  3. Vera
  4. Vera Edge Firmware
Vera Edge Firmware
verafirmware
3 Posts 3 Posters 2.2k Views 3 Watching
  • J
    J
    jfigue
    Hi, I just got a Vera Edge controller that was loaded with OpenWRT (for some project) and now I want to re-load the original Vera firmware for this device. Is this possible? If so, can you guys share the instructions on how to do it and where to download the firmware from?
    Thanks in advance.
    Regards,
    Javier.
    • HomerH
      HomerH
      Homer
      My Vera 3 has the stock firmware and it to seems to have OPENWRT. I found this out because it was sending out a wi-fi signal.
      • dbemowskD
        dbemowskD
        I too have a Vera Plus and the firmware used is OpenWRT. That is the base linux that the Vera controllers are built on. I don't know if theUI for the Vera Edge is the same as the Plus, but on mine if you go to Settings > Firmware in the left menu, it should check if there are any firmware updates available. It's always best to run the latest firmware available.
