  3. Sending custom value to move DC motor a specific # of degrees
7 Posts 2 Posters 1.4k Views 1 Watching
  • N
    N
    nizoo91
    wrote on last edited by nizoo91
    Hello everyone,
    On to a new project, I have a DC motor with an encoder that I would like to control from OpenHAB, would appreciate some help in directing me to the right place, as I have not been able to find any solutions on my own yet :/
    Basically I need to send a custom degree value from OpenHAB to the Node, and the motor should move that many degrees, store the value and display "current" position in degrees would be ideal. (the value I sent last)
    I was able to move the motor using the code below, if placed within void receive(const MyMessage &message) however it would not stop the motor at the right degree... so clearly I was doing something wrong :/
    Right now the bellow code will move the motor to "target" which is set at 360 on the sketch
    //#define MY_REPEATER_FEATURE
    #define CHILD_ID 6
    MyMessage message(CHILD_ID, S_CUSTOM);
    #define total 7560                     //x4 pulses per rotation.
    #define target 360
    #define motorSpeed 125                 //Change speed of the motor. 125 to 135 is optimal speed for perfect stops
    long degree;
    long pulses;                              //Output pulses.
    int encoderA = 3;
    int encoderB = 2;
    const int pwm = 5;                      //Power of motor.
    const int dir = 6;
    const int dir2 = 7;                      //Direction of the motor.
    int pulsesChanged = 5;
    #define degree pulses/21                   // total / 360 = total ticks per degree of shaft rotation
      Serial.begin(115200);
      pinMode(pwm, OUTPUT);
      pinMode(dir, OUTPUT);
      pinMode(dir2, OUTPUT);
      analogWrite(pwm, 0);                     //Make sure the motor in reset mode.
      digitalWrite(dir, HIGH);
      digitalWrite(dir2, HIGH);
      pinMode(encoderA, INPUT);
      pinMode(encoderB, INPUT);
      delay(50);
      attachInterrupt(0, A_CHANGE, CHANGE);
      attachInterrupt(1, B_CHANGE, CHANGE);
      sendSketchInfo("Program", "1.0");
      present(CHILD_ID, S_CUSTOM);
        if(degree==target){
        analogWrite(pwm,0);
        digitalWrite(dir,HIGH);
        digitalWrite(dir2,HIGH);
        delay(500);
        //saveState(message.sensor, message.getBool());
        //request(CHILD_ID, V_VAR1);
        return;
      else{
        if (degree>target){
          analogWrite(pwm,motorSpeed);
          digitalWrite(dir,LOW);
        else if(degree<target){
          digitalWrite(dir2,LOW);
      if (pulsesChanged != 0) {
        pulsesChanged = 0;
        Serial.println(degree);
    void A_CHANGE(){
      if( digitalRead(encoderB) == 0 ) {
        if ( digitalRead(encoderA) == 0 ) {
          // A fell, B is low
          pulses--; // moving reverse
        } else {
          // A rose, B is low
          pulses++; // moving forward
      }else {
          // B fell, A is high
          pulses++; // moving reverse
        } else {
          // B rose, A is high
          pulses--; // moving forward
      pulsesChanged = 1;
    void B_CHANGE(){
        if ( digitalRead(encoderB) == 0 ) {
          // B fell, A is low
        } else {
          // B rose, A is low
     } else {
        } else {
      pulsesChanged = 1;
    • N
      N
      nizoo91
      Any idea on how I can do this guys? :)
      I basically need whatever value I receive from V_VAR1 to = target
      I am receiving the values I send from OpenHAB, but at the moment it does nothing because I don't know how to define this :/
      Please correct me if I am wrong but it should look something like this in the void loop() no?
      if V_VAR1 value is updated
      then V_VAR1 value = target
      then run loop..
      Just don't know how to do it in programming language :) any help would be appreciated :)
      • nagelcN
        nagelcN
        nagelc
        wrote on last edited by nagelc
        Right now, you are requesting V_VAR1, but don't have anything in the receive() function to handle the return message. I haven't worked with V_VAR type messages before, but if it is the same as other message types something like this should work. In the receive() function add:
        if (message.type == V_VAR1) {
             target = message.getInt();
        There might be some more examples in the forums if you search S_CUSTOM or V_VAR
        One other thought. I think you need to move your reqest() function into loop(). The request() function tells the controller to send the variable. When the controller responds, the receive() function is called to handle the incoming message.
        • N
          N
          nizoo91
          Yah tried to find examples on the forums with no luck unfortunately :/
          I am able to receive & send the last value from/to OpenHAB, however I am unable to convert the payload to = target... that is the only missing piece I think..
          this is from my debug log
          183728 TSF:MSG:READ,0-0-1,s=6,c=1,t=24,pt=0,l=2,sg=0:55
          183735 TSF:MSG:SEND,1-1-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
          N 1 Reply Last reply
          • N nizoo91
            N
            N
            nizoo91
            @nizoo91 said in Sending custom value to move DC motor a specific # of degrees:
            However I am unable to convert the payload to = target... that is the only missing piece I think..
            • nagelcN
              nagelcN
              nagelc
              Yes. This looks good. Dropped it in the parser here: https://www.mysensors.org/build/parser
              Looks like V_VAR1 is being sent with value 55.
              I think the code I posted above should get it from the incoming message and assign to target. If not, then I am not sure what is the problem. Perhaps someone that has worked more with V_VAR can respond?
              • nagelcN nagelc
                N
                N
                nizoo91
                @nagelc said in Sending custom value to move DC motor a specific # of degrees:
                Actually I finally got it to work! and yes indeed, it was using your code!!! :)
                I don't know what I was doing before, but I tried your code previously but didn't work, and the only way to read the value was using : target = message.getString(); for some reason..
                But I changed quite a few things in the code, and now when I tried your code again, it actually worked!
                Dude thank you, you are a hero! I will post the final version once I polish up the code in case anyone else needs to do a similar thing!
