  3. How to protect rain sensor from oxidation?
14 Posts 7 Posters 4.6k Views 7 Watching
    martim
    I have a rain sensor like this:
    How can I protect this as I am currently every 6-8 weeks need to replace it :(
    Thanks for suggestions!
    Marcel
    T 1 Reply Last reply
    • FotoFieberF
      FotoFieberF
      FotoFieber
      Hi Marcel
      Is it oxidation or electrolysis? Some of the sensor use DC to detect rain which can cause electrolysis.
      Markus
      M 1 Reply Last reply
      • M martim
        Marcel
        Technovation
        @martim
        Instead of measuring resistive with contact to water, consider measuring contactless to water by for instance using a inductive or capacitive measuring method. The closest that aproaches your current sensor is a capacitive soil sensor (example: [https://www.dfrobot.com/wiki/index.php/Capacitive_Soil_Moisture_Sensor_SKU:SEN0193]) which I guess should also work to measure rain.
        Of course you should seal the top part of the pcb with the electric components from rain.
        But with some imagination and ingenuity you should be able to come up with different solutions.
        • FotoFieberF FotoFieber
          Hi Marcel
          Markus
          martim
          @fotofieber I have no idear.
          FotoFieberF 1 Reply Last reply
          • T Technovation
            @martim
            martim
            @technovation I tried this but it didn't work very reliable.
              martim
              Is there not some kind of spray to protect the board?
              • M martim
                @martim the board works because water on the board carries electrical current between the tracks.
                If you spray the board, water will no longer come in contact with the traces. This means no corrosion. But it also mean no current is carried, so the sensor will never detect any water.
                • M martim
                  FotoFieberF
                  FotoFieberF
                  FotoFieber
                  @martim said in How to protect rain sensor from oxidation?:
                  Put two sensors outside but only wire one. If only the wired one looks bad after some weeks, it is likely a problem with electrolysis. If both look bad, it is more likely a problem with oxidation. You coud then try to solder the conductor path on the sensor. Or gold-plate :)
                  If it is a problem with electrolysis, you could try another wiring and sketch (flip input and ground pin with every measurement)
                  • K
                    K
                    kimot
                    Piezo detector exists for detecting the impact of the drop.
                    • bjacobseB
                      bjacobseB
                      bjacobse
                      wrote on last edited by bjacobse
                      My car uses IR for automatic wipe the windshield, light are reflected if it hit a rounded surface, if there are water drops, then less light are reflected and wiper start to clean windshield
                      https://en.wikipedia.org/wiki/File:Rain_sensor_en.svg
                      M 2 Replies Last reply
                      • bjacobseB bjacobse
                        martim
                        @bjacobse I have been looking to something like this but did not find it. I would be indeed a lot better.
                          martim
                          @bjacobse This one seems to work like this. A bit expensive.. http://rainsensors.com/how-it-works/
                          • K
                            K
                            kimot
                            https://www.letscontrolit.com/forum/viewtopic.php?f=2&t=6540
                            • dzjrD
                              dzjrD
                              dzjr
                              For my soil moisture sensors I use a transistor with which I switch the voltage on the sensor on and off with an interval of 15 minutes.
                              For a rain sensor I am lucky to have an old rain sensor from a greenhouse climate system,
                              This sensor works in much the same way, only there are power resistors at the rear, which act as a kind of heating, these switch on when moisture or rain is measured on the sensor, and off again when they are dry.
