  3. [contest] My 12 input high precision pulse counter (kWh/ W)
[contest]
43 Posts 9 Posters 54.7k Views 10 Watching
  • NickBuilderN NickBuilder
    Hi @AWI!
    The GIT link is broken. Can I find your sketch for this counter elsewhere?
    I would like to implement this counter as a "local sensor" on an ethernet gateway without radio. I guess this would require some tweaking but right now I'm confident. x)
    Thanks!
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    #41
    @NickBuilder soory but the transition to 2.0 gave me a little GIT headache and I broke some links.. I restored the pulse counter sketches. Be carefull with combining the sketch with ethernet functionality... Both eat a lot of RAM/ROM and are time critical.
    The sketch also stores a large amount of data in EEPROM. Be aware that the space there is more limited than the 256 bytes mentioned with saveState().
    Please share your progress
    J 1 Reply Last reply
    • AWIA AWI
      J
      J
      jeti
      @AWI as did got get my modifcations 100% running I was pumped to see your latest update, but for reasons i do not understand i get an error while compiling:
      error: 'hour' was not declared in this scope
      same is the case for setTime, minute etc...
      i already tried some stuff with the time.h but it seems nothing has an impact, not even deleting the whole library (which should end in a "libraby not found" error, but only shows the errors described above)
      any idea what to look for?
      thanks
      • J jeti
        thanks
        J
        J
        jeti
        ok found the answer :stuck_out_tongue:
        the latest Time.h is only pointing to TimeLib.h so if I am calling TimeLib.h (instead of Time.h) directly it compiles
