  3. Problem with sensors on arduino and domoticz
27 Posts 4 Posters 4.1k Views 4 Watching
  • Nca78N Nca78
    @hyperflemme you can check the log using the log parser
    https://www.mysensors.org/build/parser
    Here it says it cannot connect to parent, is you gateway active, and on the same radio channel ?
    H
    H
    hyperflemme
    Nca78N 1 Reply Last reply
    • H hyperflemme
      @hyperflemme as you can read "no potential parents replied to find parent request". It means no gateway replied to the radio calls.
      Please describe your full mysensors installation if you want help :
      • controller used ?
      • board, radio used for gateway ?
      • board, radio used for sensor ?
      H 1 Reply Last reply
      • H hyperflemme
        @kimot I have only 1 arduino, i have put the gateway into this card.
        K
        K
        kimot
        @hyperflemme
        Than in your second sketch ( with sensors )
        define MY_GATEWAY_SERIAL
        is missing.
        This sketch works like normal node without this, not as gateway with sensors connected.
        • Nca78N Nca78
          • controller used ?
          H
          H
          hyperflemme
          @nca78 Hi,
          I just have an nrf24l01 plug into my arduino.
          I miss something to make it work?
          Thank's for helping me
          • K kimot
            @hyperflemme
            is missing.
            H
            H
            hyperflemme
            @kimot in my sketch for motion sensor you think i just have to had #define MY_GATEWAY_SERIAL on the top of the program?
            Thank's for your help
            • H hyperflemme
              @hyperflemme said in Problem with sensors on arduino and domoticz:
              The arduino that is connected to computer with USB should have #define MY_GATEWAY_SERIAL yes, so it will behave as a gateway and send the data to the computer. You need to configure it in your controller (home automation software) also.
              If you have 1 gateway (arduino + radio) connected to computer + 1 sensor (arduino + radio) separated then the sensor should not have this #define.
              • Nca78N Nca78
                H
                H
                hyperflemme
                @nca78 all my sensor are connected on the arduino card with nRF24L01, and the arduino card is connected by usb on my computer. I want tu connect the arduino card at an raspberry pi 3 but she don't recognise arduino card and sensor, however i have put the gateway and sketch of sensor into the arduino card....
                • H hyperflemme
                  @hyperflemme what controller software are you using on the raspberry pi ?
                  • Nca78N Nca78
                    H
                    H
                    hyperflemme
                    @nca78 Linux on raspberry pi 3 with domoticz
                    • H hyperflemme
                      @hyperflemme did rebuild the gateway script with #define MY_GATEWAY_SERIAL ?
                      Then did you add the gateway in the hardware tab of domoticz ?
                      • Nca78N Nca78
                        H
                        H
                        hyperflemme
                        @nca78 domoticz recognize the arduino card, his version of gateway, but into hardware tab if i change the card i have an children "Unknown" with id 3 and an other child unusable with a ID 255.
                        in the log of domoticz i have "Gateway ready"
                        • H hyperflemme
                          @hyperflemme so it's good news domoticz can see your gateway.
                          Can you post the script you are using now ?
                          • Nca78N Nca78
                            H
                            H
                            hyperflemme
                            @nca78 the script of the gateway or the script of one of the sensors?
                            I give you both juste here:
                            for the gateway i just use this: https://www.mysensors.org/build/serial_gateway and i just added this before inclide mysensors.h:
                            #define MY_RF24_CE_PIN 49
                            #define MY_RF24_CS_PIN 53
                            the script of the sensors is:
                             * Copyright (C) 2013-2018 Sensnology AB
                             * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                             * Version 1.0 - Henrik Ekblad
                            // Enable debug prints
                            // #define MY_DEBUG
                            #define MY_RADIO_RF24
                            //#define MY_RADIO_NRF5_ESB
                            //#define MY_RADIO_RFM95
                            uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                            // Initialize motion message
                            	present(CHILD_ID, S_MOTION);
                            	// Read digital motion value
                            	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                            	Serial.println(tripped);
                            for motion sensor i use a PIR Sensor V1.0
                            • K
                              K
                              kimot
                              wrote on last edited by kimot
                              #24
                              I think we still do not know the topology of your network and we use different terms.
                              For most of us a "sensor" is - temperature sensor, humidity sensor, pressure sensor, etc. These sensors are connected to Arduino, which we call the "node".
                              These node are connected through radio or RS485 to Arduino which works like gateway and send received messages from nodes to controller ( Rpi with Domoticz ).
                              Usually gateway have got no sensors and you can use pure gateway sketch from examples.
                              But you can connect sensors directly to gateway, but you must modify gateway sketch then.
                              • setup your sensors
                              • present your sensors
                              • send values form your sensors.
                              And of course NO SLEEP FUNCTION in sensor send code.
                              Places, where put it is marked by comments in gateway sketch:
                              Usual topology:
                              I think your topology:
                              • K kimot
                                Usual topology:
                                H
                                H
                                hyperflemme
                                @kimot Hi , tank's for your help,
                                my topology: 0_1551269057197_UNADJUSTEDNONRAW_thumb_1.jpg
                                how can i do?
                                K 1 Reply Last reply
                                • H hyperflemme
                                  how can i do?
                                  K
                                  K
                                  kimot
                                  @hyperflemme
                                  Use gateway sketch and add sensor presentation and sensor data sending like in node sketch.
                                  example from this forum:
                                    sendSketchInfo("AWI_ESP 120", "1.0");
                                    present(CHILD_ID, S_DIMMER, "AWI_ESP 120" " dimmer");
                                    present(CHILD_ID2, S_INFO, "AWI_ESP 120" " text");
                                   	send(msg.set(messageCounter)); 										// Send message to gw
                                  	messageCounter = ++messageCounter % 100 ;							// wrap
                                  	send(msg2.set("Hallo")); 											// Send message to gw
                                  	// Send update every SLEEP_TIME
                                  	wait(SLEEP_TIME) ;
                                  void receive(const MyMessage &message) {  								// messages from node or controller
                                  	//char printBuf[40] ;
                                  	//Serial.print(message.getInt());
                                  		//sprintf(printBuf, "Message node: %d %d  OK\n", message.sender, message.getInt());
                                  	//Serial.print(printBuf) ;
                                  	//sprintf(printBuf, "Messages: %d Errors: %d\n", messageCounter, messageErrorCounter);
                                  Search forum here, you are not alone with this solution.
                                  • K kimot
                                    @hyperflemme
                                    	wait(SLEEP_TIME) ;
                                    H
                                    H
                                    hyperflemme
                                    @kimot THANKS !!!
                                    for 1 sensor it's ok, but if i had a 2nd sensor he doesn't work...
                                    12.5k
