  3. Ethernet gateway and receive function
7 Posts 2 Posters 1.1k Views 2 Watching
  • D
    D
    DanieleF
    I have an ethernet gw based on Arduino Uno + W5100, working as expected.
    I tried to add an actuator (a simple relay), thus I added the usual "receive" function to the script, but at this point the ethernet stopped sending messages to others nodes.
    I tried filtering the destination, sensors type etc. but it still doesn't work.
    I suppose I should "forward" the messages manually in my receive function, correct?
    Does someone have a working example?
    Daniele
    • D DanieleF
      Daniele
      @danielef hard to say without looking at your code, but my guess is that you're doing something in receive that blocks normal processing.
      I am not sure if I have seen any sketches with actuators on the gateway, but it should be the same as other nodes.
      You should not forward messages manually.
      • D
        D
        DanieleF
        The code is really basic, taken from the ethernet gw template simply adding the receive function:
        #define MY_GATEWAY_W5100
        #define MY_RF24_CS_PIN 3
        #define MY_RF24_IRQ_PIN 2
        #define MY_RX_MESSAGE_BUFFER_FEATURE 6
        #define MY_IP_ADDRESS 192,168,1,20
        #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
        #define MY_PORT 5003
        #if defined(MY_USE_UDP)
        #include <EthernetUdp.h>
        #include <Ethernet.h>
        #define CHILD_ID_LIGHT 1
        #include <MyRF24_P2_GW.h>
          present(CHILD_ID_LIGHT, S_BINARY, "P2 Luci Armadio");
          if (message.type == V_STATUS && message.sensor == CHILD_ID_LIGHT && !message.isAck()) {
            #ifdef MY_DEBUG
            Serial.println("*** Receiving ***");
            statoLuci = message.getBool();
        • D DanieleF
              #ifdef MY_DEBUG
          @danielef thanks for sharing the code. It looks good. What does the debug output look like?
          • D
            D
            DanieleF
            Sorry for the late response, I've been away for a few days.
            The debug output looks very odd to me:
            4850944 MCO:BGN-Q-,REL=255,VER=2.3.1
            4850945 5,VER=2.3.1
            4850945 MCO:BGN:INIT GW,CP=RNNGA-Q-,REL=255,VER=2.3.1
            4850945 5,VER=2.3.1
            4850945 4850944 MCO:BGN:INIT GW,CP=RNNGA-Q-,REL=255,VER=2.3.1
            4850945 MDO:BGN:INIT GW,CP=RNNGA-Q-,REL=255,VER=2.3.1
            4850945 ```
            • D DanieleF
              4850945 5,VER=2.3.1
              4850945 5,VER=2.3.1
              4850945 ```
              @danielef the sketch you posted does not compile
              'statoLuci' was not declared in this scope
              are you sure this is the code you are using?
              Is there anything in MyRF24_P2_GW.h that we need to know about?
              From the log, it looks like the node is repeatedly calling Init, without reboot. That is very strange.
              • D
                D
                DanieleF
                This is the full code, in my previous message I tried simplifing it and I missed a variable declaration:
                //#define MY_DEBUG_DETAIL
                MyMessage msgLIGHT(CHILD_ID_LIGHT, V_STATUS);
                #define BUTTON_UP A4
                #define BUTTON_DW A5
                #include <Bounce2.h>
                Bounce debounceUp = Bounce();
                Bounce debounceDw = Bounce();
                bool statoLuci = 1;
                const byte numReed = 4;
                const byte pinReed[numReed] = {A0,A1,A2,A3};
                const byte pinRelay[numReed] = {5,6,7,8};
                bool statoReed[numReed];
                //  request(CHILD_ID_LIGHT, V_STATUS);
                  debounceUp.attach(BUTTON_UP, INPUT_PULLUP);
                  debounceUp.interval(5);
                  debounceDw.attach(BUTTON_DW, INPUT_PULLUP);
                  debounceDw.interval(5);
                  for (int i=0; i<numReed; i++){
                    pinMode(pinReed[i], INPUT_PULLUP);
                    statoReed[i] = 0;
                    pinMode(pinRelay[i], OUTPUT);
                  debounceUp.update();
                  debounceDw.update();
                  if ( debounceUp.fell() ) {
                    Serial.println("UP");
                  if ( debounceDw.fell() ) {
                    Serial.println("DOWN");
                    if (statoLuci){
                      statoReed[i] = digitalRead(pinReed[i]);
                      digitalWrite(pinRelay[i], statoReed[i]);
                    else
                      digitalWrite(pinRelay[i], 0);
                    #ifdef MY_DEBUG_DETAIL
                    Serial.print("Reed ");
                    Serial.print(i);
                    Serial.print(" : ");
                    Serial.println(statoReed[i]);
                  Serial.println("****************");
                  wait(1000);
                  if (message.destination == 0 && message.type == V_STATUS && message.sensor == CHILD_ID_LIGHT && !message.isAck()) {
                    #ifdef MY_DEBUG
                MyRF24_2_GW.h contains simply some common defines I use for all the nodes connected to this GW:
                #define MY_RF24_DATARATE   RF24_250KBPS
                #define MY_RF24_CHANNEL 115
                #ifndef MY_RF24_PA_LEVEL
                #define MY_RF24_PA_LEVEL   RF24_PA_HIGH
                #ifndef MY_PARENT_NODE_ID
                #define MY_PARENT_NODE_ID 0
