  3. Why watchdog not working with MySensors?
6 Posts 2 Posters 1.4k Views 2 Watching
  • D
    D
    Dmytro Zadvornov
    I faced with the same issue like https://forum.mysensors.org/topic/9946/watchdog-not-watchdogging/1
    MySensor ver 2.3.1
    Optiboot ver 8.0
    atmega328, 8MHz
    I have tested two codes on the one board and the result is bellow.
    This test code works well. Watchdog is working and Atmega is rebooting.
    #include <Arduino.h>
    #include <avr/wdt.h>
    #define STATUS_LED_PIN        A2
      wdt_disable();
      Serial.begin(9600);
      Serial.println("Setup..");
      pinMode(STATUS_LED_PIN, OUTPUT);
      digitalWrite(STATUS_LED_PIN, 0);
      Serial.println("Wait 5 sec..");
      delay(5000);
      wdt_enable (WDTO_8S);
      Serial.println("Watchdog enabled.");
    int timer = 0;
    void loop(){
      if(!(millis()%1000)){
        timer++;
        Serial.println(timer);
        digitalWrite(STATUS_LED_PIN, digitalRead(STATUS_LED_PIN)==1?0:1); delay(1);
      //wdt_reset();
    But this code is not working. Watchdog is not working.
    // RFM95
      #define MY_RADIO_RFM95
      //#define MY_DEBUG_VERBOSE_RFM95
      #define MY_RFM95_FREQUENCY (RFM95_868MHZ)
      #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128
      #define MY_NODE_ID 10
      #define MY_PARENT_NODE_ID 0
      wdt_disable();
      Serial.begin(9600);
      delay(5000);
    int timer = 0;
    void loop(){
        timer++;
      //wdt_reset();
    What I am doing wrong?
    • D Dmytro Zadvornov
      MySensor ver 2.3.1
      Optiboot ver 8.0
      atmega328, 8MHz
        wdt_disable();
        Serial.begin(9600);
        delay(5000);
      int timer = 0;
      void loop(){
          timer++;
        //wdt_reset();
      // RFM95
        wdt_disable();
        Serial.begin(9600);
        delay(5000);
      int timer = 0;
      void loop(){
          timer++;
        //wdt_reset();
      @dmytro-zadvornov MySensors will automatically reset the watchdog every time loop is exited.
      • D
        D
        Dmytro Zadvornov
        wrote on last edited by Dmytro Zadvornov
        @mfalkvidd Thx for you answer.
        If I understand you right MySensor has implicit call wdt_reset()?
        And in this case this new code will reboot.
        // RFM95
          wdt_disable();
          Serial.begin(9600);
          delay(5000);
        int timer = 0;
        void loop(){
            timer++;
          delay(20000);
          //wdt_reset();
        I will try it later
          // RFM95
            wdt_disable();
            Serial.begin(9600);
            delay(5000);
          int timer = 0;
          void loop(){
              timer++;
            delay(20000);
            //wdt_reset();
          I will try it later
          @dmytro-zadvornov delay will also reset the watchdog
          • D
            D
            Dmytro Zadvornov
            I have tried last code, and it works - the watchdog reboot MC. As expected.
            @mfalkvidd Why you think delay() should reset the watchdog?
              @dmytro-zadvornov thanks for reporting back.
              Sorry for my mistake. I thought most platforms called yield() inside delay(), and yield() usually resets the watchdog. Example https://github.com/arduino/ArduinoCore-avr/blob/b7c607663fecc232e598f2c0acf419ceb0b7078c/cores/arduino/wiring.c#L106
              But since your test shows that the watchdog is tripped, the watchdog is not reset inside delay().
              https://github.com/arduino/ArduinoCore-avr/blob/b7c607663fecc232e598f2c0acf419ceb0b7078c/cores/arduino/Arduino.h#L38 shows that avr does not reset watchdog in yield().
