  3. 1.2 MPa pressure transducer
9 Posts 3 Posters 1.6k Views 2 Watching
  • S
    Sundeep Goel
    Can someone point me towards some documentation which explain the working (i mean internal working) of the 1904 / 1.2 MPa pressure transducer.
    I have two units, one of which has started behaving erratically with readings fluctuating wildly from 300mv to Vcc.
    regards,
    Sundeep
    B 1 Reply Last reply
    • S Sundeep Goel
      regards,
      Sundeep
      B
      B
      boozz
      wrote on last edited by boozz
      @sundeep-goel
      Maybe something like this?
      This comes from: https://issuu.com/process1/docs/pii-june-2019
      Page 14 and further
      S 1 Reply Last reply
      • B boozz
        @sundeep-goel
        Page 14 and further
        Sundeep Goel
        @boozz said in 1.2 MPa pressure transducer:
        @sundeep-goel
        Page 14 and further
        Super, thanks!!
        Any idea on what (if anything) could be done to get it working properly again ?
        • S Sundeep Goel
          @sundeep-goel
          Page 14 and further
          Super, thanks!!
          zboblamontZ
          zboblamontZ
          zboblamont
          @sundeep-goel Short of flushing out the pressure port to dislodge any debris, these are not designed to be repaired...
          • zboblamontZ zboblamont
            Sundeep Goel
            @zboblamont said in 1.2 MPa pressure transducer:
            Thought as much, tried heating it today just in case that helped. No luck, its stuck at VCC now :(
            real pity, it was almost brand new !!!
            • S Sundeep Goel
              Sundeep Goel
              Hi, another strange problem - the ok unit works fine on the workbench, however, when i connect it to the water pipe the readings start fluctuating quite a bit ? Any pointers on how i can stabilise the system ?
              zboblamontZ B 2 Replies Last reply
              • S Sundeep Goel
                zboblamontZ
                zboblamontZ
                zboblamont
                @sundeep-goel Stick a meter on it to see if the pressure fluctuation is real?
                I use a pressure regulator and pressure vessels so not much variation.
                In industry we used to use them atop valves to not only permit servicing but an air pocket acted as a buffer.
                • S Sundeep Goel
                  B
                  B
                  boozz
                  @sundeep-goel
                  • could be some noise (EMC). What's your sample rate?
                  • could be the change in pressure in the water pipe due to some users upstream and your own usage (downstream).
                  agree with @zboblamont: if possible have a look at what your real pressure fluctuation is.
                    Sundeep Goel
                    Thanks, i'll try the pipe / buffer method and see if that helps. Will use a PVC pipe to rule out any EMC reaching the sensor.
