  3. [SOLVED] Testing Serial Gateway?
6 Posts 2 Posters 1.2k Views 2 Watching
  • F Offline
    F Offline
    FrankVK
    Being new to Sensors, I have build my first serial gateway (Aruino Pro Mini (328P 3.3V) & NRF24L01) according to the instruction video on this site. The gateway seems to be working according to the debug log; my controller (Domoticz) also 'sees' the gateway.
    0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    0;255;3;0;9;14 TSM:INIT
    0;255;3;0;9;22 TSF:WUR:MS=0
    0;255;3;0;9;34 !TSM:INIT:TSP FAIL
    0;255;3;0;9;43 TSM:FAIL:CNT=1
    0;255;3;0;9;51 TSM:FAIL:DIS
    0;255;3;0;9;59 TSF:TDI:TSL
    0;255;3;0;9;10070 TSM:FAIL:RE-INIT
    0;255;3;0;9;10078 TSM:INIT
    0;255;3;0;9;10090 !TSM:INIT:TSP FAIL
    0;255;3;0;9;10100 TSM:FAIL:CNT=2
    0;255;3;0;9;10110 TSM:FAIL:DIS
    0;255;3;0;9;10119 TSF:TDI:TSL
    However, when I fire up a (DHT22) client, it does not see the Gateway.
    __  __       ____
            |___/                      2.3.1
    51 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
    81 TSM:INIT
    86 TSF:WUR:MS=0
    94 TSM:INIT:TSP OK
    100 TSM:FPAR
    104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2125 !TSM:FPAR:NO REPLY
    2131 TSM:FPAR
    2136 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4157 !TSM:FPAR:NO REPLY
    4163 TSM:FPAR
    4167 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6189 !TSM:FPAR:NO REPLY
    6195 TSM:FPAR
    6199 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8220 !TSM:FPAR:FAIL
    8224 TSM:FAIL:CNT=1
    8230 TSM:FAIL:DIS
    8235 TSF:TDI:TSL
    I use 47uF capacitors, the gateway and client are 1-5m apart. I tried seperate power supply..
    Any suggestions?
    Is there any way I can test if the Gateway is working?
    Regards, Frank
    • F FrankVK
      __  __       ____
              |___/                      2.3.1
      81 TSM:INIT
      86 TSF:WUR:MS=0
      94 TSM:INIT:TSP OK
      100 TSM:FPAR
      2131 TSM:FPAR
      4163 TSM:FPAR
      6195 TSM:FPAR
      8220 !TSM:FPAR:FAIL
      8224 TSM:FAIL:CNT=1
      8230 TSM:FAIL:DIS
      8235 TSF:TDI:TSL
      Any suggestions?
      Regards, Frank
      Hi @frankvk, welcome to the MySensors community!
      !TSM:INIT:TSP FAIL
      this means that the node is unable to communicate with the radio chip. The most common cause is a mistake in wiring. Triple-check your wiring, and post photos here - often a new pair of eyes is helpful to spot mistakes.
      If you haven't already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for a handy flowchart on how to troubleshoot the most common problems.
      • F Offline
        F Offline
        FrankVK
        Thanks for your reply!
        It appears to be a newby mistake: I overpowered the NRF24L01 radios: the FTDI board did put out 5.0V although the output Voltage selectors witch wat at the 3.3V position..
        Another lesson learned today... always doublecheck !
        • F Offline
          F Offline
          FrankVK
          Now that we have communication: if I run the (standard) DhtTemparatureAnd HumiditySensor sketch, the Setup() en Loop() never seem to run.. The Serial.println commands don't make it to the Serial monitor..
          Am I missing something here?
          • F FrankVK
            @frankvk what does the debug output of the node and the gateway say?
            • F Offline
              F Offline
              FrankVK
              Recompiled & uploaded the sektch and now I see the Temperature and Humidity values allright!
              Thanks again!
