  3. ES8266 Wemos D1 with DHT22 - no sleep WUP -2
2 Posts 2 Posters 592 Views 2 Watching
  • B
    B
    babajun
    I am using a Wemos D1 as 8266_gateway with a DHT22 attached.
    Debug output reports some DHT read errors but from time to time temperature and humidity values are fine.
    I used the DHT22 sample code but the device ingnores the "sleep" command.
    Node woke-up, reason/IRQ=-2 (-2=not possible, -1=timer, >=0 IRQ)
    Is it because a gateway cannot "sleep" ?
    connected with HomeWIFI, channel 6
    ip:192.168.1.33,mask:255.255.255.0,gw:192.168.1.1
    4221 GWT:TIN:IP: 192.168.1.33
    4252 MCO:BGN:STP
    4275 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4333 MCO:SLP:WUP=-2
    4354 MCO:REG:NOT NEEDED
    4379 MCO:BGN:INIT OK,TSP=NA
    Failed reading temperature from DHT!
    Failed reading humidity from DHT
    4409 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4543 MCO:SLP:WUP=-2
    4565 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4698 MCO:SLP:WUP=-2
    T: 26.00
    H: 47.00
    4725 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4804 MCO:SLP:WUP=-2```
    • B babajun
      4252 MCO:BGN:STP
      4333 MCO:SLP:WUP=-2
      4543 MCO:SLP:WUP=-2
      4698 MCO:SLP:WUP=-2
      T: 26.00
      H: 47.00
      @babajun no, it is because the esp8266 has no sleep mode that is useful. Esp8266 requires a full restart after sleeping.
      Use wait() instead.
