  3. P1 not working when using Mysensors ?
10 Posts 3 Posters 1.2k Views 3 Watching
  • T
    Toine33
    Hey guys,
    I am trying to make this sketch work for a few days now but it looks like it wont work in combination with Mysensors.
    Here the sketch without the Mysensors.
    I am receiving output of the P1 Port on hardware serial 2.
    //#define MY_RADIO_RF24
    //#include <MySensors.h>
    char c;
     Serial.begin(19200);
      Serial2.begin(9600, SERIAL_7N1);
        if (Serial2.available()) {
            c = Serial2.read();
        Serial.print(c);
    /* Baud-rates available: 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 28800, 38400, 57600, or 115200, 256000, 512000, 962100
     *  Protocols available:
     * SERIAL_5N1   5-bit No parity 1 stop bit
     * SERIAL_6N1   6-bit No parity 1 stop bit
     * SERIAL_7N1   7-bit No parity 1 stop bit
     * SERIAL_8N1 (the default) 8-bit No parity 1 stop bit
     * SERIAL_5N2   5-bit No parity 2 stop bits
     * SERIAL_6N2   6-bit No parity 2 stop bits
     * SERIAL_7N2   7-bit No parity 2 stop bits
     * SERIAL_8N2   8-bit No parity 2 stop bits
     * SERIAL_5E1   5-bit Even parity 1 stop bit
     * SERIAL_6E1   6-bit Even parity 1 stop bit
     * SERIAL_7E1   7-bit Even parity 1 stop bit
     * SERIAL_8E1   8-bit Even parity 1 stop bit
     * SERIAL_5E2   5-bit Even parity 2 stop bit
     * SERIAL_6E2   6-bit Even parity 2 stop bit
     * SERIAL_7E2   7-bit Even parity 2 stop bit
     * SERIAL_8E2   8-bit Even parity 2 stop bit
     * SERIAL_5O1   5-bit Odd  parity 1 stop bit
     * SERIAL_6O1   6-bit Odd  parity 1 stop bit
     * SERIAL_7O1   7-bit Odd  parity 1 stop bit
     * SERIAL_8O1   8-bit Odd  parity 1 stop bit
     * SERIAL_5O2   5-bit Odd  parity 2 stop bit
     * SERIAL_6O2   6-bit Odd  parity 2 stop bit
     * SERIAL_7O2   7-bit Odd  parity 2 stop bit
     * SERIAL_8O2   8-bit Odd  parity 2 stop bit
    When i am using this same sketch with the Mysensors it is not giving output anymore.
    Does someone has an clue ?
    I have used an Arduino nano 16mhz first on altsoftserial with the same result.
    in this example i am using an Arduino mega 2560.
    char c;
            c = Serial2.read();
        Serial.print(c);
    • T Toine33
      Hey guys,
      char c;
              c = Serial2.read();
          Serial.print(c);
      char c;
              c = Serial2.read();
          Serial.print(c);
      Welcome to the mysensors community @toine33
      What does the debug output from the node say?
      Are you sure the nrf24 is correctly wired? Is your gateway and controller up and running?
      If you haven't already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to troubleshoot them efficiently.
      • T
        Toine33
        So the output wich is given on the first sketch is :
        /ISk5\2MT382-1003
        0-0:96.1.1(5A424556303035303738373110323132)
        1-0:1.8.1(08316.297*kWh)
        1-0:1.8.2(08472.574*kWh)
        1-0:2.8.1(00000.020*kWh)
        1-0:2.8.2(00000.010*kWh)
        0-0:96.14.0(0001)
        1-0:1.7.0(0000.38*kW)
        1-0:2.7.0(0000.00*kW)
        0-0:17.0.0(0999.00*kW)
        0-0:96.3.10(1)
        0-0:96.13.1()
        0-0:96.13.0()
        0-1:24.1.0(3)
        0-1:96.1.0(3238303131303031323031113336343132)
        0-1:24.3.0(190907210000)(00)(60)(1)(0-1:24.2.1)(m3)
        (04212.860)
        0-1:24.4.0(1)
        You can see here the output of my energy meter wich is given every 10 seconds
        And this is the output when i am using the sketch with Mysensors,
        It is curently not connected because im am unable at the moment.
        The strange part is that the serial prints are not workig at this stage anymore or is this normal when using mysensors?
         __  __       ____
                |___/                      2.3.0
        16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
        25 TSM:INIT
        26 TSF:WUR:MS=0
        33 !TSM:INIT:TSP FAIL
        35 TSM:FAIL:CNT=1
        37 TSM:FAIL:DIS
        38 TSF:TDI:TSL
        10040 TSM:FAIL:RE-INIT
        10042 TSM:INIT
        10048 !TSM:INIT:TSP FAIL
        10051 TSM:FAIL:CNT=2
        10053 TSM:FAIL:DIS
        10054 TSF:TDI:TSL
        20057 TSM:FAIL:RE-INIT
        20059 TSM:INIT
        20065 !TSM:INIT:TSP FAIL
        20068 TSM:FAIL:CNT=3
        20070 TSM:FAIL:DIS
        20071 TSF:TDI:TSL
        30074 TSM:FAIL:RE-INIT
        30076 TSM:INIT
        30083 !TSM:INIT:TSP FAIL
        30086 TSM:FAIL:CNT=4
        30088 TSM:FAIL:DIS
        30089 TSF:TDI:TSL
        40092 TSM:FAIL:RE-INIT
        40094 TSM:INIT
        40100 !TSM:INIT:TSP FAIL
        40103 TSM:FAIL:CNT=5
        40105 TSM:FAIL:DIS
        40107 TSF:TDI:TSL
        50110 TSM:FAIL:RE-INIT
        50112 TSM:INIT
        50118 !TSM:INIT:TSP FAIL
        50121 TSM:FAIL:CNT=6
        50123 TSM:FAIL:DIS
        50124 TSF:TDI:TSL
        60127 TSM:FAIL:RE-INIT
        60129 TSM:INIT
        60135 !TSM:INIT:TSP FAIL
        60138 TSM:FAIL:CNT=7
        60140 TSM:FAIL:DIS
        60141 TSF:TDI:TSL
        120144 TSM:FAIL:RE-INIT
        120146 TSM:INIT
        120154 !TSM:INIT:TSP FAIL
        120156 TSM:FAIL:CNT=7
        120158 TSM:FAIL:DIS
        120160 TSF:TDI:TSL
        P.S
        I have done some testing also on RS485 and had the same situation.
        • T Toine33
          /ISk5\2MT382-1003
          0-0:96.14.0(0001)
          0-0:96.3.10(1)
          0-0:96.13.1()
          0-0:96.13.0()
          0-1:24.1.0(3)
          (04212.860)
          0-1:24.4.0(1)
           __  __       ____
                  |___/                      2.3.0
          25 TSM:INIT
          26 TSF:WUR:MS=0
          35 TSM:FAIL:CNT=1
          37 TSM:FAIL:DIS
          38 TSF:TDI:TSL
          10042 TSM:INIT
          10053 TSM:FAIL:DIS
          10054 TSF:TDI:TSL
          20059 TSM:INIT
          20070 TSM:FAIL:DIS
          20071 TSF:TDI:TSL
          30076 TSM:INIT
          30088 TSM:FAIL:DIS
          30089 TSF:TDI:TSL
          40094 TSM:INIT
          40105 TSM:FAIL:DIS
          40107 TSF:TDI:TSL
          50112 TSM:INIT
          50123 TSM:FAIL:DIS
          50124 TSF:TDI:TSL
          60129 TSM:INIT
          60140 TSM:FAIL:DIS
          60141 TSF:TDI:TSL
          120146 TSM:INIT
          120158 TSM:FAIL:DIS
          120160 TSF:TDI:TSL
          P.S
          @toine33 yes this is normal. MySensors is unable to initialize the radio so it never reaches setup, nor loop.
          • electrikE
            electrikE
            electrik
            You expect the baudrate to be 19200, but Mysensors also initialises the port at a baudrate. Maybe that one is done later and you should use the terminal on that baudrate?
            • T
              Toine33
              Hey guys,
              Thanks for helping :) . The sketch was working after i have deleted the Serial.begin in the void setup.
              i only have some other issues at the moment haha,
              The value's from the gas meter / high an low elecktricity are showing wrong within Domoticz
              When i am doing /1000 on the send values of the GAS meter and elecktricity meters i am getting an beter value but i loose 3 decimals and cant see any calculated value by domoticz.
              Is there an option to send these decimals ?
              #define MY_RS485
              #define MY_RS485_DE_PIN 2
              #define MY_RS485_BAUD_RATE 19200
              #define MY_RS485_HWSERIAL Serial
              #define MY_NODE_ID 3
              #include <AltSoftSerial.h>
              AltSoftSerial altSerial;
              int msg[1];
              const uint64_t pipe = 0xE8E8F0F0E1LL;
              const int requestPin =  4;
              char input; // incoming serial data (byte)
              bool readnextLine = false;
              #define BUFSIZE 500
              #define CHILD_ID_WATT 0
              #define CHILD_ID_KWH_LOW 1
              #define CHILD_ID_KWH_HIGH 2
              #define CHILD_ID_GAS 3
              #define CHILD_ID_CURRENT 4
              char buffer[BUFSIZE]; //Buffer for serial data to find \n .
              int bufpos = 0;
              long mEVLT = 0; //Meter reading Electrics - consumption low tariff
              long mEVHT = 0; //Meter reading Electrics - consumption high tariff
              long mEAV = 0;  //Meter reading Electrics - Actual consumption
              long mEAT = 0;  //Meter reading Electrics - Actual generated electricity (Solar panels)
              long mG = 0;   //Meter reading Gas
              MyMessage msgWatt(CHILD_ID_WATT, V_WATT);
              MyMessage msgKwhLow(CHILD_ID_KWH_LOW, V_KWH);      //Was V_KWH
              MyMessage msgKwhHigh(CHILD_ID_KWH_HIGH, V_KWH);     //Was V_KWH
              MyMessage msgGas(CHILD_ID_GAS, V_VOLUME);
              //  Serial.begin(19200);
              //  delay(1000);
                altSerial.begin(9600);
                delay(1000);
              void presentation() {
                sendSketchInfo("Node", "1.0");
                present(CHILD_ID_WATT, S_POWER);
                present(CHILD_ID_KWH_LOW, S_POWER);
                present(CHILD_ID_KWH_HIGH, S_POWER);
                present(CHILD_ID_GAS, S_GAS);
                long tl = 0;
                long tld =0;
                if (altSerial.available()) {
                    char input = altSerial.read();
                    buffer[bufpos] = input&127;
                    bufpos++;
                    if (input == '\n') { // We received a new line (data up to \n)
                      // 1-0:1.8.2 = Electricity consumption high tariff (DSMR v4.0)
                      if (sscanf(buffer,"1-0:1.8.2(%ld%.%ld%*s" , &tl, &tld) >0 ) {
                        tl *= 1000;
                        tl += tld;
                        mEVHT = tl;
                        //mEVHT = tl * 1000 + tld;
                        if (mEVHT > 0) {
                          //mEVHT = 0;
                      if (sscanf(buffer,"1-0:1.8.1(%ld.%ld" ,&tl, &tld)==2){
                        tl *= 1000;
                        tl += tld;
                        mEVLT = tl;
                        if (mEVLT > 0) {
                      // 1-0:1.7.0 = Electricity consumption actual usage (DSMR v4.0)
                      if (sscanf(buffer,"1-0:1.7.0(%ld.%ld" ,&tl , &tld) == 2)
                        mEAV = (tl*1000)+tld*10;
                        if (mEAV > 0) {
              /* Geeft actuele waarde door maar doet geen compare
              if (sscanf(buffer,"(%ld.%ld" , &tl, &tld)==2 )
                    {   mG = (tl*1000.0)+tld;
                    mG = mG/1000;
              //Gastand uitlezen
                    mG = mG;
                      // Empty buffer again (whole array)
                      for (int i=0; i<500; i++)
                        buffer[i] = 0;
                      bufpos = 0;
                    if (input == '!') {   //uitroepteken geeft einde van telegram aan, dus we gaan data versturen
                      #ifdef DEBUG
                        printData();
                      send(msgWatt.set(mEAV));
                      send(msgKwhLow.set(mEVLT));
                      send(msgKwhHigh.set(mEVHT));
                      send(msgGas.set(mG));
                      mEVHT=0;
                      mEVLT = 0;
                      mEAV = 0;
                      mG = 0;
                      //client.stop();
                    } //Einde vraagteken detectie
              Thanks !
              • T Toine33
                Hey guys,
                #define MY_RS485
                int msg[1];
                #define BUFSIZE 500
                int bufpos = 0;
                //  delay(1000);
                  delay(1000);
                  long tl = 0;
                  long tld =0;
                      bufpos++;
                          tl *= 1000;
                          tl += tld;
                          mEVHT = tl;
                          if (mEVHT > 0) {
                            //mEVHT = 0;
                          tl *= 1000;
                          tl += tld;
                          mEVLT = tl;
                          if (mEVLT > 0) {
                          if (mEAV > 0) {
                      mG = mG/1000;
                //Gastand uitlezen
                      mG = mG;
                          buffer[i] = 0;
                        bufpos = 0;
                        #ifdef DEBUG
                          printData();
                        mEVHT=0;
                        mEVLT = 0;
                        mEAV = 0;
                        mG = 0;
                        //client.stop();
                Thanks !
                Nice work @toine33
                Use set(value, numberOfDecimals)
                Example:
                send(msgWatt.set(mEAV, 3));
                Documentation: https://www.mysensors.org/apidocs/MyMessage_8h.html#a8af6ca9ee9a61b5954e405a2ae7de361
                T 1 Reply Last reply
                  Nice work @toine33
                  Example:
                  Toine33
                  @mfalkvidd
                  Sorry for asking , but as you already noticed i am not super familiar to the arduino coding haha.
                  So i have tried send(msgWatt.set(mEAV, 3));
                  But the only output i am receiving is something like this,
                  TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=35,pt=7,l=5,sg=0,ft=0,st=OK:4213752.000
                  What i would like to archieve is an value like
                  TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=35,pt=7,l=5,sg=0,ft=0,st=OK:4213.752
                  I just would like to ad an decimal somehow and send this to Domoticz.
                  • T Toine33
                    @mfalkvidd
                    @toine33 asking is exactly what the forum is here for :)
                    This should work (note: .0 is a "trick" to let the compiler know we want a floating point / decimal number)
                    send(msgWatt.set(mEAV / 1000.0, 3));
                      Toine33
                      @mfalkvidd
                      Thank you so much :D Finnaly it is working as it should do!
                      #define MY_RS485
                      int msg[1];
                      #define BUFSIZE 500
                      int bufpos = 0;
                      //  delay(1000);
                        delay(1000);
                        long tl = 0;
                        long tld =0;
                            bufpos++;
                              if (sscanf(buffer,"1-0:1.8.2(%ld.%ld" , &tl, &tld) >0 ) {
                                tl *= 1000;
                                tl += tld;
                                mEVHT = tl;
                                if (mEVHT > 0) {
                                  //mEVHT = 0;
                                tl *= 1000;
                                tl += tld;
                                mEVLT = tl;
                                if (mEVLT > 0) {
                                if (mEAV > 0) {
                      //Gastand uitlezen
                            mG = mG;
                                buffer[i] = 0;
                              bufpos = 0;
                              #ifdef DEBUG
                                printData();
                              send(msgKwhLow.set(mEVLT / 1000.0, 3));
                              send(msgKwhHigh.set(mEVHT / 1000.0, 3));
                              send(msgGas.set(mG / 1000.0, 3));
                              mEVHT=0;
                              mEVLT = 0;
                              mEAV = 0;
                              mG = 0;
                              //client.stop();
                      And here an picture how it is showing up in domoticz:
