure the ripple with the converter you used? And what kind of transformer did you use?
    0_1460204514941_upload-fba2c7ca-80c5-4017-814e-03c5dda8de8a
    HenryWhiteH
    HenryWhiteH
    HenryWhite
    wrote on last edited by HenryWhite
    #21
    Looks good too!
    I can't measure it, because I don't have an oscilloscope (yet) :smile:
    For powering the module, I used an old 12V laptop power supply.
    • mountainmanM
      mountainmanM
      mountainman
      Any thoughts on a case (ebay/ali) for homemade PSUs?
      • AWIA AWI
        rvendrameR
        rvendrameR
        rvendrame
        @AWI , a did a similar thing, but never got the volt/amper meter work properly on the 'negative side'. Mine looks very similar (to not say identical) to yours... Would you mind to share how did you connected the V-A meters?
        ESP8266 GW + mySensors 2.3.2
        Alexa / Google Home
        AWIA 1 Reply Last reply
        • rvendrameR rvendrame
          AWIA
          AWIA
          AWI
          @rvendrame As far as I remember there are two similar power positive voltage (isolated) power supplies with the meter in the positive line. Then connect the positive line of no 1 to the negative line of no 2.
