  3. CYCLE PUMPE
CYCLE PUMPE
3 Posts 3 Posters 919 Views 3 Watching
  • H Offline
    H Offline
    hohm
    wrote on last edited by Nca78
    void Pumpe(){
        if(percentage < SystemLimens.setSoil_Limen)
        digitalWrite(RelayPin,RelayOn);//on
        if(totalMilliLitres>=SystemLimens.setVolume_Limen)
         digitalWrite(RelayPin,RelayOff);//off
         if(millis()-StartTime>=fivesMinutes)// temps d'absorption de l'eau par les racines
            reset_Counter();
    ello I would like to add a second cycle of watering,
    force On, stop the pump by totalMimimeters and reset counter.
    someone would have an idea please.
    D 1 Reply Last reply
    • H hohm
      void Pumpe(){
              reset_Counter();
      @hohm First, it helps when posting code to put it in a code block. If you can edit your post and highlight your "Pumpe" block of code and click the </> icon. It helps too if your code is indented. That should make your code a bit easier to read. You may also want to post your full sketch so we can see what is going on.
      Welcome to the forum...
      • N Offline
        N Offline
        Hello @hohm I added the code block to your message.
        Is the "Pumpe()" function your attempt for the second cycle, or do you want to add a second cycle to the Pumpe() function ? Because from what I see it's doing what you ask ? If humidity percentage is below limit activate pump, when pumped volume is over specified volume stop the pump, and after "fiveMinutes" are passed, reset the counter.
