  3. Which Lab Power Supply?
24 Posts 14 Posters 16.0k Views 10 Watching
    wrote on last edited by hek
    Need a recommendation on a stabilized lab power supply 0-30V. Without fan.
    Price range $150-250
    • YveauxY
      YveauxY
      I own a Voltcraft lab supply. Outputs 0..30V and a separate 0..5V supply.
      Served me for many years without a single problem and sufficient for most tasks..
        Was actually looking at this one now:
        http://www.conrad.com/ce/en/product/511813/VOLTCRAFT-VLP-1602pro-102W-2-Output-Variable-DC-Power-Supply-Linear-Bench
        • YveauxY
          YveauxY
          Looks like the modern version of the one I have indeed!
          • blaceyB
            blaceyB
            blacey
            I bought this one - http://www.ebay.com/itm/Pro-30V-5A-Digital-DC-Power-Supply-Current-Tool-Precision-Variable-Adjustable-/370586966860?pt=LH_DefaultDomain_0&hash=item5648b45b4c upon recommendation from Peter Easton, the inventor of ControlLeo. Inexpensive and I have been pretty happy with it.
            YveauxY 1 Reply Last reply
            • tbowmoT
              tbowmoT
              tbowmo
              @hek
              build one yourself? :)
              hekH 1 Reply Last reply
              • tbowmoT tbowmo
                @hek
                Yeah.. we're DIY people here right? :)
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @hek
                  I'm still using my own "homegrown" lab supply, that I build 23 years ago :)
                  • blaceyB blacey
                    YveauxY
                    YveauxY
                    @blacey There are many clones of this supply available, and I've work with one of these in the past.
                    I can confirm it works OK indeed!
                    • DammeD
                      DammeD
                      Damme
                      Code Contributor
                      I like this one, It's not fanless but hackable and 3 channels; http://www.meilhaus.de/en/rigol+dp832,i2.htm
                      • Igor KatkovI
                        Igor KatkovI
                        Igor Katkov
                        Some ppl suggest - DIY.
                        The problem with DIY is that you need to know well what are you doing and you also need tools to debug your power supply when it does not work. Non of that applies to a typical novice.
                        I suggest getting one of the low-end bench grade power supplies ~$100 on amazon.
                        Example: http://www.amazon.com/gp/product/B00FPU6G4E
                        Make sure you don't try to save $20 and buy the cheapest possible with low precision pots.
                        Hi precision pots a re like $10+ a piece alone so you are likely to save nothing if decided to upgrade yourself. I did that and I regret it.
                        One bench power supply is not enough so you can DIY your second one.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          I recently bought the digital edition of the korad supply http://m.reichelt.de/KA3005P/3/index.html?&ACTION=3&LA=446&ARTICLE=135689&artnr=KA3005P&SEARCH=Korad
                          And being a sensor / control freak, I bought the one that could be controlled from a computer :) 109€ isn't that bad..
                          • D
                            D
                            DavidZH
                            As I'm also searching for a new supply (I have a 2 x 30V/3A "LongWei" clone but it drifts like no other.... And I want something lighter). I tend to follow all the threads on the fora I frequent.
                            On the Tweakers.nl forum I saw a fellow tweaker who had bought one of the Korads and took EEVBlogs motto to heart. And that was a good thing! The wiring is prone to get torn on a sharp metal edge and that includes the line voltage wiring!!!!
                            So if you own one of these, please open yours up and check for abrasions!
                            The forum is in Dutch but the pictures speak for themselves: C.44 on GoT
                            My search will continue (the Rigol one looks very tempting. But that fan! :confounded: )
                            • GertSandersG
                              GertSandersG
                              GertSanders
                              wrote on last edited by GertSanders
                              I'm also interested to know if there is software for OSX that allows control of a power supply. Most power supplies have Windows software only :-(
                              • I
                                I
                                Ironbar
                                I am really considering this one:
                                http://www.amazon.com/gp/product/B012LMOI84?colid=Y744CSFT9FT9&coliid=ICZ9KPR69X86E&ref_=wl_it_dp_o_pC_S_ttl
                                EEVBlog has a little write up about it. It has a fan but it is variable and they say it is quite:
                                http://www.eevblog.com/forum/testgear/inside-the-new-korad-ka3305p-linear-psu/
                                • Igor KatkovI
                                  Igor KatkovI
                                  Igor Katkov
                                  What are the benefits of software controlled PSU versus turn-knob style?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Igor-Katkov
                                    on a sw controlled, you could have memories for the different voltages that you usually work with (for me that's 3V3, and 5V). Just a single press of a button to set the desired output voltage..
                                    Other than that, I don't see any advantages..
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      It it is software controlled, you could also script things. Useful for testing stuff. Rough emulation of battery powered behavior and such.
                                      • HenryWhiteH
                                        HenryWhiteH
                                        HenryWhite
                                        wrote on last edited by HenryWhite
                                        Just buy a LTC3780 (link), exchange the pots, hook up a volt/amp display and there you have it: your own lab power supply which can deliver 1V-30V // 0A - 8A, 10A peak.
                                        Here's mine:
                                        AWIA 1 Reply Last reply
                                        • HenryWhiteH HenryWhite
                                          Here's mine:
                                          AWIA
                                          AWIA
                                          AWI
                                          @HenryWhite Looks good. I did something similar (not completely finished) but went too cheap ;-(
                                          A huge (0.3 V) noise/ripple on the output.... Are you able to measure the ripple with the converter you used? And what kind of transformer did you use?
                                          0_1460204514941_upload-fba2c7ca-80c5-4017-814e-03c5dda8de8a
                                          HenryWhiteH rvendrameR 2 Replies Last reply
