  3. Mozilla WebThings Gateway
  4. MySensors: trying to add Things in WebThings Gateway
Scheduled Pinned Locked Moved Mozilla WebThings Gateway
35 Posts 3 Posters 5.8k Views 3 Watching
  • alowhumA alowhum
    @rmalbers Wait one second. I've been playing with the code and I have a suspicion about what's going on. I'm uploading a new version of the add-on, try that first.
    R
    R
    rmalbers
    @alowhum Wow, ok, that's sounds great. I'll watch here for word.
    • alowhumA
      alowhumA
      alowhum
      Version 0.1.0 has been accepted. Try it and let me know how it goes?
      • R
        R
        rmalbers
        Ok ,updated addon and rebooted GW. This test was in Ethernet mode. No luck but the log sure looks different:
        2019-06-21 14:32:15.079 INFO : Opened a new things socket
        2019-06-21 14:32:15.185 INFO : About to call startPairing on MySensorsAdapter
        2019-06-21 14:32:15.197 INFO : mysensors: -Connection status is present in the config data.
        2019-06-21 14:32:15.199 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
        2019-06-21 14:32:15.200 INFO : mysensors:
        2019-06-21 14:32:15.202 INFO : mysensors: #0
        2019-06-21 14:32:15.203 INFO : mysensors: -Gateway choice: Ethernet gateway
        2019-06-21 14:32:15.205 INFO : mysensors: Selected IP address and port: 192.168.1.98
        2019-06-21 14:32:15.206 INFO : mysensors:
        2019-06-21 14:32:15.208 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
        2019-06-21 14:32:15.209 INFO : mysensors: Re-requesting presentation of all nodes on the network
        2019-06-21 14:32:15.211 INFO : mysensors: Re-request thread created
        2019-06-21 14:32:15.218 INFO : mysensors:
        2019-06-21 14:32:15.220 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
        2019-06-21 14:32:15.221 INFO : mysensors:
        2019-06-21 14:32:15.222 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
        2019-06-21 14:32:15.224 INFO : mysensors:
        2019-06-21 14:32:15.225 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
        2019-06-21 14:32:15.227 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
        2019-06-21 14:32:15.465 ERROR : mysensors: Node 2 is unknown
        2019-06-21 14:32:36.851 ERROR : mysensors: Node 1 is unknown
        2019-06-21 14:32:50.254 ERROR : mysensors: Node 2 is unknown
        2019-06-21 14:33:09.496 ERROR : mysensors: Node 1 is unknown
        2019-06-21 14:33:15.190 INFO : Pairing timeout
        2019-06-21 14:33:15.196 ERROR : Thing was not added
        2019-06-21 14:33:15.198 ERROR : addNewThing cancelled
        2019-06-21 14:33:15.201 INFO : mysensors: PAIRING INITIATED
        2019-06-21 14:33:15.204 INFO : mysensors: Thread already existed
        2019-06-21 14:33:15.205 INFO : mysensors: Re-requesting presentation of all nodes on the network
        2019-06-21 14:33:15.207 INFO : mysensors: Re-request of node presentation restarted
        2019-06-21 14:33:15.208 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
        2019-06-21 14:33:25.022 ERROR : mysensors: Node 2 is unknown
        R 1 Reply Last reply
        • R rmalbers
          R
          R
          rmalbers
          @rmalbers Just to add, this a log using USB GW, it seems to looks slightly different:
          2019-06-21 14:46:04.725 INFO : Unloading MySensorsAdapter
          2019-06-21 14:46:04.729 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadAdapter","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
          2019-06-21 14:46:04.734 INFO : mysensors: Shutting down MySensors adapter
          2019-06-21 14:46:04.736 INFO : mysensors: MySensors adapter was unable to cleanly close PyMySensors loop. This is not a problem.
          2019-06-21 14:46:04.737 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadPlugin","data":{"pluginId":"mysensors-adapter"}}'
          2019-06-21 14:46:05.497 INFO : mysensors: MySensors add-on has succesfully loaded the configuration.
          2019-06-21 14:46:08.255 INFO : Loading add-on: mysensors-adapter
          2019-06-21 14:46:10.552 INFO : mysensors: initialising adapter from class
          2019-06-21 14:46:10.555 INFO : mysensors: IpcClient: Connected to server, registering...
          2019-06-21 14:46:10.559 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
          2019-06-21 14:46:10.561 INFO : mysensors: IpcClient: Registered with PluginServer
          2019-06-21 14:46:10.564 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
          2019-06-21 14:46:17.198 INFO : About to call startPairing on MySensorsAdapter
          2019-06-21 14:46:17.205 INFO : mysensors: -Connection status is present in the config data.
          2019-06-21 14:46:17.207 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
          2019-06-21 14:46:17.209 INFO : mysensors:
          2019-06-21 14:46:17.210 INFO : mysensors: #0
          2019-06-21 14:46:17.212 INFO : mysensors: -Gateway choice: USB Serial gateway
          2019-06-21 14:46:17.214 INFO : mysensors: Selected USB device address: /dev/ttyUSB0
          2019-06-21 14:46:17.215 INFO : mysensors:
          2019-06-21 14:46:17.217 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
          2019-06-21 14:46:17.218 INFO : mysensors: Re-requesting presentation of all nodes on the network
          2019-06-21 14:46:17.220 INFO : mysensors: Re-request thread created
          2019-06-21 14:46:17.221 INFO : mysensors:
          2019-06-21 14:46:17.223 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.3.0
          2019-06-21 14:46:17.225 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
          2019-06-21 14:46:17.245 INFO : Opened a new things socket
          2019-06-21 14:46:44.848 ERROR : mysensors: Node 2 is unknown
          2019-06-21 14:47:17.202 INFO : Pairing timeout
          2019-06-21 14:47:17.206 ERROR : Thing was not added
          2019-06-21 14:47:17.208 ERROR : addNewThing cancelled
          2019-06-21 14:47:17.211 INFO : mysensors: PAIRING INITIATED
          2019-06-21 14:47:17.213 INFO : mysensors: Thread already existed
          2019-06-21 14:47:17.215 INFO : mysensors: Re-requesting presentation of all nodes on the network
          2019-06-21 14:47:17.216 INFO : mysensors: Re-request of node presentation restarted
          2019-06-21 14:47:17.218 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
          2019-06-21 14:47:18.140 ERROR : mysensors: Node 1 is unknown
          • alowhumA
            alowhumA
            alowhum
            Very strange.
            I notice you press the pairing button immediately. You don't have to press the pairing button for it to scan for devices. But it shouldn't affect things either.
            The only device in your persistence file seems to be your gateway (which it does not turn into a thing, but maybe it should. But that's another matter.)
            Have you restarted your devices after starting the gateway? Otherwise they won't show up. Also make sure your devices send actual values when they boot or shortly after, otherwise those won't show up as properties.
            I think it's time to have a look at your Arduino code.
            • alowhumA alowhum
              Very strange.
              R
              R
              rmalbers
              @alowhum Sorry, I forgot about rebooting the sensor - SUCCESS! (Now I just have to find the other sensors to reboot them, LOL! This is with the ethernet gateway:
              2019-06-21 15:03:33.639 INFO : Opened a new things socket
              2019-06-21 15:04:08.145 ERROR : mysensors: Node 2 is unknown
              2019-06-21 15:04:25.229 ERROR : mysensors: Child 0 is unknown
              2019-06-21 15:04:33.108 INFO : Pairing timeout
              2019-06-21 15:04:33.111 ERROR : Thing was not added
              2019-06-21 15:04:33.113 ERROR : addNewThing cancelled
              2019-06-21 15:04:33.117 INFO : mysensors: PAIRING INITIATED
              2019-06-21 15:04:33.118 INFO : mysensors: Thread already existed
              2019-06-21 15:04:33.120 INFO : mysensors: Re-requesting presentation of all nodes on the network
              2019-06-21 15:04:33.121 INFO : mysensors: << Requesting presentation from 1
              2019-06-21 15:04:33.123 INFO : mysensors: Re-request of node presentation restarted
              2019-06-21 15:04:33.124 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
              2019-06-21 15:04:35.520 INFO : Successfully created new thing MySensors_1
              2019-06-21 15:04:42.920 ERROR : mysensors: Node 2 is unknown
              2019-06-21 15:04:57.864 ERROR : mysensors: Child 0 is unknown
              • R rmalbers
                R
                R
                rmalbers
                @rmalbers Success with second sensor in garage: (Posting log for informational purposes only)
                2019-06-21 15:11:18.780 INFO : Opened a new things socket
                2019-06-21 15:11:22.651 INFO : Successfully created new thing Temperature Sensor
                2019-06-21 15:11:24.864 ERROR : Thing was not added
                2019-06-21 15:11:24.865 ERROR : addNewThing cancelled
                2019-06-21 15:11:24.869 INFO : mysensors: PAIRING INITIATED
                2019-06-21 15:11:24.871 INFO : mysensors: Thread already existed
                2019-06-21 15:11:24.872 INFO : mysensors: Re-requesting presentation of all nodes on the network
                2019-06-21 15:11:24.874 INFO : mysensors: << Requesting presentation from 1
                2019-06-21 15:11:24.875 INFO : mysensors: Re-request of node presentation restarted
                2019-06-21 15:11:24.877 INFO : mysensors: << Requesting presentation from 2
                2019-06-21 15:11:24.878 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
                2019-06-21 15:11:25.829 INFO : getValue for property 2-0-0 for: Temperature Sensor returning 24.1
                • R
                  R
                  rmalbers
                  BTW: I know I have to rebuild my sensors, but at least now I have 'things' sort of working and can see better what's going on.
                  • alowhumA
                    alowhumA
                    alowhum
                    Oh my god :-D
                    • alowhumA alowhum
                      Oh my god :-D
                      R
                      R
                      rmalbers
                      wrote on last edited by rmalbers
                      #34
                      @alowhum I guess I should sum it up: I have V2.2 and V2.3 sensors running using the Ethernet GW addon config and using the MySensors original, not rebuilt gateway, so the MS gateway is running unchanged, yet does work with the addon and WebThings GW. (I do have to rebuild sensors again for the 'imperial' config setting. domoticz didn't care but it looks like the WebThings GW does use it. (I have mixtures of F degrees, C degrees, etc.)
                      • alowhumA
                        alowhumA
                        alowhum
                        I've updated the first post of the Gateway Addon thread to indicate that devices must be restarted to initially connect them.
