  3. MySensors on ATTiny84 and RFM69CW
4 Posts 2 Posters 1.1k Views 3 Watching
  • B
    B
    blachner
    I try to get MySensors working on an ATtiny 84 with RFM69CW module. I use the Tiny TX 3 Sensor board. I know, because of little memory, I can use this for reel simple nodes, at the best.
    First I do some changes to get MYSensors to compile with the ATTiny core.
    I have to disable serialEventRun in MySensors main (MyMainAVR.cpp) because there is no serial interface on ATtiny:
    int main(void)
    	init();
    #if defined(USBCON)
    	USBDevice.attach();
    	_begin(); // Startup MySensors library
    	for(;;) {
    		_process();  // Process incoming data
    		if (loop) {
    			loop(); // Call sketch loop
    // MCU like ATtiny don't support serial
    #if defined(HAVE_HWSERIAL0) || defined(HAVE_HWSERIAL1) || defined(HAVE_HWSERIAL2) || defined(HAVE_HWSERIAL3)
    		if (serialEventRun) {
    			serialEventRun();
    	return 0;
    I also have to change clearPendingInterrupt (MyHWAVR.cpp) because ATtiny 84 only have on interrupt and use an other register:
    void clearPendingInterrupt(const uint8_t interrupt)
    #ifdef ATTINY_CORE
    	// Flag for INT0 / ATtiny84 is on Bit 6 in GIFR
    	if (interrupt == 0)
    		GIFR = _BV(interrupt + 6);
    #else
    	EIFR = _BV(interrupt);
    I also have to change hwUniqueID (MyHWAVR.cpp). I know this code don't really return a unique ID. At the moment I have no idea how to do this for ATtiny. But I think also that souldn't prevent MySensors from working.
    bool hwUniqueID(unique_id_t *uniqueID)
    	// padding
    	(void)memset(uniqueID, MY_HWID_PADDING_BYTE, sizeof(unique_id_t));
    #ifndef ATTINY_CORE
    	// no unique ID for non-PB AVR, use HW specifics for diversification
    	*((uint8_t *)uniqueID) = boot_signature_byte_get(0x00);
    	*((uint8_t *)uniqueID + 1) = boot_signature_byte_get(0x02);
    	*((uint8_t *)uniqueID + 2) = boot_signature_byte_get(0x04);
    	*((uint8_t *)uniqueID + 3) = boot_signature_byte_get(0x01); //OSCCAL
    #if defined(__AVR_ATmega328PB__)
    	// ATMEGA328PB specifics, has unique ID
    	for(uint8_t idx = 0; idx < 10; idx++) {
    		*((uint8_t *)uniqueID + 4 + idx) = boot_signature_byte_get(0xE + idx);
    	return true; // unique ID returned
    #else
    	return false;	// no unique ID returned
    With this little changes, which I think aren't completely wrong, MySensors compile for ATtiny. At least after this changes it compiles for the Attiny 84 on TinyTX3 and for my Arduino Nano which I also use for testing.
    I got also message sent to my gateway from the ATiny. But it seems, it never receives the incoming message because I get this log:
    TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSF:MSG:BC
    TSF:MSG:FPAR REQ,ID=5
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    TSF:MSG:BC
    TSF:CKU:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:CKU:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:CKU:OK,FCTRL
    TSF:MSG:GWL OK
    An endless I_FIND_PARENT_REQUEST / I_FIND_PARENT_RESPONSE sequence The same program on Arduino Nano works.
    My first idea was, that the interrupt on ATtiny don't work (because I changes the code for clearPendingInterrupt how you can see above :-) ). But I set an output pin to debug (because I have no serial on ATtiny) in the interrupt routine and it seems that at least it is called.
    By check the output pins I also see the (Arduino) pin 8 and 9 is set to high. I don't know why. I don't set thess in my program but I also don't see at the moment that they are set in the MySensors code.
    Does anyone have an idea why pin 8 and 9 is high? Or why incoming messages aren't processed?
    B 1 Reply Last reply
    • B blachner
      int main(void)
      	init();
      #if defined(USBCON)
      	USBDevice.attach();
      	for(;;) {
      		if (loop) {
      			serialEventRun();
      	return 0;
      #ifdef ATTINY_CORE
      	if (interrupt == 0)
      #else
      	// padding
      #ifndef ATTINY_CORE
      #else
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CKU:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CKU:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CKU:OK,FCTRL
      TSF:MSG:GWL OK
      B
      B
      blachner
      wrote on last edited by blachner
      OK I now know why Pin 8 and 9 is not 0V. It was used for a software serial interface on ATtiny. I could disable this with "#define MY_DISABLED_SERIAL". I also now use "#define MY_PASSIVE_NODE", because for my intended use as temperature/humidity sensor its OK.
      The following test program no works on ATtiny84 with my changes to MySensor lib:
      #include <Arduino.h>
      // ATMEL ATTINY84 / ARDUINO Pin map
      //                     VCC  1|    |14  GND
      //             (D  0)  PB0  2|    |13  AREF (D 10)
      //             (D  1)  PB1  3|    |12  PA1  (D  9)
      //                     PB3  4|    |11  PA2  (D  8)
      //  PWM  INT0  (D  2)  PB2  5|    |10  PA3  (D  7)
      //  PWM        (D  3)  PA7  6|    |9   PA4  (D  6)
      //  PWM        (D  4)  PA6  7|    |8   PA5  (D  5)        PWM
      #ifdef ATTINY_CORE
        #define MY_NODE_ID 5
        #define MY_RFM69_CS_PIN 1
      #else
        #define MY_NODE_ID 1
      #define MY_RADIO_RFM69
      #define MY_RFM69_NEW_DRIVER
      #define MY_RFM69_FREQUENCY RFM69_433MHZ
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      // Set this offset if the sensor has a permanent small offset to the real temperatures.
      // In Celsius degrees (as measured by the device)
      #define SENSOR_TEMP_OFFSET 0
      #ifdef ATTINY_CORE
        sendSketchInfo("TinyTest", "1.1");
      #else
        sendSketchInfo("NanoTest", "1.1");
        delay(3000);
        present(CHILD_ID_HUM, S_HUM);
        delay(3000);
        delay(3000);
      #ifdef ATTINY_CORE
        pinMode(0, OUTPUT);
        pinMode(3, OUTPUT);
        pinMode(7, OUTPUT);
        pinMode(8, OUTPUT);
        pinMode(9, OUTPUT);
        pinMode(10, OUTPUT);
      #else
        Serial.begin(9600);
        float temperature = 11.11f;
        // if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
        //   // Only send temperature if it changed since the last measurement or if we didn't send an update for n times
        //   lastTemp = temperature;
        //   // apply the offset before converting to something different than Celsius degrees
        //   temperature += SENSOR_TEMP_OFFSET;
        //   // Reset no updates counter
        //   nNoUpdatesTemp = 0;
        //   send(msgTemp.set(temperature, 2));
        // else
        //   // Increase no update counter if the temperature stayed the same
        //   nNoUpdatesTemp++;
        if (send(msgTemp.set(temperature, 2)))
          digitalWrite(0, HIGH);
        else
          digitalWrite(3, HIGH);
        delay(3000);
        float humidity = 55.55f;
        send(msgHum.set(humidity, 2));
        // if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS)
        //   // Only send humidity if it changed since the last measurement or if we didn't send an update for n times
        //   lastHum = humidity;
        //   nNoUpdatesHum = 0;
        //   send(msgHum.set(humidity, 2));
        // else
        //   // Increase no update counter if the humidity stayed the same
        //   nNoUpdatesHum++;
        delay(3000);
      But some problems still remaining. The biggest one, sleep don't work. If I replace delay by sleep in the program above, the program really behaves strange. So I think I must rewrite this function for ATtiny84. Has anyone tips how to do this?
      Nca78N 1 Reply Last reply
      • B blachner
        //                     VCC  1|    |14  GND
        #ifdef ATTINY_CORE
        #else
        float lastTemp;
        float lastHum;
        #ifdef ATTINY_CORE
        #else
          delay(3000);
          delay(3000);
          delay(3000);
        #ifdef ATTINY_CORE
          pinMode(0, OUTPUT);
          pinMode(3, OUTPUT);
          pinMode(7, OUTPUT);
          pinMode(8, OUTPUT);
          pinMode(9, OUTPUT);
        #else
          Serial.begin(9600);
          // else
          else
          delay(3000);
          // else
          //   nNoUpdatesHum++;
          delay(3000);
        Nca78N
        Nca78N
        @blachner said in MySensors on ATTiny84 and RFM69CW:
        Hello, you should not use delay() with MySensors but wait(), which will poll the NRF24 regularly to receive incoming messages.
        • Nca78N Nca78
          B
          B
          blachner
          @nca78 said in MySensors on ATTiny84 and RFM69CW:
          You are surely right, that using delay isn't normally a good idea for a MySensors program. In my case I only want to implement a passive node to measure temperature and humidity. So my program don't wait for any incoming messages and delay wouldn't be a problem for this reason. But for the final version delay wouldn't be a good solution for another reason: battery life. But I have now a working sleep function for the ATTiny84 which needs only approximately 6µA during sleep.
          In the meantime I found the reasons for my problems. My program just uses to much RAM (only 512 Byte on ATTiny84 available), so the stack destroys other variables and the program behaves strange. But I now found a solution for a working passive MySensors Node for temperature and humidity on ATTiny84 with RFM69 radio module and the BME280 as temperature/humidity sensor. I will show my solution here anytime soon, maybe it is of interest for others who try something similar.
