  3. Problem with sensors on arduino and domoticz
27 Posts 4 Posters 4.1k Views 4 Watching
  • Nca78N Nca78
    @hyperflemme did rebuild the gateway script with #define MY_GATEWAY_SERIAL ?
    Then did you add the gateway in the hardware tab of domoticz ?
    H
    H
    hyperflemme
    @nca78 domoticz recognize the arduino card, his version of gateway, but into hardware tab if i change the card i have an children "Unknown" with id 3 and an other child unusable with a ID 255.
    in the log of domoticz i have "Gateway ready"
    Nca78N 1 Reply Last reply
    • H hyperflemme
      Nca78N
      Nca78N
      @hyperflemme so it's good news domoticz can see your gateway.
      Can you post the script you are using now ?
      H 1 Reply Last reply
      • Nca78N Nca78
        H
        H
        hyperflemme
        @nca78 the script of the gateway or the script of one of the sensors?
        I give you both juste here:
        for the gateway i just use this: https://www.mysensors.org/build/serial_gateway and i just added this before inclide mysensors.h:
        #define MY_RF24_CE_PIN 49
        #define MY_RF24_CS_PIN 53
        the script of the sensors is:
         * Version 1.0 - Henrik Ekblad
         * Motion Sensor example using HC-SR501
         * http://www.mysensors.org/build/motion
        // Enable debug prints
        // #define MY_DEBUG
        #define MY_RADIO_RF24
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
        // Initialize motion message
        	sendSketchInfo("Motion Sensor", "1.0");
        	present(CHILD_ID, S_MOTION);
        	// Read digital motion value
        	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        	Serial.println(tripped);
        	send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        	sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
        for motion sensor i use a PIR Sensor V1.0
        • K
          K
          kimot
          wrote on last edited by kimot
          #24
          I think we still do not know the topology of your network and we use different terms.
          For most of us a "sensor" is - temperature sensor, humidity sensor, pressure sensor, etc. These sensors are connected to Arduino, which we call the "node".
          These node are connected through radio or RS485 to Arduino which works like gateway and send received messages from nodes to controller ( Rpi with Domoticz ).
          Usually gateway have got no sensors and you can use pure gateway sketch from examples.
          But you can connect sensors directly to gateway, but you must modify gateway sketch then.
          • setup your sensors
          • present your sensors
          • send values form your sensors.
          And of course NO SLEEP FUNCTION in sensor send code.
          Places, where put it is marked by comments in gateway sketch:
          Usual topology:
          I think your topology:
          • K kimot
            Usual topology:
            H
            H
            hyperflemme
            @kimot Hi , tank's for your help,
            my topology: 0_1551269057197_UNADJUSTEDNONRAW_thumb_1.jpg
            how can i do?
            K 1 Reply Last reply
            • H hyperflemme
              how can i do?
              K
              K
              kimot
              @hyperflemme
              Use gateway sketch and add sensor presentation and sensor data sending like in node sketch.
              example from this forum:
              void presentation() {
                sendSketchInfo("AWI_ESP 120", "1.0");
                present(CHILD_ID, S_DIMMER, "AWI_ESP 120" " dimmer");
                present(CHILD_ID2, S_INFO, "AWI_ESP 120" " text");
               	send(msg.set(messageCounter)); 										// Send message to gw
              	messageCounter = ++messageCounter % 100 ;							// wrap
              	send(msg2.set("Hallo")); 											// Send message to gw
              	// Send update every SLEEP_TIME
              	wait(SLEEP_TIME) ;
              void receive(const MyMessage &message) {  								// messages from node or controller
              	//char printBuf[40] ;
              	//Serial.print(message.getInt());
              		//sprintf(printBuf, "Message node: %d %d  OK\n", message.sender, message.getInt());
              	//Serial.print(printBuf) ;
              	//sprintf(printBuf, "Messages: %d Errors: %d\n", messageCounter, messageErrorCounter);
              Search forum here, you are not alone with this solution.
              • K kimot
                @hyperflemme
                	wait(SLEEP_TIME) ;
                H
                H
                hyperflemme
                @kimot THANKS !!!
                for 1 sensor it's ok, but if i had a 2nd sensor he doesn't work...
