MySensors: trying to add Things in WebThings Gateway
Ok, when I went into the WT GW the first time the addon was at V0.0.7 but there was an new 'Update' tab that I hit and the new addon version installed. With the USB gateway I get this (I think I started the cut/paste at the right spot):
2019-06-19 15:49:54.172 INFO : Loading add-on: mysensors-adapter
2019-06-19 15:49:56.494 INFO : mysensors: initialising adapter from class
2019-06-19 15:49:56.496 INFO : mysensors: IpcClient: Connected to server, registering...
2019-06-19 15:49:56.500 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
2019-06-19 15:49:56.503 INFO : mysensors: IpcClient: Registered with PluginServer
2019-06-19 15:49:56.505 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
2019-06-19 15:50:13.088 INFO : About to call startPairing on MySensorsAdapter
2019-06-19 15:50:13.096 INFO : mysensors: -Connection status was present in the config data.
2019-06-19 15:50:13.098 INFO : mysensors: -Gateway choice: USB Serial gateway
2019-06-19 15:50:13.099 INFO : mysensors: Error extracting settings from config object: local variable 'ip_address' referenced before assignment
2019-06-19 15:50:13.101 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-19 15:50:18.322 INFO : Opened a new things socket
2019-06-19 15:51:13.092 INFO : Pairing timeout
2019-06-19 15:51:13.095 ERROR : Thing was not added
2019-06-19 15:51:13.113 ERROR : addNewThing cancelled
2019-06-19 15:51:13.118 INFO : mysensors: PAIRING INITIATED
2019-06-19 15:51:13.120 INFO : mysensors: Error re-requesting node ID's from devices in the MySensors network:'MySensorsAdapter' object has no attribute 't'
2019-06-19 15:51:13.121 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}' -
This log is from an attempt (with the new addon) using 'Ethernet' GW and the IP address of the GW that I've been using with Domoticz for the last year or so, (it's at mysensor v2.2) This looks like it was communicating with the gw and thus the sensors but still didn't work. This could be because I am at V2.2 of mysensors(?).:
2019-06-19 15:33:17.874 INFO : Loading add-on: mysensors-adapter
2019-06-19 15:33:20.227 INFO : mysensors: initialising adapter from class
2019-06-19 15:33:20.229 INFO : mysensors: IpcClient: Connected to server, registering...
2019-06-19 15:33:20.233 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
2019-06-19 15:33:20.236 INFO : mysensors: IpcClient: Registered with PluginServer
2019-06-19 15:33:20.238 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
2019-06-19 15:33:20.314 ERROR : mysensors: DEBUG:mysensors.persistence:Loading sensors from persistence file /home/pi/.mozilla-iot/config/mysensors-adapter-persistence.json
2019-06-19 15:33:20.319 ERROR : mysensors: DEBUG:mysensors.persistence:Saving sensors to persistence file /home/pi/.mozilla-iot/config/mysensors-adapter-persistence.json
2019-06-19 15:33:20.330 ERROR : mysensors: INFO:mysensors.gateway_tcp:Trying to connect to ('192.168.1.98', 5003)
2019-06-19 15:33:20.393 ERROR : mysensors: INFO:mysensors:Connected to <_SelectorSocketTransport fd=14 read=idle write=<idle, bufsize=0>>
2019-06-19 15:33:20.425 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;14;Gateway startup complete.
2019-06-19 15:33:20.434 ERROR : mysensors: INFO:mysensors.handler:n:0 c:255 t:3 s:14 p:Gateway startup complete.
2019-06-19 15:33:20.436 ERROR : mysensors: DEBUG:mysensors:Sending 255;255;3;0;20;
2019-06-19 15:33:20.438 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;0;0;18;2.2.0
2019-06-19 15:33:20.442 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;26;0
2019-06-19 15:33:27.927 ERROR : mysensors: DEBUG:mysensors:Receiving 1;0;1;0;0;22.6
2019-06-19 15:33:27.932 ERROR : mysensors: WARNING:mysensors:Node 1 is unknown
2019-06-19 15:33:27.934 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 1
2019-06-19 15:33:27.935 ERROR : mysensors: DEBUG:mysensors:Sending 1;255;3;0;19;
2019-06-19 15:33:29.635 INFO : About to call startPairing on MySensorsAdapter
2019-06-19 15:33:29.642 INFO : mysensors: -Connection status was present in the config data.
2019-06-19 15:33:29.644 INFO : mysensors: -Gateway choice: Ethernet gateway
2019-06-19 15:33:29.646 INFO : mysensors: Selected IP address and port: 192.168.1.98
2019-06-19 15:33:29.648 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
2019-06-19 15:33:29.649 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
2019-06-19 15:33:29.651 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
2019-06-19 15:33:29.652 INFO : mysensors: Re-requesting presentation of all nodes on the network
2019-06-19 15:33:29.654 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-19 15:33:29.656 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;26;0
2019-06-19 15:33:29.695 INFO : Opened a new things socket
2019-06-19 15:33:30.333 ERROR : mysensors: DEBUG:mysensors.persistence:Saving sensors to persistence file /home/pi/.mozilla-iot/config/mysensors-adapter-persistence.json
2019-06-19 15:33:30.495 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
2019-06-19 15:33:30.558 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
2019-06-19 15:33:34.611 ERROR : mysensors: DEBUG:mysensors:Receiving 2;0;1;0;0;23.2
2019-06-19 15:33:34.614 ERROR : mysensors: WARNING:mysensors:Node 2 is unknown
2019-06-19 15:33:34.617 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 2
2019-06-19 15:33:34.618 ERROR : mysensors: DEBUG:mysensors:Sending 2;255;3;0;19;
2019-06-19 15:33:40.597 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
2019-06-19 15:33:40.689 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
2019-06-19 15:33:50.699 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
2019-06-19 15:33:50.820 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
2019-06-19 15:34:00.595 ERROR : mysensors: DEBUG:mysensors:Receiving 1;0;1;0;0;22.6
2019-06-19 15:34:00.599 ERROR : mysensors: WARNING:mysensors:Node 1 is unknown
2019-06-19 15:34:00.601 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 1
2019-06-19 15:34:00.602 ERROR : mysensors: DEBUG:mysensors:Sending 1;255;3;0;19;
2019-06-19 15:34:00.801 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
2019-06-19 15:34:00.875 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
2019-06-19 15:34:09.359 ERROR : mysensors: DEBUG:mysensors:Receiving 2;0;1;0;0;23.2
2019-06-19 15:34:09.362 ERROR : mysensors: WARNING:mysensors:Node 2 is unknown
2019-06-19 15:34:09.365 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 2
2019-06-19 15:34:09.366 ERROR : mysensors: DEBUG:mysensors:Sending 2;255;3;0;19;
2019-06-19 15:34:10.903 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
2019-06-19 15:34:10.980 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
2019-06-19 15:34:21.005 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
2019-06-19 15:34:21.112 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
2019-06-19 15:34:29.646 INFO : Pairing timeout
2019-06-19 15:34:29.651 ERROR : Thing was not added
2019-06-19 15:34:29.653 ERROR : addNewThing cancelled -
FWIW: I was just thinking I should mention, after the 'Update' of the addon the first time I tired it I got the same/similar messages as I had in my OP. I rebooted at that point and those messages went away so I'm thinking that after addon install or update a reboot is probably a good idea.
I noticed something with the Ethernet GW: On the addon configure page under the 'IP address' the text has an IP address example that includes the port. When I include the port I get this data in the log file: 2019-06-19 17:47:34.750 ERROR : mysensors: INFO:mysensors.gateway_tcp:Trying to connect to ('192.168.1.98:5003', 5003)
2019-06-19 17:47:34.758 ERROR : mysensors: ERROR:mysensors.gateway_tcp:Failed to connect to socket at ('192.168.1.98:5003', 5003)and it doesn't seem to connect.
When I leave off the port number I get this in the log file:
2019-06-19 17:49:44.095 ERROR : mysensors: INFO:mysensors.gateway_tcp:Trying to connect to ('192.168.1.98', 5003)
2019-06-19 17:49:44.111 ERROR : mysensors: INFO:mysensors:Connected to <_SelectorSocketTransport fd=14 read=idle write=<idle, bufsize=0>>and it seems to connect. If I'm interpreting this correctly you have to leave the port number off the IP string for it to work properly, not sure which way it really should be, just pointing this out in case it hadn't been noticed.
Thank you for the logs.
Perhaps this is a point where it crashes and reboots the add-on:
2019-06-19 15:33:27.935 ERROR : mysensors: DEBUG:mysensors:Sending 1;255;3;0;19; 2019-06-19 15:33:29.635 INFO : About to call startPairing on MySensorsAdapterI also noticed that it keeps re-requesting the presentation of your nodes:
2019-06-19 15:33:34.617 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 2This could mean:
- You have created a node that somehow has the same node-ID as an earlier but different node. Although in theory the add-on handles this case now.
- Some data is missing that is required to actually create the device. This could be the name.
Can you share the Arduino Code? Could it be that your presentation function does not send names? Your presentation should look something like this:
sendSketchInfo(F("Sensor name"), F("1.1")); present(CHILD_ID, S_BINARY, F("Button name"));Here's another example sketch:
https://forum.mysensors.org/topic/10342/mozilla-webthings-mysensors-add-on-adapter/14// By the way, I don't think using v2.2 should matter. Internally the PyMySensors library actually uses 2.2.
I need to keep better track of what software is running on a given cpu/sensor, sorry about that but I didn't think of it at the time! I 'think' this is what is running on the office sensor. I should probably build a new sensor using this code and make sure it works the same, (log files match what I've been giving you):
//#define MY_DEBUG// Enable and select radio type attached
#include <MyConfig.h>#define MY_RADIO_NRF24
#include <OneWire.h>#define COMPARE_TEMP 1 // Send temperature only if changed? 1 = Yes 0 = No
int numSensors = 0;
bool receivedConfig = false;
bool metric = true;
MyMessage msg(0, V_TEMP);void before()
sensors.begin();
}void setup()
}void presentation() {
sendSketchInfo("Temperature Sensor", "1.1");// Fetch the number of attached temperature sensors numSensors = sensors.getDeviceCount(); // Present all sensors to controller for (int i = 0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { present(i, S_TEMP); }}
sensors.requestTemperatures();// query conversion time and sleep until conversion completed int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution()); // sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater) sleep(conversionTime); // Read temperatures and send them to controller for (int i = 0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { // Fetch and round temperature to one decimal float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.; // Only send data if temperature has changed and no error#if COMPARE_TEMP == 1
#endif// Send in the new temperature send(msg.setSensor(i).set(temperature, 1)); // Save new temperatures for next compare lastTemperature[i] = temperature; } } sleep(SLEEP_TIME); } -
When you create a new post, click on the 'code' button when you want to insert code.
Back on topic, I don't think that's the actual code, since the log showed that no sketch name was sent. Receiving the sketch name is what triggers the creation of the thing, so it's kind of important.
For example, here's a node presentation from my own logs:
2019-06-20 10:20:03.441 ERROR : mysensors: DEBUG:mysensors:Receiving 33;255;3;0;11;Fireplace 2019-06-20 10:20:03.446 ERROR : mysensors: DEBUG:mysensors:Receiving 33;255;3;0;12;1.2...Yet I don't see "Temperature Sensor" anywhere in your logs.
Also in your errors I can see this strange situation where the add-on keeps requesting node 0 to present itself.
2019-06-19 15:34:00.801 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2; 2019-06-19 15:34:00.875 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0Node 0 should theoretically be the MySensors gateway. It only responds with it's version, and not a name. Perhaps that's also an issue (although theoretically it shouldn't be, since node 0 is never turned into a thing).
Come to think of it, I don't see any messages being handled by the add-on other than the initial two messages from the Gateway.
You should see all kinds of things with
>>like:2019-06-20 10:30:34.498 INFO : mysensors: << Requesting presentation from 35 2019-06-20 10:30:34.500 INFO : mysensors: >> incoming message > presentation > id: 35; child: 255; subtype: 17; payload: 2.3.1 2019-06-20 10:30:34.501 INFO : mysensors: >> incoming message > internal > id: 35; child: 255; subtype: 11; payload: Anemone 2019-06-20 10:30:34.503 INFO : mysensors: >> incoming message > internal > id: 35; child: 255; subtype: 12; payload: 1.0 2019-06-20 10:30:34.505 INFO : mysensors: >> incoming message > set > id: 35; child: 1; subtype: 2; payload: 1 -
Ok, I'll look at this and probably just start rebuilding my sensor's and gateway making sure I get those names in there. When I built this over a year ago I was playing with different boards and different sensors and once I got things working in Domoticz I moved on. That's why I have so much program source code out there. This time I'll put a unique, my version number in there so I can keep better track. I think I'll even physically label the sensors this time! Thanks for all your time on this, I really like the looks of the WebThings GW and it's really a good fit for the stuff I'm doing/trying to do. Oh, thanks for that about the code button, didn't know about that.
@rmalbers Wait one second. I've been playing with the code and I have a suspicion about what's going on. I'm uploading a new version of the add-on, try that first.
Version 0.1.0 has been accepted. Try it and let me know how it goes?
Ok ,updated addon and rebooted GW. This test was in Ethernet mode. No luck but the log sure looks different:
2019-06-21 14:32:15.079 INFO : Opened a new things socket
2019-06-21 14:32:15.185 INFO : About to call startPairing on MySensorsAdapter
2019-06-21 14:32:15.197 INFO : mysensors: -Connection status is present in the config data.
2019-06-21 14:32:15.199 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
2019-06-21 14:32:15.200 INFO : mysensors:
2019-06-21 14:32:15.202 INFO : mysensors: #0
2019-06-21 14:32:15.203 INFO : mysensors: -Gateway choice: Ethernet gateway
2019-06-21 14:32:15.205 INFO : mysensors: Selected IP address and port: 192.168.1.98
2019-06-21 14:32:15.206 INFO : mysensors:
2019-06-21 14:32:15.208 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
2019-06-21 14:32:15.209 INFO : mysensors: Re-requesting presentation of all nodes on the network
2019-06-21 14:32:15.211 INFO : mysensors: Re-request thread created
2019-06-21 14:32:15.218 INFO : mysensors:
2019-06-21 14:32:15.220 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
2019-06-21 14:32:15.221 INFO : mysensors:
2019-06-21 14:32:15.222 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
2019-06-21 14:32:15.224 INFO : mysensors:
2019-06-21 14:32:15.225 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
2019-06-21 14:32:15.227 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-21 14:32:15.465 ERROR : mysensors: Node 2 is unknown
2019-06-21 14:32:36.851 ERROR : mysensors: Node 1 is unknown
2019-06-21 14:32:50.254 ERROR : mysensors: Node 2 is unknown
2019-06-21 14:33:09.496 ERROR : mysensors: Node 1 is unknown
2019-06-21 14:33:15.190 INFO : Pairing timeout
2019-06-21 14:33:15.196 ERROR : Thing was not added
2019-06-21 14:33:15.198 ERROR : addNewThing cancelled
2019-06-21 14:33:15.201 INFO : mysensors: PAIRING INITIATED
2019-06-21 14:33:15.204 INFO : mysensors: Thread already existed
2019-06-21 14:33:15.205 INFO : mysensors: Re-requesting presentation of all nodes on the network
2019-06-21 14:33:15.207 INFO : mysensors: Re-request of node presentation restarted
2019-06-21 14:33:15.208 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-21 14:33:25.022 ERROR : mysensors: Node 2 is unknown -
2019-06-21 14:33:25.022 ERROR : mysensors: Node 2 is unknown@rmalbers Just to add, this a log using USB GW, it seems to looks slightly different:
2019-06-21 14:46:04.725 INFO : Unloading MySensorsAdapter
2019-06-21 14:46:04.729 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadAdapter","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-21 14:46:04.734 INFO : mysensors: Shutting down MySensors adapter
2019-06-21 14:46:04.736 INFO : mysensors: MySensors adapter was unable to cleanly close PyMySensors loop. This is not a problem.
2019-06-21 14:46:04.737 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadPlugin","data":{"pluginId":"mysensors-adapter"}}'
2019-06-21 14:46:05.497 INFO : mysensors: MySensors add-on has succesfully loaded the configuration.
2019-06-21 14:46:08.255 INFO : Loading add-on: mysensors-adapter
2019-06-21 14:46:10.552 INFO : mysensors: initialising adapter from class
2019-06-21 14:46:10.555 INFO : mysensors: IpcClient: Connected to server, registering...
2019-06-21 14:46:10.559 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
2019-06-21 14:46:10.561 INFO : mysensors: IpcClient: Registered with PluginServer
2019-06-21 14:46:10.564 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
2019-06-21 14:46:17.198 INFO : About to call startPairing on MySensorsAdapter
2019-06-21 14:46:17.205 INFO : mysensors: -Connection status is present in the config data.
2019-06-21 14:46:17.207 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
2019-06-21 14:46:17.209 INFO : mysensors:
2019-06-21 14:46:17.210 INFO : mysensors: #0
2019-06-21 14:46:17.212 INFO : mysensors: -Gateway choice: USB Serial gateway
2019-06-21 14:46:17.214 INFO : mysensors: Selected USB device address: /dev/ttyUSB0
2019-06-21 14:46:17.215 INFO : mysensors:
2019-06-21 14:46:17.217 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
2019-06-21 14:46:17.218 INFO : mysensors: Re-requesting presentation of all nodes on the network
2019-06-21 14:46:17.220 INFO : mysensors: Re-request thread created
2019-06-21 14:46:17.221 INFO : mysensors:
2019-06-21 14:46:17.223 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.3.0
2019-06-21 14:46:17.225 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-21 14:46:17.245 INFO : Opened a new things socket
2019-06-21 14:46:44.848 ERROR : mysensors: Node 2 is unknown
2019-06-21 14:47:17.202 INFO : Pairing timeout
2019-06-21 14:47:17.206 ERROR : Thing was not added
2019-06-21 14:47:17.208 ERROR : addNewThing cancelled
2019-06-21 14:47:17.211 INFO : mysensors: PAIRING INITIATED
2019-06-21 14:47:17.213 INFO : mysensors: Thread already existed
2019-06-21 14:47:17.215 INFO : mysensors: Re-requesting presentation of all nodes on the network
2019-06-21 14:47:17.216 INFO : mysensors: Re-request of node presentation restarted
2019-06-21 14:47:17.218 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-21 14:47:18.140 ERROR : mysensors: Node 1 is unknown -
Very strange.
I notice you press the pairing button immediately. You don't have to press the pairing button for it to scan for devices. But it shouldn't affect things either.
The only device in your persistence file seems to be your gateway (which it does not turn into a thing, but maybe it should. But that's another matter.)
Have you restarted your devices after starting the gateway? Otherwise they won't show up. Also make sure your devices send actual values when they boot or shortly after, otherwise those won't show up as properties.
I think it's time to have a look at your Arduino code.
Very strange.
@alowhum Sorry, I forgot about rebooting the sensor - SUCCESS! (Now I just have to find the other sensors to reboot them, LOL! This is with the ethernet gateway:
2019-06-21 15:03:33.639 INFO : Opened a new things socket
2019-06-21 15:04:08.145 ERROR : mysensors: Node 2 is unknown
2019-06-21 15:04:25.229 ERROR : mysensors: Child 0 is unknown
2019-06-21 15:04:33.108 INFO : Pairing timeout
2019-06-21 15:04:33.111 ERROR : Thing was not added
2019-06-21 15:04:33.113 ERROR : addNewThing cancelled
2019-06-21 15:04:33.117 INFO : mysensors: PAIRING INITIATED
2019-06-21 15:04:33.118 INFO : mysensors: Thread already existed
2019-06-21 15:04:33.120 INFO : mysensors: Re-requesting presentation of all nodes on the network
2019-06-21 15:04:33.121 INFO : mysensors: << Requesting presentation from 1
2019-06-21 15:04:33.123 INFO : mysensors: Re-request of node presentation restarted
2019-06-21 15:04:33.124 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-21 15:04:35.520 INFO : Successfully created new thing MySensors_1
2019-06-21 15:04:42.920 ERROR : mysensors: Node 2 is unknown
2019-06-21 15:04:57.864 ERROR : mysensors: Child 0 is unknown -
2019-06-21 15:04:57.864 ERROR : mysensors: Child 0 is unknown@rmalbers Success with second sensor in garage: (Posting log for informational purposes only)
2019-06-21 15:11:18.780 INFO : Opened a new things socket
2019-06-21 15:11:22.651 INFO : Successfully created new thing Temperature Sensor
2019-06-21 15:11:24.864 ERROR : Thing was not added
2019-06-21 15:11:24.865 ERROR : addNewThing cancelled
2019-06-21 15:11:24.869 INFO : mysensors: PAIRING INITIATED
2019-06-21 15:11:24.871 INFO : mysensors: Thread already existed
2019-06-21 15:11:24.872 INFO : mysensors: Re-requesting presentation of all nodes on the network
2019-06-21 15:11:24.874 INFO : mysensors: << Requesting presentation from 1
2019-06-21 15:11:24.875 INFO : mysensors: Re-request of node presentation restarted
2019-06-21 15:11:24.877 INFO : mysensors: << Requesting presentation from 2
2019-06-21 15:11:24.878 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
2019-06-21 15:11:25.829 INFO : getValue for property 2-0-0 for: Temperature Sensor returning 24.1 -
Oh my god :-D
@alowhum I guess I should sum it up: I have V2.2 and V2.3 sensors running using the Ethernet GW addon config and using the MySensors original, not rebuilt gateway, so the MS gateway is running unchanged, yet does work with the addon and WebThings GW. (I do have to rebuild sensors again for the 'imperial' config setting. domoticz didn't care but it looks like the WebThings GW does use it. (I have mixtures of F degrees, C degrees, etc.)
I've updated the first post of the Gateway Addon thread to indicate that devices must be restarted to initially connect them.
