  3. Secure SSL connection between the Arduino MQTT gateway and the MQTT broker server: status?
2 Posts 2 Posters 647 Views 3 Watching
  • E
    E
    evb
    Did search the forum, but didn't really find an answer of it is now implemented by default in the MySensors library...
    Found : https://forum.mysensors.org/topic/8863/esp8266-mqtt-gateway-ssl-connection
    But it is already 2 years old and it is a proposal to modify the code in the MySensors library.
    @monte : do you know what the status is? There is not really an answer on your topic.
    • monteM
      monteM
      monte
      Well, I never returned to that topic, because I didn't need it. I think it still isn't implemented, but you have my code from that post, so you can try to modify your copy of Mysensors and it should work. If I remember correctly that was pretty simple modification, new version has probably changed, but not so much I guess.
