  3. Mozilla WebThings Gateway
  4. MySensors: trying to add Things in WebThings Gateway
Scheduled Pinned Locked Moved Mozilla WebThings Gateway
35 Posts 3 Posters 5.8k Views 3 Watching
  • R
    R
    rmalbers
    I need to keep better track of what software is running on a given cpu/sensor, sorry about that but I didn't think of it at the time! I 'think' this is what is running on the office sensor. I should probably build a new sensor using this code and make sure it works the same, (log files match what I've been giving you):
    //#define MY_DEBUG
    #include <MyConfig.h>
    #include <OneWire.h>
    int numSensors = 0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0, V_TEMP);
    void before()
    sensors.begin();
    void presentation() {
    sendSketchInfo("Temperature Sensor", "1.1");
    for (int i = 0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
    	present(i, S_TEMP);
    sleep(conversionTime);
    	float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
    #if COMPARE_TEMP == 1
    #else
    		send(msg.setSensor(i).set(temperature, 1));
    		lastTemperature[i] = temperature;
    sleep(SLEEP_TIME);
    • alowhumA
      alowhumA
      alowhum
      #22
      When you create a new post, click on the 'code' button when you want to insert code.
      Back on topic, I don't think that's the actual code, since the log showed that no sketch name was sent. Receiving the sketch name is what triggers the creation of the thing, so it's kind of important.
      For example, here's a node presentation from my own logs:
      2019-06-20 10:20:03.441 ERROR  : mysensors: DEBUG:mysensors:Receiving 33;255;3;0;11;Fireplace
      2019-06-20 10:20:03.446 ERROR  : mysensors: DEBUG:mysensors:Receiving 33;255;3;0;12;1.2
      ...Yet I don't see "Temperature Sensor" anywhere in your logs.
      Also in your errors I can see this strange situation where the add-on keeps requesting node 0 to present itself.
      2019-06-19 15:34:00.801 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
      2019-06-19 15:34:00.875 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
      Node 0 should theoretically be the MySensors gateway. It only responds with it's version, and not a name. Perhaps that's also an issue (although theoretically it shouldn't be, since node 0 is never turned into a thing).
      Come to think of it, I don't see any messages being handled by the add-on other than the initial two messages from the Gateway.
      You should see all kinds of things with >> like:
      2019-06-20 10:30:34.498 INFO   : mysensors: << Requesting presentation from 35
      2019-06-20 10:30:34.500 INFO   : mysensors: >> incoming message > presentation > id: 35; child: 255; subtype: 17; payload: 2.3.1
      2019-06-20 10:30:34.501 INFO   : mysensors: >> incoming message > internal > id: 35; child: 255; subtype: 11; payload: Anemone
      2019-06-20 10:30:34.503 INFO   : mysensors: >> incoming message > internal > id: 35; child: 255; subtype: 12; payload: 1.0
      2019-06-20 10:30:34.505 INFO   : mysensors: >> incoming message > set > id: 35; child: 1; subtype: 2; payload: 1
      • R
        R
        rmalbers
        wrote on last edited by rmalbers
        #23
        Ok, I'll look at this and probably just start rebuilding my sensor's and gateway making sure I get those names in there. When I built this over a year ago I was playing with different boards and different sensors and once I got things working in Domoticz I moved on. That's why I have so much program source code out there. This time I'll put a unique, my version number in there so I can keep better track. I think I'll even physically label the sensors this time! Thanks for all your time on this, I really like the looks of the WebThings GW and it's really a good fit for the stuff I'm doing/trying to do. Oh, thanks for that about the code button, didn't know about that.
        • alowhumA
          alowhumA
          alowhum
          @rmalbers Wait one second. I've been playing with the code and I have a suspicion about what's going on. I'm uploading a new version of the add-on, try that first.
          R 1 Reply Last reply
          • alowhumA alowhum
            R
            R
            rmalbers
            @alowhum Wow, ok, that's sounds great. I'll watch here for word.
            • alowhumA
              alowhumA
              alowhum
              Version 0.1.0 has been accepted. Try it and let me know how it goes?
              • R
                R
                rmalbers
                Ok ,updated addon and rebooted GW. This test was in Ethernet mode. No luck but the log sure looks different:
                2019-06-21 14:32:15.079 INFO : Opened a new things socket
                2019-06-21 14:32:15.185 INFO : About to call startPairing on MySensorsAdapter
                2019-06-21 14:32:15.197 INFO : mysensors: -Connection status is present in the config data.
                2019-06-21 14:32:15.199 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
                2019-06-21 14:32:15.200 INFO : mysensors:
                2019-06-21 14:32:15.202 INFO : mysensors: #0
                2019-06-21 14:32:15.203 INFO : mysensors: -Gateway choice: Ethernet gateway
                2019-06-21 14:32:15.205 INFO : mysensors: Selected IP address and port: 192.168.1.98
                2019-06-21 14:32:15.206 INFO : mysensors:
                2019-06-21 14:32:15.208 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
                2019-06-21 14:32:15.209 INFO : mysensors: Re-requesting presentation of all nodes on the network
                2019-06-21 14:32:15.211 INFO : mysensors: Re-request thread created
                2019-06-21 14:32:15.218 INFO : mysensors:
                2019-06-21 14:32:15.220 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
                2019-06-21 14:32:15.221 INFO : mysensors:
                2019-06-21 14:32:15.222 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
                2019-06-21 14:32:15.224 INFO : mysensors:
                2019-06-21 14:32:15.225 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
                2019-06-21 14:32:15.227 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
                2019-06-21 14:32:15.465 ERROR : mysensors: Node 2 is unknown
                2019-06-21 14:32:36.851 ERROR : mysensors: Node 1 is unknown
                2019-06-21 14:32:50.254 ERROR : mysensors: Node 2 is unknown
                2019-06-21 14:33:09.496 ERROR : mysensors: Node 1 is unknown
                2019-06-21 14:33:15.190 INFO : Pairing timeout
                2019-06-21 14:33:15.196 ERROR : Thing was not added
                2019-06-21 14:33:15.198 ERROR : addNewThing cancelled
                2019-06-21 14:33:15.201 INFO : mysensors: PAIRING INITIATED
                2019-06-21 14:33:15.204 INFO : mysensors: Thread already existed
                2019-06-21 14:33:15.205 INFO : mysensors: Re-requesting presentation of all nodes on the network
                2019-06-21 14:33:15.207 INFO : mysensors: Re-request of node presentation restarted
                2019-06-21 14:33:15.208 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
                2019-06-21 14:33:25.022 ERROR : mysensors: Node 2 is unknown
                • R rmalbers
                  R
                  R
                  rmalbers
                  @rmalbers Just to add, this a log using USB GW, it seems to looks slightly different:
                  2019-06-21 14:46:04.725 INFO : Unloading MySensorsAdapter
                  2019-06-21 14:46:04.729 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadAdapter","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
                  2019-06-21 14:46:04.734 INFO : mysensors: Shutting down MySensors adapter
                  2019-06-21 14:46:04.736 INFO : mysensors: MySensors adapter was unable to cleanly close PyMySensors loop. This is not a problem.
                  2019-06-21 14:46:04.737 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadPlugin","data":{"pluginId":"mysensors-adapter"}}'
                  2019-06-21 14:46:05.497 INFO : mysensors: MySensors add-on has succesfully loaded the configuration.
                  2019-06-21 14:46:08.255 INFO : Loading add-on: mysensors-adapter
                  2019-06-21 14:46:10.552 INFO : mysensors: initialising adapter from class
                  2019-06-21 14:46:10.555 INFO : mysensors: IpcClient: Connected to server, registering...
                  2019-06-21 14:46:10.559 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
                  2019-06-21 14:46:10.561 INFO : mysensors: IpcClient: Registered with PluginServer
                  2019-06-21 14:46:10.564 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
                  2019-06-21 14:46:17.198 INFO : About to call startPairing on MySensorsAdapter
                  2019-06-21 14:46:17.205 INFO : mysensors: -Connection status is present in the config data.
                  2019-06-21 14:46:17.207 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
                  2019-06-21 14:46:17.209 INFO : mysensors:
                  2019-06-21 14:46:17.210 INFO : mysensors: #0
                  2019-06-21 14:46:17.212 INFO : mysensors: -Gateway choice: USB Serial gateway
                  2019-06-21 14:46:17.214 INFO : mysensors: Selected USB device address: /dev/ttyUSB0
                  2019-06-21 14:46:17.215 INFO : mysensors:
                  2019-06-21 14:46:17.217 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
                  2019-06-21 14:46:17.218 INFO : mysensors: Re-requesting presentation of all nodes on the network
                  2019-06-21 14:46:17.220 INFO : mysensors: Re-request thread created
                  2019-06-21 14:46:17.221 INFO : mysensors:
                  2019-06-21 14:46:17.223 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.3.0
                  2019-06-21 14:46:17.225 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
                  2019-06-21 14:46:17.245 INFO : Opened a new things socket
                  2019-06-21 14:46:44.848 ERROR : mysensors: Node 2 is unknown
                  2019-06-21 14:47:17.202 INFO : Pairing timeout
                  2019-06-21 14:47:17.206 ERROR : Thing was not added
                  2019-06-21 14:47:17.208 ERROR : addNewThing cancelled
                  2019-06-21 14:47:17.211 INFO : mysensors: PAIRING INITIATED
                  2019-06-21 14:47:17.213 INFO : mysensors: Thread already existed
                  2019-06-21 14:47:17.215 INFO : mysensors: Re-requesting presentation of all nodes on the network
                  2019-06-21 14:47:17.216 INFO : mysensors: Re-request of node presentation restarted
                  2019-06-21 14:47:17.218 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
                  2019-06-21 14:47:18.140 ERROR : mysensors: Node 1 is unknown
                  • alowhumA
                    alowhumA
                    alowhum
                    Very strange.
                    I notice you press the pairing button immediately. You don't have to press the pairing button for it to scan for devices. But it shouldn't affect things either.
                    The only device in your persistence file seems to be your gateway (which it does not turn into a thing, but maybe it should. But that's another matter.)
                    Have you restarted your devices after starting the gateway? Otherwise they won't show up. Also make sure your devices send actual values when they boot or shortly after, otherwise those won't show up as properties.
                    I think it's time to have a look at your Arduino code.
                    • alowhumA alowhum
                      Very strange.
                      R
                      R
                      rmalbers
                      @alowhum Sorry, I forgot about rebooting the sensor - SUCCESS! (Now I just have to find the other sensors to reboot them, LOL! This is with the ethernet gateway:
                      2019-06-21 15:03:33.639 INFO : Opened a new things socket
                      2019-06-21 15:04:08.145 ERROR : mysensors: Node 2 is unknown
                      2019-06-21 15:04:25.229 ERROR : mysensors: Child 0 is unknown
                      2019-06-21 15:04:33.108 INFO : Pairing timeout
                      2019-06-21 15:04:33.111 ERROR : Thing was not added
                      2019-06-21 15:04:33.113 ERROR : addNewThing cancelled
                      2019-06-21 15:04:33.117 INFO : mysensors: PAIRING INITIATED
                      2019-06-21 15:04:33.118 INFO : mysensors: Thread already existed
                      2019-06-21 15:04:33.120 INFO : mysensors: Re-requesting presentation of all nodes on the network
                      2019-06-21 15:04:33.121 INFO : mysensors: << Requesting presentation from 1
                      2019-06-21 15:04:33.123 INFO : mysensors: Re-request of node presentation restarted
                      2019-06-21 15:04:33.124 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
                      2019-06-21 15:04:35.520 INFO : Successfully created new thing MySensors_1
                      2019-06-21 15:04:42.920 ERROR : mysensors: Node 2 is unknown
                      2019-06-21 15:04:57.864 ERROR : mysensors: Child 0 is unknown
                      • R rmalbers
                        R
                        R
                        rmalbers
                        @rmalbers Success with second sensor in garage: (Posting log for informational purposes only)
                        2019-06-21 15:11:18.780 INFO : Opened a new things socket
                        2019-06-21 15:11:22.651 INFO : Successfully created new thing Temperature Sensor
                        2019-06-21 15:11:24.864 ERROR : Thing was not added
                        2019-06-21 15:11:24.865 ERROR : addNewThing cancelled
                        2019-06-21 15:11:24.869 INFO : mysensors: PAIRING INITIATED
                        2019-06-21 15:11:24.871 INFO : mysensors: Thread already existed
                        2019-06-21 15:11:24.872 INFO : mysensors: Re-requesting presentation of all nodes on the network
                        2019-06-21 15:11:24.874 INFO : mysensors: << Requesting presentation from 1
                        2019-06-21 15:11:24.875 INFO : mysensors: Re-request of node presentation restarted
                        2019-06-21 15:11:24.877 INFO : mysensors: << Requesting presentation from 2
                        2019-06-21 15:11:24.878 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
                        2019-06-21 15:11:25.829 INFO : getValue for property 2-0-0 for: Temperature Sensor returning 24.1
                        • R
                          R
                          rmalbers
                          BTW: I know I have to rebuild my sensors, but at least now I have 'things' sort of working and can see better what's going on.
                          • alowhumA
                            alowhumA
                            alowhum
                            Oh my god :-D
                            • alowhumA alowhum
                              Oh my god :-D
                              R
                              R
                              rmalbers
                              #34
                              @alowhum I guess I should sum it up: I have V2.2 and V2.3 sensors running using the Ethernet GW addon config and using the MySensors original, not rebuilt gateway, so the MS gateway is running unchanged, yet does work with the addon and WebThings GW. (I do have to rebuild sensors again for the 'imperial' config setting. domoticz didn't care but it looks like the WebThings GW does use it. (I have mixtures of F degrees, C degrees, etc.)
                              • alowhumA
                                alowhumA
                                alowhum
                                I've updated the first post of the Gateway Addon thread to indicate that devices must be restarted to initially connect them.
