  3. OpenHAB
  4. Status LED issues with Raspberry Pi gateway
3 Posts 3 Posters 1.7k Views 3 Watching
  • DbagioniD
    DbagioniD
    Dbagioni
    Morning all.
    Ive just had to completely rebuild my openhab and mysensors set up. Im running OH 2.4 on a Raspberry Pi 3B+, with the MySensors 2.4 bindings. Gateway compiles and runs fine....butttt I acidentaly configured --my-leds-blinking-inverse. How do i unconfigure it.
    Second led issue. The red error led is always lit, no blink, just steady burn. It is wired as noted in the guide.
    Should i reneter the options and then remake the gate way? Im not sure how to go about this I was using arduinos before and there you just deleted the options from the sketch and reloaded it.
    Thanks for the advice in advance
    YveauxY mfalkviddM 2 Replies Last reply
    • DbagioniD Dbagioni
      Morning all.
      YveauxY
      YveauxY
      @dbagioni said in Status LED issues with Raspberry Pi gateway:
      According to: https://github.com/mysensors/MySensors/blob/development/Makefile
      make cleanconfig
      Insn't that beacuse you configured --my-leds-blinking-inverse ???
        Morning all.
        @dbagioni run a new ./configure with the settings you want. Then build, test and install as normal.
