  3. [SOLVED] Nodes not receviving ACK from Pi3 gateway
4 Posts 2 Posters 1.0k Views 2 Watching
  • O
    O
    olision
    Hi everyone,
    I have been running a sensor node with a nrf52832 talking to an Arduino Uno and a NRF24L01+ for the mqtt Gateway without trouble. Recently I wanted to run the Gateway on my Raspberry Pi that is already running Openhab with the Embedded MQTT Broker. I followed the installations and setup guidelines, installing the latest development rep. The test does make a connection to the NRF24L01+ chip as the logs here:
    Mar 03 23:48:09 INFO  Starting gateway...
    Mar 03 23:48:09 INFO  Protocol version - 2.3.1
    Mar 03 23:48:09 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,REL=255,VER=2.3.1
    Mar 03 23:48:09 DEBUG TSF:LRT:OK
    Mar 03 23:48:09 DEBUG TSM:INIT
    Mar 03 23:48:09 DEBUG TSF:WUR:MS=0
    Mar 03 23:48:09 DEBUG TSM:INIT:TSP OK
    Mar 03 23:48:09 DEBUG TSM:INIT:GW MODE
    Mar 03 23:48:09 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Mar 03 23:48:09 DEBUG MCO:REG:NOT NEEDED
    Mar 03 23:48:09 DEBUG MCO:BGN:STP
    Mar 03 23:48:09 DEBUG MCO:BGN:INIT OK,TSP=1
    Mar 03 23:48:09 DEBUG GWT:RMQ:MQTT RECONNECT
    Mar 03 23:48:09 DEBUG connected to 127.0.0.1
    Mar 03 23:48:09 DEBUG GWT:RMQ:MQTT CONNECTED
    Mar 03 23:48:09 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    Mar 03 23:48:09 DEBUG TSM:READY:NWD REQ
    Mar 03 23:48:11 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0        ,st=OK:
    But on the other side, on the debug from my node I have:
     __  __       ____
            |___/                      2.3.1
    284 MCO:BGN:INIT NODE,CP=RNNNN---,REL=255,VER=2.3.1
    338 TSM:INIT
    352 TSF:WUR:MS=0
    369 TSM:INIT:TSP OK
    390 TSM:INIT:STATID=5
    413 TSF:SID:OK,ID=5
    434 TSM:FPAR
    454 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2527 !TSM:FPAR:NO REPLY
    2551 TSM:FPAR
    2572 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4646 !TSM:FPAR:NO REPLY
    4670 TSM:FPAR
    4691 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6765 !TSM:FPAR:NO REPLY
    6789 TSM:FPAR
    6810 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8884 !TSM:FPAR:FAIL
    8904 TSM:FAIL:CNT=1
    8925 TSM:FAIL:DIS
    8944 TSF:TDI:TPD
    I used the configuration line :
    ./configure --my-transport=rf24 --my-rf24-pa-level=RF24_PA_MAX --my-rf24-ce-pin=26 --my-rf24-cs-pin=24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1  --my-port=1883  --my-mqtt-publish-topic-prefix=mygateway1-out --my-mqtt-subscribe-topic-prefix=mygateway1-in --my-mqtt-client-id=Gateway
    Which is most alike than what I had on my Arduino Uno Gateway.
    Did I miss anything to make it works?
    Thanks for your help on that matter!
    • O olision
      Hi everyone,
       __  __       ____
              |___/                      2.3.1
      338 TSM:INIT
      352 TSF:WUR:MS=0
      369 TSM:INIT:TSP OK
      413 TSF:SID:OK,ID=5
      434 TSM:FPAR
      2551 TSM:FPAR
      4670 TSM:FPAR
      6789 TSM:FPAR
      8884 !TSM:FPAR:FAIL
      8904 TSM:FAIL:CNT=1
      8925 TSM:FAIL:DIS
      8944 TSF:TDI:TPD
      @olision actually, the nodes do receive ack, as indicated by st=OK.
      Does the gateway log cover the time when the node sent its messages? In that case, maybe there is another gateway (or a repeater node) that send the acks?
      What capacitor(s) are you using for the power on the gateway radio? How is the gateway radio powered?
      • O
        O
        olision
        Thanks for your fast reply,
        In my case, there is only one Gateway running on the Pi3 and only one NRF52832 node. I have a 10uf capacitor soldered on the NRF24L01+ and it is powered using the 3.3V form the Raspberry Pi. To make sure it wasn't a faulty radio, it is the same I used on my working Arduino gateway.
        I saw in the configure help that there is a --my-rf24-channel=<0-125> option set to 76 by default. Could it be the cause of this communication error?
        I'm all ears if you have any recommendation to my setup to make it works!
        • O
          O
          olision
          Finally got some time to work on it. I started back from scratch, installing the openhabian image and configuring it all over. I problably made a mistake somewhere because now it does works well!
