  3. Newbie RFM69 MQTT Gateway !TSM:INIT:TSP FAIL
11 Posts 4 Posters 2.0k Views 3 Watching
  • H
    H
    highlifelight
    I want to apologize in advance, because I'm 100% sure I'm making a stupid mistake somewhere, but I've spent so much time trying to figure it out - I just have to ask. I did a fresh install of Raspbian Jessie and installed the development branch of MySensors. I'm using an Adafruit RFM69 breakout and this is the configure code I used:
    ./configure --my-transport=rfm69 --my-rfm69-frequency=915 --my-is-rfm69hw --my-rfm69-irq-pin=22 --my-rfm69-cs-pin=24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    I have wired and rewired the connection between the pi and the radio probably six times. It's set up like this currently (I also wired RST to GND per the documentation re: RFM69HW):
    color | Pi | RFM Breakout
    green | pin 1 | VIN
    blue | pin 6 | GND
    magenta | pin 24 | CS
    gray | pin 23 | SCK
    white | pin 21 | MISO
    black | pin 19 | MOSI
    brown | pin 22 | G0
    And of course, as per the documentation, my radio is not connected correctly, per the debug. Can anybody see what mistake I'm making? I've lost my mind chasing this.
    pi@mysensorsgw:~/MySensors $ sudo ./bin/mysgw
    Jul 10 09:58:20 INFO Starting gateway...
    Jul 10 09:58:20 INFO Protocol version - 2.3.2-beta
    Jul 10 09:58:20 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=5,VER=2.3.2-beta
    Jul 10 09:58:20 DEBUG TSF:LRT:OK
    Jul 10 09:58:20 DEBUG TSM:INIT
    Jul 10 09:58:20 DEBUG TSF:WUR:MS=0
    Jul 10 09:58:21 DEBUG !TSM:INIT:TSP FAIL
    Jul 10 09:58:21 DEBUG TSM:FAIL:CNT=1
    Jul 10 09:58:21 DEBUG TSM:FAIL:DIS
    Jul 10 09:58:21 DEBUG TSF:TDI:TSL
    Jul 10 09:58:31 DEBUG TSM:FAIL:RE-INIT
    Jul 10 09:58:31 DEBUG TSM:INIT
    Jul 10 09:58:31 DEBUG !TSM:INIT:TSP FAIL
    Jul 10 09:58:31 DEBUG TSM:FAIL:CNT=2
    Jul 10 09:58:31 DEBUG TSM:FAIL:DIS
    Jul 10 09:58:31 DEBUG TSF:TDI:TSL
    ^CJul 10 09:58:35 NOTICE Received SIGINT
    1_1562771111943_Copy of 20190710_094917.jpg 0_1562771111942_20190710_095026.jpg
    • H highlifelight
      green | pin 1 | VIN
      blue | pin 6 | GND
      gray | pin 23 | SCK
      brown | pin 22 | G0
      Welcome to the MySensors forum @highlifelight
      I have studied your photos and description and everything looks ok to me.
      There is only one thing that isn't included in your description: Is RST connected to GND? I think the white cable with round connectors in your RFM69 photo takes care of that, but want to be sure.
      Maybe try adding MY_DEBUG_VERBOSE_RFM69 and MY_DEBUG_VERBOSE_RFM69_REGISTERS to get more information on what part of the initialization fails? You can add them by re-running your entire ./configure command, with this added: --extra-cxxflags="-DMY_DEBUG_VERBOSE_RFM69 -DMY_DEBUG_VERBOSE_RFM69_REGISTERS"
      Documentation references:
      https://www.mysensors.org/apidocs/group__RFM69SettingGrpPub.html#ga025051efe601a28037eab3f2b35b7504
      https://www.mysensors.org/build/raspberry#advanced
      • H
        H
        highlifelight
        wrote on last edited by highlifelight
        Thank you so much for looking at my setup. You are correct, the rounded white jumper is from RST to GND per the instructions for RFM69. I have pasted the output from the additional configuration parameters you gave - I don't see any additional debug messages. I attached the tail syslog at the end of the post and it looks identical (but my eyes might be failing, honestly).
        One note I wanted to add - I have two of these Adafruit radios and have swapped them to make sure that I just didn't have a bad unit. Neither works. And another thing - I used a separate power source that I know provides clean 3.3 (entirely separate from the Pi, power directly to the radio), and the results didn't change.
        Again, thank you so much for your time!
        pi@mysensorsgw:~/MySensors $ ./configure --my-transport=rfm69 --my-rfm69-frequency=915 --my-is-rfm69hw --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --extra-cxxflags="-DMY_DEBUG_VERBOSE_RFM69 -DMY_DEBUG_VERBOSE_RFM69_REGISTERS"
        [SECTION] Detecting target machine.
          [OK] machine detected: SoC=BCM2837, Type=rpi3, CPU=armv7l.
        [SECTION] Detecting SPI driver.
          [OK] SPI driver detected:BCM.
        [SECTION] Gateway configuration.
          [OK] Type: mqtt.
          [OK] Transport: rfm69.
          [OK] Signing: Disabled.
          [OK] Encryption: Disabled.
          [OK] CPPFLAGS: -DMY_RADIO_RFM69 -DMY_RFM69_NEW_DRIVER -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_DEFAULT_TX_LED_PIN=18 -DMY_DEFAULT_RX_LED_PIN=16 -DMY_DEFAULT_ERR_LED_PIN=12 -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -DMY_IS_RFM69HW -DMY_RFM69_FREQUENCY=RFM69_915MHZ
        [SECTION] Detecting init system.
          [OK] Init system detected: systemd.
        [SECTION] Saving configuration.
          [OK] Saved.
        [SECTION] Cleaning previous builds.
          [OK] Finished.
        pi@mysensorsgw:~/MySensors $ make
        <removed all the compilation messages - if they would be helpful I can re-add them>
        Jul 12 08:14:57 INFO  Starting gateway...
        Jul 12 08:14:57 INFO  Protocol version - 2.3.2-beta
        Jul 12 08:14:57 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=5,VER=2.3.2-beta
        Jul 12 08:14:57 DEBUG TSF:LRT:OK
        Jul 12 08:14:57 DEBUG TSM:INIT
        Jul 12 08:14:57 DEBUG TSF:WUR:MS=0
        Jul 12 08:14:57 DEBUG !TSM:INIT:TSP FAIL
        Jul 12 08:14:57 DEBUG TSM:FAIL:CNT=1
        Jul 12 08:14:57 DEBUG TSM:FAIL:DIS
        Jul 12 08:14:57 DEBUG TSF:TDI:TSL
        Jul 12 08:15:07 DEBUG TSM:FAIL:RE-INIT
        Jul 12 08:15:07 DEBUG TSM:INIT
        Jul 12 08:15:07 DEBUG !TSM:INIT:TSP FAIL
        Jul 12 08:15:07 DEBUG TSM:FAIL:CNT=2
        Jul 12 08:15:07 DEBUG TSM:FAIL:DIS
        Jul 12 08:15:07 DEBUG TSF:TDI:TSL
        Jul 12 08:15:17 DEBUG TSM:FAIL:RE-INIT
        Jul 12 08:15:17 DEBUG TSM:INIT
        Jul 12 08:15:17 DEBUG !TSM:INIT:TSP FAIL
        Jul 12 08:15:17 DEBUG TSM:FAIL:CNT=3
        Jul 12 08:15:17 DEBUG TSM:FAIL:DIS
        Jul 12 08:15:17 DEBUG TSF:TDI:TSL
        ^CJul 12 08:15:19 NOTICE Received SIGINT
        Just in case
        Jul 12 08:29:51 mysensorsgw systemd[1]: Started Session c3 of user pi.
        Jul 12 08:30:15 mysensorsgw mysgw: Starting gateway...
        Jul 12 08:30:15 mysensorsgw mysgw: Protocol version - 2.3.2-beta
        Jul 12 08:30:15 mysensorsgw mysgw: MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=5,VER=2.3.2-beta
        Jul 12 08:30:15 mysensorsgw mysgw: TSF:LRT:OK
        Jul 12 08:30:15 mysensorsgw mysgw: TSM:INIT
        Jul 12 08:30:15 mysensorsgw mysgw: TSF:WUR:MS=0
        Jul 12 08:30:15 mysensorsgw mysgw: !TSM:INIT:TSP FAIL
        Jul 12 08:30:15 mysensorsgw mysgw: TSM:FAIL:CNT=1
        Jul 12 08:30:15 mysensorsgw mysgw: TSM:FAIL:DIS
        Jul 12 08:30:15 mysensorsgw mysgw: TSF:TDI:TSL
        Jul 12 08:30:25 mysensorsgw mysgw: TSM:FAIL:RE-INIT
        Jul 12 08:30:25 mysensorsgw mysgw: TSM:INIT
        Jul 12 08:30:26 mysensorsgw mysgw: !TSM:INIT:TSP FAIL
        Jul 12 08:30:26 mysensorsgw mysgw: TSM:FAIL:CNT=2
        Jul 12 08:30:26 mysensorsgw mysgw: TSM:FAIL:DIS
        Jul 12 08:30:26 mysensorsgw mysgw: TSF:TDI:TSL
        Jul 12 08:30:36 mysensorsgw mysgw: TSM:FAIL:RE-INIT
        Jul 12 08:30:36 mysensorsgw mysgw: TSM:INIT
        Jul 12 08:30:36 mysensorsgw mysgw: !TSM:INIT:TSP FAIL
        Jul 12 08:30:36 mysensorsgw mysgw: TSM:FAIL:CNT=3
        Jul 12 08:30:36 mysensorsgw mysgw: TSM:FAIL:DIS
        Jul 12 08:30:36 mysensorsgw mysgw: TSF:TDI:TSL
        Jul 12 08:30:40 mysensorsgw mysgw: Received SIGINT
        • H highlifelight
            [OK] Type: mqtt.
            [OK] Saved.
            [OK] Finished.
          Just in case
          @highlifelight it seems like ./configure no longer reacts to --extra-cxxflags :-( I have created an issue in github: https://github.com/mysensors/MySensors/issues/1303
          Could you check out 7d907d17 (git checkout 7d907d17) and re-run the configure command (and make, etc)? 7d907d17 seems to be the last commit that accepted the extra flags.
          H 1 Reply Last reply
            H
            H
            highlifelight
            @mfalkvidd
            Jul 12 11:57:34 INFO  Starting gateway...
            Jul 12 11:57:34 INFO  Protocol version - 2.3.2-beta
            Jul 12 11:57:34 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=4,VER=2.3.2-beta
            Jul 12 11:57:34 DEBUG TSF:LRT:OK
            Jul 12 11:57:34 DEBUG TSM:INIT
            Jul 12 11:57:34 DEBUG TSF:WUR:MS=0
            Jul 12 11:57:34 DEBUG RFM69:INIT
            Jul 12 11:57:34 DEBUG RFM69:INIT:PIN,CS=24,IQP=22,IQN=25
            Jul 12 11:57:34 DEBUG RFM69:PTX:LEVEL=5 dBm
            Jul 12 11:57:34 DEBUG RFM69:DUMP:Registers Address | HEX value
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x01 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x02 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x03 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x04 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x05 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x06 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x07 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x08 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x09 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x0a Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x0b Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x0c Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x0d Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x0e Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x0f Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x10 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x11 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x12 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x13 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x14 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x15 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x16 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x17 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x18 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x19 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x1a Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x1b Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x1c Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x1d Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x1e Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x1f Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x20 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x21 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x22 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x23 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x24 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x25 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x26 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x27 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x28 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x29 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x2a Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x2b Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x2c Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x2d Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x2e Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x2f Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x30 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x31 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x32 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x33 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x34 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x35 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x36 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x37 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x38 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x39 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x3a Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x3b Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x3c Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x3d Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x3e Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x3f Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x40 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x41 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x42 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x43 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x44 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x45 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x46 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x47 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x48 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x49 Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x4a Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x4b Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x4c Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x4d Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x4e Value=0x00
            Jul 12 11:57:34 DEBUG RFM69:DUMP:REG=0x4f Value=0x00
            Jul 12 11:57:34 DEBUG !RFM69:INIT:SANCHK FAIL
            Jul 12 11:57:34 DEBUG !TSM:INIT:TSP FAIL
            Jul 12 11:57:34 DEBUG TSM:FAIL:CNT=1
            Jul 12 11:57:34 DEBUG TSM:FAIL:DIS
            Jul 12 11:57:34 DEBUG TSF:TDI:TSL
            Jul 12 11:57:34 DEBUG RFM69:RSL
            Jul 12 11:57:44 DEBUG TSM:FAIL:RE-INIT
            Jul 12 11:57:47 DEBUG TSM:INIT
            Jul 12 11:57:47 DEBUG RFM69:INIT
            Jul 12 11:57:47 DEBUG RFM69:INIT:PIN,CS=24,IQP=22,IQN=25
            Jul 12 11:57:48 DEBUG RFM69:PTX:LEVEL=5 dBm
            Jul 12 11:57:48 DEBUG RFM69:DUMP:Registers Address | HEX value
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x01 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x02 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x03 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x04 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x05 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x06 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x07 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x08 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x09 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x0a Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x0b Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x0c Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x0d Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x0e Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x0f Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x10 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x11 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x12 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x13 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x14 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x15 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x16 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x17 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x18 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x19 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x1a Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x1b Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x1c Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x1d Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x1e Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x1f Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x20 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x21 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x22 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x23 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x24 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x25 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x26 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x27 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x28 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x29 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x2a Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x2b Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x2c Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x2d Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x2e Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x2f Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x30 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x31 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x32 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x33 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x34 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x35 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x36 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x37 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x38 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x39 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x3a Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x3b Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x3c Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x3d Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x3e Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x3f Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x40 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x41 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x42 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x43 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x44 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x45 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x46 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x47 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x48 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x49 Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x4a Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x4b Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x4c Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x4d Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x4e Value=0x00
            Jul 12 11:57:48 DEBUG RFM69:DUMP:REG=0x4f Value=0x00
            Jul 12 11:57:48 DEBUG !RFM69:INIT:SANCHK FAIL
            Jul 12 11:57:48 DEBUG !TSM:INIT:TSP FAIL
            Jul 12 11:57:48 DEBUG TSM:FAIL:CNT=2
            Jul 12 11:57:48 DEBUG TSM:FAIL:DIS
            Jul 12 11:57:48 DEBUG TSF:TDI:TSL
            Jul 12 11:57:48 DEBUG RFM69:RSL
            ^CJul 12 11:57:52 NOTICE Received SIGINT
            • H highlifelight
              @mfalkvidd
              @highlifelight hmm. Looks like the radio module doesn't respond at all?
                H
                H
                highlifelight
                @mfalkvidd I'm just so confused. I'm looking at the breakouts, it's not like I'm an expert at soldering but there are no bridges and they are connected appropriately, on both. I guess I should take it up with Adafruit at this point.
                • H highlifelight
                  @highlifelight That makes two of us :)
                  maybe try with a basic rfm69 example sketch (non-mysensors), just to rule out that it is an MySensors issue. Maybe Adafruit has a basic example?
                    H
                    H
                    highlifelight
                    @mfalkvidd Tried that as well. Still waiting for a response on their forum.
                    • K
                      K
                      kimot
                      I am not sure with RST to GND.
                      Look here:
                      link text
                      • K kimot
                        Look here:
                        link text
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @kimot Usually tied to ground via a 100k, but controlled by a pin so the mcu can pulse a reset.
